antifreeze? | FerrariChat
antifreeze?
Discussion in 'Technical Q&A' started by nancy1, May 10, 2014.
  1. nancy1
    nancy1 Rookie
    May 10, 2014
    4
    ive got 13 years but only 4000 miles--
  2. Mozella
    Mozella Formula Junior
    Mar 24, 2013
    905
    Piemonte, Italia
    " ive got 13 years but only 4000 miles-- "
    Are you bragging or complaining? ;)
    Time to change. Make sure you use the correct coolant.
    By the way, drive your car more often.
  3. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,681
    NJ
    Peter
    As I understand it, antifreeze doesn't really wear out with usage but it turns acidic over time -- so age is a bigger concern than miles driven. Definitely it should be changed. There are kits on Amazon (and maybe in Automotive parts stores) that allow you to check the PH level of antifreeze -- it might be worth using those to check the current PH to see if any damage was done.
