antifreeze | FerrariChat
antifreeze
Discussion in 'Technical Q&A' started by fastaone, Jan 27, 2004.
  1. fastaone
    fastaone Karting
    Jan 9, 2004
    192
    Long Island
    Peter F
    Hello ferraristi
    Imp concern on the overflow of antifreeze on my 1983 308 GTS,
    I found that after a 30 mile ride, I saw antifreeze coming out the overflow as soon I killed the engine, the temp. Gauge did not run hot while I was driving, I checked the expansion tank and it was at list half way full. Did I have too much antifreeze? Did anyone have this same problem?
    Thanks in advance
    Peter
  2. Steve Magnusson
    26,580
    Do you bleed your radiator quasi-regularly?
  3. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Faulty cap. Replace.
  4. JeffMN
    JeffMN Rookie
    Jan 18, 2004
    28
    I can't speak for 308s specifically but that's normal in alot of cars. The cap lets the fluid into the jar at a certain pressure and it gets sucked back in when the car cools down.
    -Jeff
  5. fastaone
    fastaone Karting
    Jan 9, 2004
    192
    Long Island
    Peter F
    I replaced the water pump about a month ago, that was the last time I bleeded the radiator.
    About the radiator cap, it was replaced 2 weeks ago.
    How much antifreeze should be in the expansion tank?
  6. Steve Magnusson
    26,580
    There should be a figure (or two) in your OM showing the recommended "cold" level -- something like 6 cm below the cap (check the "liquids" section in Chap 1 and the "cooling system" in Chap 3).
  7. Doc
    Doc Formula Junior
    Sep 13, 2001
    886
    Latham, New York
    Bill Van Dyne
    I believe that the level of coolant in the tank shouldn't be more than between 2-3 inches from the neck. Be sure to bleed the radiator as well. Sometimes you need to do it a few times to get all of the air out after a service of the cooling system.
  8. norm
    norm Karting
    May 30, 2003
    204
    Rochester, NY
    Definitely try bleeding radiator 1st, and it may a take a few times. I had same thing when water pump was replaced in my Mondial. You're also probably down on coolant after it pizzing out overflow tube.
  9. Diablo
    Diablo Formula Junior
    I would check the cap again.
    Most of the time some anti-freeze coming out is normal after topping the system off.
    But since you have changed the cap, lets look at it.
    Sometime ago,even ferrari had a problem with a supplier and got caps that didn't seal for the testarossa. It was like 1 or 2 MM too short.
    Good Luck
  10. ChrisfromRI
    ChrisfromRI Karting
    Jan 28, 2003
    230
    Foster, RI
    Chris F
    IME, you need to fill the reservoir only up to the seam that goes around the middle, which is about 2 inches down from the top. Use a mixture of about half anti-freeze and half distilled water, and stick to the same color antifreeze that is already in there.
    You also need to periodically bleed the air out of the cooling system by running the car up to temp, turning the heater levers to heat, and then opening the front (radiator) bleed screw until the air is out of the system (with the engine running and with the radiator cap in place). Some people do this when the car is parked on an incline, I don't seem to need to. However, I do need to bleed quite regularly.
    If it still burps whe you turn it off, then you should replace the cap.
    Kind Regards, Chris
  11. MarkG
    MarkG Formula Junior
    Nov 3, 2003
    369
    Colorado Springs
    Mark
    Same problem too until I realized I added too much coolant; I believe its 6cm from top (where cap seats). I bought a small T-square ruler and cut it at the proper coolant level, so I just put it on the refil neck and add coolant until it touches the ruler.
    No problems since.
  12. Ron328
    Ron328 F1 Rookie
    2,626
    Willamette Valley, Oregon
    Ron
