430 - Antigravity battery on 430 Scuderia | FerrariChat
430 Antigravity battery on 430 Scuderia
Discussion in '360/430' started by boostedt0y, Dec 30, 2023.
  1. boostedt0y
    boostedt0y Formula Junior
    Dec 25, 2014
    806
    Bay Area, CA
    I picked up an Antigravity battery for my Scud during the Black Friday sale and finally got around to installing it. The battery model is H6/Group-48 60Ah which is roughly a 30 pound saving over the stock Optima red top.
    You will need the battery tray from a F430 to use the Antigravity battery due to the dimensions of the Antigravity battery being different from the Optima red top. The Scud battery tray has a backplate with concave recesses to fit the shape of the Optima red top which causes the AG battery to sit too far forward. With the standard F430 battery tray, the AG battery bolted up with no issues.
  2. MichaelMatic
    MichaelMatic Karting
    Dec 19, 2020
    167
    Raleigh, NC
    Michael D
    The perfect compliment to a scud’s lightweight philosophy.
    boostedt0y likes this.
  3. boostedt0y
    Dec 25, 2014
    806
    Bay Area, CA
    Agreed! Every little bit helps.
    clean512 likes this.
  4. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,117
    Josh @jtcarprojects
    So want to do this
  5. GogglesPisano
    GogglesPisano F1 Rookie
    3,213
    East Bay, California
    Joe
    This was one of my favorite mods. Getting the Bluetooth monitor is worth it if you didn’t get it at the same time.
  6. boostedt0y
    Dec 25, 2014
    806
    Bay Area, CA
    I do have the Bluetooth monitor! I had the setup on my Gt3 and had to make sure the scud had it as well.
  7. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,021
    NE FL
    Ken
    thoughts on 60 vs 40ah?
    how much was it on black friday?
  8. boostedt0y
    Dec 25, 2014
    806
    Bay Area, CA
    They had a 15% sale off their batteries on Black Friday.
    I chose the 60 aH for the extra cranking amps over the small weight savings.
  9. f355spider
    f355spider F1 World Champ
    18,045
    A bluetooth battery monitor is something everyone should consider. They are only $20 on eBay and have a number of useful features through the app.
    Mel Spillman likes this.
  10. U-Boat Commander
    U-Boat Commander Formula 3
    1,304
    Dam, I just changed the battery on my 16M a couple weeks ago. Should have done this.
    How much was the 430 tray? Any issues swapping it in? Does it easily attach to the black fold down panel?
    I assume you no longer need the center bottom bracket?
  11. boostedt0y
    Dec 25, 2014
    806
    Bay Area, CA
    Eurospares had a used 430 tray for $250. The tray is a direct bolt on and attaches to the fold down panel with no issues. Yes, you no longer use the center bottom bracket.
  12. f355spider
    18,045
    Eurospares was where I obtained my used F430 battery tray as well. After three leaking Optima red top AGMs in a row, it was time to move on. Two years ago I made the move to an Interstate AGM from Costco, and no issues. It was puzzling why Ferrari designed the Scuderia battery tray to only fit an Optima battery...the standard tray would have accepted an Optima just fine. They made it so ONLY an Optima would fit. Otherwise you would have to cut and trim the rear most portion to accept a regular battery.
  13. ShineKen
    ShineKen F1 World Champ
    19,892
    Southern California
    Nostradamus
  14. Raconteur
    Raconteur F1 Rookie
    4,081
    Portlandia, OR
    Frank
    Thanks, All, for the Bluetooth battery monitor suggestion. Just purchased one today. Will install when I get a new battery during the spring annual for my 360. Have never heard of it prior.
  15. freshmeat
    freshmeat F1 Veteran
    Aug 30, 2011
    7,284
    quick question for all those that installed an antigravity battery, do you guys still run a trickler charger to it when the car is in storage?
  16. GogglesPisano
    3,213
    Joe
    Mine has sat over a month with zero issues and almost no drop. I would put it on one regardless if storing for more than 3-4 weeks. Also, the bluetooth battery monitor makes it super easy to check the condition.
    ditpixs likes this.
  17. CoreyNJ
    CoreyNJ Formula 3
    2,469
    New Jersey Shore
    If the car isn't being driven for a week or more, then yes, I use the specific CTEK made for Lithium batteries with a Ferrari adapter so it plugs into the special connector under the passenger side. In general, the battery won't drop below 13V if you leave it unplugged for a week or so, but why risk killing the battery accidentally? I keep it charged.
    ditpixs likes this.
  18. f355spider
    18,045
    Regardless of chemistry type, the car will still require a battery tender of the appropriate type when sitting more than 3 or 4 weeks. Going to a lithium battery does not magically fix the parasitic draw the car has. And with these low amp hour batteries you have less reserve capacity, so more of a reason to use the battery tender.
  19. freshmeat
    Aug 30, 2011
    7,284
    Can you spare a fellow scudist some part #s, grazie mille!
  20. freshmeat
    Aug 30, 2011
    7,284
    And oh, anyone looking to do this upgrade, just a heads up, be prepared to pay $900 USD for a brand new F430 plate! I searched high and low but did not manage to find a used one or any other option remotely near the $2-300 price point from 2024.
  21. ShineKen
    19,892
    Southern California
    Nostradamus
    Or you can get a smaller lithium battery and keep the Scud tray.
  22. f355spider
    18,045
    I bought a used one from Eurospares...but it would not be hard to take the 430 Scuderia battery tray and have the back edge trimmed at a metal shop so it could accomodate a standard H6 Group 48 size battery like the F430 battery tray.
  23. forty1
    forty1 Karting
    Jul 4, 2024
    118
    Australia
    Nico
    I use lead acids on my cars but I run lithium on my motorcycles and can confirm, they do run dead flat (eventually), and when it happens, it really sucks to recover more than a traditional battery which you can somewhat brute force a recharge. So a small trickle charger with a lithium setting is worth it.
  24. CoreyNJ
    CoreyNJ Formula 3
    2,469
    New Jersey Shore
    What size fits? I know most of the internal space in the case for the Antigravity batteries is empty space, so a smaller physical size battery that fits the stock tray should make no difference to the car other than not requiring Scud owners to swap out their battery tray. Disclaimer: I have a 2009 F430, not Scud, so this question is for other people, not me.
  25. ShineKen
    19,892
    Southern California
    Nostradamus
    Check a few posts up. I posted pics of the model used on my car. So whatever size that model is…
