News
Any Ferrari Mechanics in Vegas ?
Discussion in 'Arizona & New Mexico' started by 1Turbo, May 6, 2005.
  1. 1Turbo
    1Turbo Formula Junior
    Jan 26, 2005
    670
    LA$ VEGA$
    Jimmy K
    I received some Quotes from Penske/WYNN & they are too "HIGH" IMO.
    I'd appreciate any recommendations from "Lost Wages" Locals.
    I have no Problem with Factory Trained Independents looking for some side Work.
    PM me, if you don't feel comfortable posting on this Thread.
    Thanks.
  3. de993
    de993 Formula Junior
    Sep 10, 2004
    415
    Las Vegas, NV
    The best in town is Italy Service. That is where we all go. They are reasonable and very knowlegable. John or Oscar. 2407 Highland Dr 702-382-5008
  4. TURBOQV
    TURBOQV Formula Junior
    Mar 6, 2003
    838
    NV and Socal
    All?
    I take my Ferraris somewhere else now.
  5. 1Turbo
    Jan 26, 2005
    670
    LA$ VEGA$
    Jimmy K
    Thanks for the Advice.
  6. de993
    Sep 10, 2004
    415
    Las Vegas, NV
    Sorry, didn't mean to generalize. It's just that everyone that I know with a Ferrari takes theirs to them.
  8. TURBOQV
    Mar 6, 2003
    838
    NV and Socal
    No worries.
    I like the idea of fixed pricing for majors and unscheduled maintenance items.
    I was quoted $2500 to fix two oil leaks over there. The service times schedule indicates 6 hours to do the job, not 25.
    I know they WERE the only game in town until now, but 25 hours?
    PLEASE!
  9. bobleb
    bobleb Formula 3
    Mar 9, 2004
    1,244
    Las Vegas, NV
    Bob Lebenson
    Paul - I'm really not taking sides here, but isn't your 308 pretty drastically modified? Could that be the cause of the difference between the service schedule and the times you were quoted?
  10. TURBOQV
    Mar 6, 2003
    838
    NV and Socal
    yes it is modified, but that has nothing to do with changing shift shaft seals and cam seals as quoted by John at $2500. I can get the whole major done for nearly that. i AM NOT THE ONLY PERSON WITH THIS OPINION AS WELL BOB.
    NO THANKS
    THIS IS WHAT I PAY FOR A MAJOR.
    *30,000 mile (MAJOR) Service for 308 QV = $2995.00
    {Documentation of every Major Service comes complete with a full write-up, pictures, and all receipts for your records}
    -Replace Spark Plugs (NGK or Bosch)
    -Replace Timing Belts and Tensioner Bearings
    -Replace Cam Seals and Housing O-Rings
    -Replace Valve Cover Gaskets
    -Replace Distributor Seals and Housing Gaskets
    -Replace Distributor Cap Gaskets
    -Replace Cam End Cover Gaskets
    -Replace Air Filter
    -Replace Fuel Filter(s)
    -Replace A/C Belt
    -Replace Alternator / Water Pump Belt
    -Adjust Valves (where applicable)
    -Torque Cam Journals
    -Torque Heads (check only)
    -Set Timing
    -Bleed Brake Lines
    -Change Oil and New Filter
    -Change Transaxle Gear Fluid
    -Replace Coolant
    -Inspection/Service of Air Conditioning System (recharge "R12" extra on 308's/348's but "R134" is included on F355's)
    -Inspect all Lines (fuel, oil, water) and replace if necessary (extra charge for parts)
    -Check of Lambda System and Bosch Fuel Injection System (make adjustments if necessary)
    -Clean Engine Compartment
    -Pressurize Coolant System, check for leaks
    -Inspect CV Boots
    -Inspect Fuse Panel
    -Inspect Tires / Adj. Tire pressure
    {The items below are inspected and advised to the customer at no charge. If any item(s) require service, the customer will be advised of the cost.
  11. bobleb
    bobleb Formula 3
    Mar 9, 2004
    1,244
    Las Vegas, NV
    Bob Lebenson
    Paul - Like I said, I wasn't taking sides, just asking a question.
  13. 308930G
    308930G Rookie
    Nov 25, 2003
    4
    Turboqv, Where in Las Vegas do you take your Ferrari now?
    thanks
  14. TURBOQV
    Mar 6, 2003
    838
    NV and Socal
    a very logical question.
    Thank You.
  15. TURBOQV
    Mar 6, 2003
    838
    NV and Socal
    It goes to CA for service.
    Cheers
