458 - Antigravity Lithium Battery Fail. | Page 2 | FerrariChat
458 Antigravity Lithium Battery Fail.
Discussion in '458 Italia/488/F8' started by v35, Jul 30, 2021.
  1. v35
    v35 Karting
    May 15, 2013
    223
    Los Angeles
    Aaron
    Thanks Ray. I did this test at AG’s request to confirm that the re-start feature was non-operational.
    The car is plugged in again and I will just actually start it in a few hours and drive it.
    quickjack and vraa like this.
  2. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    Got it.
    So when you attempted to start the car, previously - using their re-start feature - did the starter motor attempt to crank at all?
    Ray
  3. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    Definitely a faulty battery. That is a test the battery should handle. Dan from Normal Supercar Guy did exactly that test with his 458. There's a video of him doing it on his channel. Do a small video showing your car not starting and sed it to AG along with a link of Dan's video showing the restart working properly.
    quickjack and v35 like this.
  4. v35
    v35 Karting
    May 15, 2013
    223
    Los Angeles
    Aaron
    Yes at 11.78 the motor cranked for about 3/4 of a second before it died out again. Once the battery was down to about 11.48V on a second attempt there was no cranking at all.
    RayJohns likes this.
  5. v35
    v35 Karting
    May 15, 2013
    223
    Los Angeles
    Aaron
    They agreed it’s a faulty battery and that it should never be allowed to get as low as 11.78V. They’re setting up the exchange now on a Sunday. Great customer service.
  6. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    It's a bit disconcerting when their fail safe system fails...
    I'm glad they stand behind their product, but I still say upgrade to the Braille i48CS.
    Ray
  7. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Indeed, but failures happen.
    When they do, it is imperative that it is handled swiftly and properly.
    You know I'm a big fan of Braille, and I think highly of their products. However, I cannot say that I have experienced the same level of customer care as that I have experienced with AntiGravity. A local guy had an issue with an I49CS in an FF which would not take a proper charge, and it was evident that it was the battery. It turned into a saga lasting for a month, during which we were basically told that we were idiots. Then after a few heated phone calls and a test done by someone I know in Bosch Automotive, they reluctantly took it back and sent out a new one. They still charged the guy for shipping the old back and the new out. It was 5 months old when he had an issue, and it's a 3000 Euro battery. That's just not good enough. I love their stuff and I stll think their AGM stuff is above and beyond, and I like their Lithium stuff too. But their service needs to be better, especially when you pay top price.
    I have personal experience with a few AG,batteries at this stage, and honestly it gets harder and harder for me to justify the high price of the Braille CS batteries. The technology is getting cheaper and is developing, but Braille has not adjusted pricing for years. Maybe it's time they re-evaluate things a bit.
  8. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    Having owned a number of companies myself, I definitely agree with you that customer service is often as important - if not more important - than the product or service itself.
    I've always had top notch customer service from Braille myself.
    The fact that Anti-gravity has jumped in here quickly to help resolve this situation certainly speaks highly of them as well.
    Ray
  9. v35
    v35 Karting
    May 15, 2013
    223
    Los Angeles
    Aaron
    The car started up just fine after letting it charge for an hour at 13.08V.
    I’ll run the same tests on the replacement battery and report.
    -100% SOC reading
    -0% SOC reading after leaving lights on.
    - Verify proper operation of the Re-Start fail safe.
    - Reading of the daily parasitic draw after a week or so.
  10. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Just to get you off to the best start. Charge the battery fully before you install it. It should read about 14.4 volts when at maximum charge.
    Ray Smith and v35 like this.
  11. todd cloud
    todd cloud Formula 3
    Jun 21, 2019
    1,158
    Todd
    I thought the AG battery just shut down just before reaching a voltage insufficient to crank the car. When the reset button is pressed, you have 1 start left in the battery which can the recharge while driving. Nothing more than that, but please correct me if I am mistaken.
  12. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    That could be. I'm not really sure what method they are using.
    Ray
  13. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    v35 likes this.
  14. v35
    v35 Karting
    May 15, 2013
    223
    Los Angeles
    Aaron
    I finally got a chance to install the new battery. Here are the results of the testing:
    -Battery immediately after install had a 93% SOC at 13.25V. Identical to my old battery at the same 93%.
    -Left lights and radio on. Took 2 hours 32 minutes for it to shut down.
    -0% SOC was 11.37V. (Lower than old battery at 11.78V)
    -Re-start worked successfully and started the car after a few seconds of cranking
    - Here’s where it gets interesting though. The 0% SOC still drained the battery down to 11.37V. The old battery only got down to 11.78V.
    -The new battery was able to start the car with 11.37V. The OLD battery couldn’t start the car with 11.78V.
    -I can’t conclude if it was an issue with the re-start system allowing the battery to get so low because the new one gets down even lower. I have some thoughts that the old battery was just faulty in general since it couldn’t start my car with 11.78V.
    quickjack likes this.
  15. SVCalifornia
    SVCalifornia F1 Rookie
    2,585
    Silicon Valley
    Keith
    Now attach it to a Li charger and let it charge to 100%.
    Then you can remove the charger as long as you give it a good run once a week.
    SV
    Rexcat458 and v35 like this.
  16. colonels
    colonels Formula Junior
    Aug 5, 2011
    883
    i recently installed antigrav battery and bluetooth tracker on my F12 so far so good. however it seems anyone can download the app and access my battery tracker and initiate crank/charge tests and change notifications. is there a way to restrict access to the tracker via a pin code or something similar?
  17. FerrariCognoscenti
    FerrariCognoscenti Formula 3
    Jan 19, 2021
    2,429
    East Coast
    My 458 sat at an airport parking lot for 46 days with an antigravity lithium batter. Came back and the car started as if it was sitting for just a day.
    Separately, I left my emergency flashers on for 24+ hours and it drained the battery. Car wouldn’t start. Hit the remote button for the battery, gave it enough juice and car started right up.
    FF40Man and Bas like this.
  18. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,999
    ESP
    Bas
    Frankly speaking, that's amazing. My Ranger Raptor (2021 model) was recently shipped from one side of the world to the other. Reconnected the battery, started right up, and charged it. Wanted to move it to a different spot the other day (I'm still waiting on the registration documents), battery completely dead. It was sitting maybe 3 weeks, with a traditional battery.
    To have an ''older'' car (as the 458 is right now, amazingly) sit for about twice as long and start right way says a lot!
  19. Mrpseudonym
    Mrpseudonym Formula Junior
    619
    Sydney, Australia
    I couldn’t get past this
  20. FerrariCognoscenti
    Jan 19, 2021
    2,429
    East Coast
    When I started it after 46 days, there was no delay. As soon as I turned the key everything came on normally, quickly, not a single error, hit the start button and she fired right up without any clogging or delay. The antigravity lithium battery is the real deal. I’ll never own a car without this battery ever again.
    For the starter of the thread with issues….these batteries are made in China. You probably just got a lemon. Swap it under warranty and you’ll be fine.
  21. usrodeo4
    usrodeo4 Rookie
    Jan 17, 2022
    19
    Steve
    +1 on the Braille i48CS. I'm an Aerospace/Software Engineer in the defense industry and have looked at the AG "smart" electronics/software. I personally wouldn't trust it farther than I can spit.
  22. Baptist
    Baptist Karting
    Mar 2, 2008
    78
    Cool story bro.
  23. FerrariCognoscenti
    Jan 19, 2021
    2,429
    East Coast
    It worked well for me, exactly as advertised.
    Battery lasted 46 days and the Ferrari fired right up without being on a tender and just sitting there.
    Separate occasion, battery died because I left the emergency flashers on overnight which is a massive drain. The car wouldn’t start and was dead…I pressed the button on the Antigravity key fob, the cars electronics turned on, I hit the start button and it fired right up.
    The AG batters are excellent and their technology is a marvel that worked as advertised for me.
    The OP simply got a lemon and should exchange it under warranty and not look back.
    quickjack, Need4Spd and Baptist like this.
  24. ruey220
    ruey220 Formula Junior
    316
    Sf bay area
    RM
    Has anyone had issues with ag batteries? It's worked fine in my ferrari and lambo for 3 years but I have one in my track bmw car and I just had two dead batteries
    One they replaced under warranty, the second In less than 8 months while completely disconnected it went completely dead for no reason
    I emailed them again just to ask if there's a known defect with the model I had and they never responded back.
  25. TheGaucho
    TheGaucho Karting
    Oct 21, 2020
    54
    SergeFurRE
    I purchased an AG battery, and let it run out on purpose to see if the restart button would work. It worked just as advertised. Nobody mentioned it here, but it's also a very easy way to shed about 30 pounds from the car. You need to buy a LOT of carbon fiber to get an equivalent weight savings.
    quickjack and Thecadster like this.
