Any hints on steering wheel removal? | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Ak Jim, Feb 16, 2012.
  1. Ak Jim
    Ak Jim F1 Veteran
    9,621
    North Pole AK
    I need to do some work on the multi function steering wheel stalk switch. Is there any hints or secrets I need to know or do. I have a three jaw puller and the special socket, any other special tools required? Thanks.
  2. ricar116
    ricar116 Formula Junior
    Aug 2, 2005
    409
    Bolivar, Missouri
    Rick Carr
    Sounds like you have it covered
  3. hoverland
    hoverland Formula Junior
    Aug 14, 2010
    265
    Norway
    Harald Ø
    +1
    And take care not to rip off horn wire, it snags easily when steering wheel is moved aft.
    Harald
  4. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    Also, if I recall..keep track of that small column locking pin that fits in the keyed slot. It might just fall on the floor without you noticing until your ready to re-asseemble. Jq.
  5. Ak Jim
    Ak Jim F1 Veteran
    9,621
    North Pole AK
    Thanks for the hints. I'll take it apart on Monday and let you know how it went.
  6. vespasian
    vespasian Karting
    Nov 28, 2011
    55
    Germany
    Alex
    If you don't mind ... could you take a couple of photos from the process and the tools? Would be very helpful!
  7. Steve Magnusson
    26,796
    This is more a general note about using a puller (and you may need the eared type, to bolt into the hub holes, rather than jaw type if the back of the hub doesn't have a sharp corner for the jaw ends to grab), but, if it's stubborn, don't just crank on the puller's threaded screw 'til something breaks -- tighten up the puller, and give a (light) rap to the back end of the puller's threaded screw with a hammer, re-tighten, re-rap, re-tighten, etc....
  8. new ulm 400i
    new ulm 400i Karting
    Sep 1, 2007
    117
    Taipei, Taiwan
    Lee Atkinson
    ...I think the hard part is getting off the ring nut. Anybody know where to get the socket ? I completely buggered mine up thru the process, I'd be embarrassed to show the pics...Lee
  9. Steve Magnusson
    26,796
  10. ricar116
    Aug 2, 2005
    409
    Bolivar, Missouri
    Rick Carr
    My best price was from Hill inclusive of shipping and got it in 3 days from the UK.
