any repair for a flopping sun visor for 575 | FerrariChat
Discussion in '456/550/575' started by DM1, Mar 9, 2007.
  1. DM1
    DM1 Formula 3
    Nov 9, 2006
    1,041
    Southwest
    DM
    anyone know of a fix for a sun visor that will NOT stay up? Dealer needs 6 to 8 weeks and about $800. Its for the passanger side of my 02 575 Black with white stiching
  2. chris marsh
    chris marsh F1 Veteran
    5,742
    Detroit
    Chris Marsh
    I've had good luck with some cars, removing the visor and roughing up the shaft with some coarse sand paper. Run the sandpaper lengthwise down the shaft to create lines that run perpendicular to the visor movement.
    Although on my 308 I have yet to dtermine how to get the visor off of the shaft.
  3. MordaloMVD
    MordaloMVD F1 Rookie
    Sep 7, 2005
    4,222
    WA
    Michael von Ditter
    I have the same problem with my 04. Dealer is replacing it. In the meantime I am using the old coat hanger and electrical tape trick. :)
  4. 575M-Nero
    575M-Nero Formula Junior
    Feb 25, 2006
    524
    Dealer replaced mine to fix.
  5. Dr_ferrari
    Dr_ferrari Formula 3
    Nov 2, 2003
    1,071
    Pocono Sportscar
    Jim McGee
    You do not have to replace the visor. the hinge on the right side has a tendency to break in half inside the visor. You can purchace just the hinge and I do not believe it is expensive. not too hard to replace either, worst part is removing the broken piece from the visor. I have repaired three myself.
    check with your dealer. If they cannot find, e-mail me and I will get you the part number and cost.
    best regards, Jim
  6. MordaloMVD
    Sep 7, 2005
    4,222
    WA
    Michael von Ditter
    Ok, I give. How do you get the visor off of the rod without tearing the electrical wire for the mirror? Can you post the part number and cost?
  7. Dr_ferrari
    Nov 2, 2003
    1,071
    Pocono Sportscar
    Jim McGee
    the new part comes with the new wiring. you have to remove the visor and unplug it from the roof harness, then you remove the visor mirror and unplug the wiring and remove the wire harness and remaining damaged hinge. you then feed in the new harness and follow with the new hinge.
    plug in the harness to the visor mirror and reinstall.
    I will get the part number tomorrow and post.
    best regards, Jim
  8. Dr_ferrari
    Nov 2, 2003
    1,071
    Pocono Sportscar
    Jim McGee
    Part number is 65195800
    I believe about 117.00 +/- check with dean.
    dean at wwc can get it : 845-425-2600
    regards, Jim
    rycol8184 likes this.
  9. DM1
    DM1 Formula 3
    Nov 9, 2006
    1,041
    Southwest
    DM
    Jim
    Thanks for the info on the sun visor. I ordered the part and got my fixed. Dealer didn't know that you can order just the hinge. But now they do. Hope they pass on the info to other customers so they don't order a new visor just because the hinge is flopping. Anyway Thanks Again.
  10. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    The dealer has the parts book and he didn't know this?
    No wonder the dealer parts business is so good!
  11. DM1
    DM1 Formula 3
    Nov 9, 2006
    1,041
    Southwest
    DM
    The parts dep. was very surprised when I gave them the part number.
  12. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    I believe that and the fact that they were surprised you figured a way not to get fleeced!
    Good going.
    Maybe you should be their ad"visor"!!!
  13. DM1
    DM1 Formula 3
    Nov 9, 2006
    1,041
    Southwest
    DM
    To my surprise, I have to give them credit. They did change out the hinge for me for free.
  14. Qksilver
    Qksilver F1 Rookie
    4,534
    PC, UT
    Joe
    I'm going to go with some black electrical tape around the bar that the visor snaps into. Should do the trick.
  15. DM1
    DM1 Formula 3
    Nov 9, 2006
    1,041
    Southwest
    DM
    I think the hinge is only about $90.00 and it will look original.
  16. 575M-Nero
    Feb 25, 2006
    524
    Thx for the info!
    Didn't complain too much since they replaced one under warranty.
    Will be great to have the fix/part number in case it fails off warranty.
  17. Schultzois
    Schultzois Formula Junior
    Jun 22, 2004
    879
    Hey Jim, good to see you here (since I don't get to see you in person any more). Did you just come up with this one, or is there another reason you never did this on mine! :D My '01 550's passenger visor's been falling down since '03 now, and I'm actually worried the driver's side is getting a little loose!
    I moved the car to CA for now, otherwise I'd just come and have you do it (but it'd be a long drive, and besides I'm in France now and spend most of my time in Argentina... so it'd be even harder...)
  18. dsd
    dsd F1 Rookie
    Nov 19, 2006
    4,253
    Northern Virginia
    Well my passenger visor has this problem and I have the replacement piece thanks to Ricambi and this thread :)
    However, I cannot seem to get the broken part out. Any tricks?
    Thanks,
    dsd
  19. ferrarioldman
    ferrarioldman Formula 3
    Professional Ferrari Technician Silver Subscribed
    Jun 19, 2002
    1,032
    Summerfield, NC
    Tom Jones
    I just replaced one this week. I used a 5/16 drill bit to break up the inner plastic piece. You have to be care not to catch the leather. There is a flat metal spring inside the hole so when it alaigns with the flat on the plastic hinge, it holds it in place. I used a very very light coat of grease on the plastic part that slips inside the visor. Worked great.
  20. Ricambi America
    Sponsor Owner
    The fix pieces are pretty cheap.... but depends on the year/assembly of the car, and whether you need right or left side visor bits.
    The plastic hooks in the middle of the windscreen (near the rearview mirror) is 65196000
    The parts that ferrarioldman is referring to (above) are:
    Passenger side: 65195800 (until assembly 28973)
    Passenger side: 65513000 (from assembly 28974)
    Drivers side: 65195900 (until assembly 28973)
    Drivers side: 65508000 (from assembly 28974)
  21. fredwf
    fredwf Rookie
    Oct 13, 2007
    8
    Sarasota, Fl
    Fred W Fiala
    I fixed my sun visor by installing the factory replacement part. Not an easy job. I will help anyone do the job and impart my experience. It takes a lot of work and some sewing skills, but it can be done with prior help. Calcutating the hours, if a mechanic did it, $800 for a new one more or less for a new one would not be far off. But with some instruction, you can probably do it in about 4 hours if you can sew and can find the tread to match. I would be happy to give instructions. fred
