any aftermarket stuff / Improvements ?? | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by madturk, Nov 18, 2003.
  1. madturk
    madturk Formula 3
    1,508
    Williston, ND
    Seyhan Kilincci
    Did any of you guys add / change stuff in your cars other then wheels, and exaust.
    Pictures??
    Anyone ???? Anything????
  2. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    Well, on my euro carb 308, i did the following.
    custom dual exhaust
    electromotive ignition
    nick scianna krank vents
    deep sump oil pan system
    SI Clutch
    16 inch wheels
    cd player
    coolant overflow tank
    borgo hi comp pistons
    tinted windows
    drilled aluminum pedals
    steering column spacer
  3. madturk
    madturk Formula 3
    1,508
    Williston, ND
    Seyhan Kilincci
    Electromotive ignition ???? What exactly is that?
  4. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    an ignition system that uses no moving parts to control spark - instead uses a microporcessor that receives its trigger from a wheel mounted to the CRANKSHAFT, so throw away the distributors, caps and rotors.
    also known as a direct fire ignition system - many new cars have them.
    you can adjust the timing advance using potientiometers, and it also fires on the exhaust stroke making for an efficient burn.
  5. WILLIAM H
    WILLIAM H Three Time F1 World Champ
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    Check my car in my profile, its a 512TR race car, full roll cage, fuel cell, Motec ignition w digital dash, F50 brakes, no mufflers, took almost 1,000 # off the car & it now has 470 hp, looking for 600 hp soon. Is that enough ? :)
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,802
    The twilight zone
    There is very little left on my car that has not been changed.
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,802
    The twilight zone
    A few GTO parts, an intercooled supercharger (around 600 hp +/-), carbon-carbon clutch (in a couple more days), Ohlins shocks/springs, programable EFI, direct fire ignition, Stereo, ....
    There are a few other guys who post here with way cool mods to their cars.
