any architect or contractors??? Header Help | FerrariChat
Discussion in 'Other Off Topic Forum' started by darkalley, Dec 11, 2006.
  1. darkalley
    darkalley Formula Junior
    Aug 17, 2004
    826
    Jim
    I'm trying to figure out the size of a header I need to use. I'm putting in a set of french doors on an exterior wall of my summer cabin. Rough opening will be 82 Inches across. This is a one story A-frame with a loft area on the second floor with no dormers. The doors will be on the "long side" of the building-vs the "A" side" if you know what i mean. Am I fine with a 2x6 header? Right now, the floor joists from the second floor sit on this wall (double 2x4's on the top of the walls).
  2. UroTrash
    Jan 20, 2004
    40,613
    Purgatory
    Clifford Gunboat
    Bearing wall?
    82 inches, I'd use double 2x12s. Seriously.
  3. Glassman
    Glassman F1 World Champ
    2 x 6 Header is fine. Even less if no building inspector is expected.
  4. darkalley
    Aug 17, 2004
    826
    Jim
    I have room for a 2x6 header for sure. This is load bearing for the roof-remember this is the front of the house with only one floor. Roof joists and attic/loft floor sit on the wall.
  5. Dubai Vol
    Dubai Vol Formula 3
    Aug 12, 2005
    1,418
    back in Dubai
    Scot Danner
    Architect? they draw pretty buildings, then engineers have to figure out how to stop them falling down.
    Simple enough calculation: figure 100 pounds per square foot of loft, plus 100 pounds per square foot of roof, to get the total load on your walls. Divide that by the total length of the load-bearing walls (to be on the safe side I'd call the "A" walls non-load bearing.) Now you have a load in pounds per foot. Multiply by 7 to get the load on that header. Once you've done that you can figure what size to make it. Or post your calcs here and I'll take a stab at it.
    Don't forget that the posts on either side of that header have to take all that extra weight too, so plan to beef them up, and brace them. Columns fail by buckling.
  6. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    Not really. I do my own engineering. To the original poster, how long are the bearing members from the second floor? Let me know and I'll run you a beamcheck data page that will accurately size the header. Also, what grade of wood will you use? SYP or DF/L #2? If you don't know, where in the country will this be installed? As a guess I would say double 2x8 will be sufficient, but more info needed.
    BT
  7. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    So its a regular 2x4 frammed wall with a double top sill of 2x4's, 8' high??
    Personally, I'd go with the largest dimension you can get in there. If the wall is 8' high, the french door must be 6'-8" leaving a rough opening of 82"x82"? That leaves you with 14" from the top of the RO to the bottom of the doubled up 2x4 top sills.
    If you are cramped for space (wires, etc, ?) I'd try to at least get (2) 7-1/4" LVL's nailed and glued in there. Similar would be (2) 2x8" dimensional lumber with a section of 3/4" plywood sandwiched in between nailed and glued.
    If you are not cramped for space go as big as you can (2) 11-7/8" LVL,s, or (2) 2x12's with the 3/4' ply...sure, that's overkill, but you dont want to ever have to go back in and fix it do you?
    If you have the access, why not do it so you don't have to worry about it.
  8. David_S
    David_S F1 World Champ
    11,260
    Mountains of WNC...
    David S.
    That's the way I'd do it - you're talking about $75 out the door for a pre-nailed/glued double LVL cut to your spec. Well worth it for peace of mind!
  9. UroTrash
    Jan 20, 2004
    40,613
    Purgatory
    Clifford Gunboat
    Exactly. I bet the price difference in using 2x8 vs 2x12 would be less than 10 bucks.
    Addendum. I checked, the price difference for 2 of each is $4.00 total.
  10. Glassman
    you are probably right, but my framing experience comes largely from work on my own home where you are lucky to be able to sqeeze in a couple of 2x4 and still have any head room.
  11. darkalley
    Aug 17, 2004
    826
    Jim
    Sounds good. I'll go that route. I guess it is better to go bigger than smaller...
  12. Tony91505
    Tony91505 Formula Junior
    Apr 13, 2005
    424
    So cal
    Tony
    the rule of thumb for headers is 4X4 material up to 4 feet, 4X6 up to 6 feet and 4X8 up to 8 feet in width and so forth usually this covers most cases with some overkill for live and dead loads in most seismic zones including zone 4. the preferred lumber in load bearing walls should be struc1 DF perhaps best in KD form.
    good luck
  13. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,394
    Dumpster Fire #31
    SMG
    2-2x6 = (roof only load) 4'-6' span: (one story load) 4' span
    2-2x8 = (roof only load) 6'-8' span: (one story load) 4'-6' span
    2-2x10 = (roof only load) 8'-10' span: (one story load) 6'-8' span: (two story load) 4'-6' span
    2-2x12 = (roof only load) 10'-12' span: (one story load) 8'-10' span: (two story load) 6'-8' span
    if you're using the upper loft area above for live loads i'd err to the 2nd story load approach. and use 2-2x12's
