Antigravity Bluetooth Battery Tracker | FerrariChat
Discussion in 'FF/Lusso' started by vraa, Jun 25, 2021.
  1. vraa
    vraa F1 Rookie
    4,586
    Texas
    Mr. A
    I finally got off my ass to install this battery tracker on both of my cars
    Here's a screen shot from my phone of the two monitors on each of the cars, it's right after I had driven the ff
  2. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,261
    Mel
    Thanx I have one too, called Battery Monitor.
    Why did you install them on your two cars ?
  3. vraa
    vraa F1 Rookie
    4,586
    Texas
    Mr. A
    1) I'm a nerd
    2) I thought my ff battery was dying / had a bad cell since it discharged to the point of not starting
  4. sandman03456
    sandman03456 Formula Junior
    389
    Las Vegas, NV
    These are helpful, but after a few months, the casing begins to bubble up, presumably, due to heat. The company was fantastic in supplying a new one right away. When I received the replacement, I affixed some heat shield tape, and it continued to work fine without the bubbling from the heat. It should be noted, however, that despite the bubbling, the original product continued to function just fine. Joe
  5. vraa
    vraa F1 Rookie
    4,586
    Texas
    Mr. A
    Was that through anti gravity or a random chinese company?
  6. sandman03456
    389
    Las Vegas, NV
    #7 sandman03456, Jun 26, 2021
    Bought the AntiGravity tracker on Amazon, but when I had an issue, I contacted AntiGravity directly. They simply asked for a photo before sending out a replacement for free. I will try to locate the photo if it was not deleted
    vraa likes this.
  7. sandman03456
    389
    Las Vegas, NV
  8. sandman03456
    389
    Las Vegas, NV
    Despite, the odd shape, it continued to function properly
  9. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,180
    Denmark
    Max
    I would have thought it would be a better idea to use the OBD port as a way of permanently connect a battery monitor.
  10. Rosino81
    Rosino81 Rookie
    May 25, 2013
    38
    London, UK
    Coming back to this. Just in the process of buying a GTC4 V12 ferrari approved. And paranoid about the battery already - is there no concern with a lithium battery being so close to a very warm area ? Battery monitor clearly suffering, battery holds up fine ?
    LittleEnzo likes this.
  11. LittleEnzo
    LittleEnzo Karting
    Nov 10, 2024
    77
    FPS
    A valid question! Hollywood Mechanic has a program to actually relocate the battery to the back. Personally, I would just stick with an AGM battery and replace it more regularly than having a lithium in that location. I am very familiar with lithium battery fires (from even smaller batteries,) and they scare the hell out of me.
  12. priericky128
    priericky128 Formula Junior
    676
    St. Louis MO
    Rick
    Yeah I am sticking with an agm and learned how to replace it. Even if I have to do it annually it’s really not a big deal
    71veedub likes this.
  13. LittleEnzo
    LittleEnzo Karting
    Nov 10, 2024
    77
    FPS
    Learning how to replace it is kind of impressive. In the Lusso it seems buried under a bunch of other electrical stuff. I told it something like an hour of labor
  14. priericky128
    676
    St. Louis MO
    Rick
    It's really not that bad. It's in the same spot as the FF. You pull off one of the radiation shields and it's under there. The battery is annoyingly heavy and it's a weird angle, but no worse than doing the one in the passenger footwell of the 360...
