Any split CV boot sources for 355?... | FerrariChat
Discussion in '348/355' started by cladd2000, Sep 5, 2011.
  1. cladd2000
    cladd2000 Formula Junior
    519
    Just realized that both of my outers are torn.
  2. cuneo
    cuneo Formula 3
    2,484
    #2 cuneo, Sep 5, 2011
    Porsche 944 or 968 boots fit, don't recall exactly but search and you'll find it. Ricambi is pretty affordable, that's where I got mine.
  3. f355spider
    f355spider F1 World Champ
    18,055
  4. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #4 2NA, Sep 5, 2011
    I think you're looking for the split-type boot that is available for VW swing axle cars.
    Because the axle shafts on the 355 rotate rather fast and are continuously flexing around their entire diameter.(VW axle tubes do not rotate and only flex up & down) the split-type boot would probably not work very well.
    If only it was so simple. ;)
  5. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    If they are ripped, I would take the time to clean and re-pack the bearings. Yes, it's a horribly messy job, but relatively easy. Go to Auto Zone and buy a $10.00 bearing packer, it saves a lot of hassle. Do a search, there are several great threads on this subject.
  6. The Outcast
    The Outcast Formula 3
    Apr 19, 2011
    1,562
    Royal Oak Michigan
    Don't F355's have sealed bearings? Mine does...not to worry, though; replacement bearings are about $100.00 each.
  7. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Not on the half shafts
  8. tashier
    tashier Formula Junior
    Sep 8, 2008
    573
    Oregon
    Sean
    #8 tashier, Sep 6, 2011
    I've done this job. It's not too bad. After R&Ring the engine and transmission on two separate occasions, I was glad to 'only' be doing the CV boots.
    And just get the boot kit from Ricambi, it's affordable.
  9. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    You only need one kit also. The boots are the same in and out, so you can use both where you need.
    The official ones aren't very expensive, so this is one I would just stay with the OEM parts.
  10. cladd2000
    519
    $200.00?
  11. Frode
    Frode Rookie
    Sep 11, 2009
    26
    Seattle, WA
    Frode
  12. cladd2000
    519
  13. gus355
    gus355 Formula Junior
    Aug 3, 2011
    569
    B.C. and WA
    I think J.Salmon just said they are same in and out.
