Antigravity battery on 458 | Page 3 | FerrariChat
Discussion in '458 Italia/488/F8' started by csteve, Jun 8, 2020.
  1. Beez
    Beez Karting
    111
    ^ Patrick, did you do the battery reset procedure outlined in the owner's manual? I thought I had saved a pic of that page but don't seem to have it right now
  2. Patrick Hsieh
    Patrick Hsieh Rookie
    May 2, 2020
    4
    Pat Shay
    I followed all those steps accordingly. Unfortunately, it didn’t work out.
  3. Shorn355
    Shorn355 F1 Veteran
    6,857
    Colorado
    Scott
    Well I was going to respond but thus pretty much sums it up succinctly :cool::cool:
  4. Beez
    Beez Karting
    111
    My next thought would be that a fuse got blown during install, but I don't have any experience about exactly how to look into that.
  5. Patrick Hsieh
    May 2, 2020
    4
    Pat Shay
    Yeah it seems like a real possibility there. Thanks for your input.
  6. v35
    v35 Karting
    May 15, 2013
    223
    Los Angeles
    Aaron
    Connect the battery to the app and make sure the battery has enough volts in it to turn the engine over. Maybe you got a faulty battery with low voltage.
  7. Jason B
    Jason B Formula Junior
    Apr 7, 2006
    409
    Hbg, PA
    I'm a dealer for AG, call/text me 717-319-2100 today as I'm around and will help you.
    Need4Spd likes this.
  8. SVCalifornia
    SVCalifornia F1 Rookie
    2,552
    Silicon Valley
    Keith
    I assume you’re pushing hard enough on the brake to start it??
    There are fuses located on the top the positive terminal of the battery cable. You can check that you didn’t inadvertently fry one when you placed the cable on the battery. You did put the positive terminal on first? Than the ground.
    ‘One thing to look at, it happened to me, is that you can get the cable weakly attached to the battery so it has enough power to light up the car but not to start it. Mine even went south after it started working. Vibrations loosened the connection. Went back in and noticed I had put the cable on a little skewed so it became loose after a few startups.
    SV
  9. lowmpg
    lowmpg Rookie
    Oct 7, 2022
    20
    Roger Hart
    Sounds like you got a defective AG battery. Contact LithiumMoto.com and they will exchange it for you with one of their H6 60Ah with wireless remote
    jumpstart batteries. They will send you a label to ship it.
