Any tips for how to remove dovel when timing Mondial T | FerrariChat
Discussion in 'Technical Q&A' started by nicce12, May 19, 2023.
Tags:
  1. nicce12
    nicce12 Karting
    May 22, 2013
    76
    Stockholm, Sweden
    Niclas Olovsson
    Hello,
    I am in the process of doing a major on my Mondal T, on of the cams are a bit of from the assembly marks and I am trying to move the dovel so I can adjust the cam to the assembly mark (and the degreeing the cams etc). I have so far failed to remove the dovel, any good tips on tools or procedure to get the pesky little bugger out? Funny thing was that I adjusted another cam and that dovel could easily be picked out with a vice grip,,,
    Thanks, Niclas
  2. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Sometimes spraying it with penetration oil. Then gently rock the pulley will give you clearance .
    nicce12 and wmuno like this.
  3. wmuno
    wmuno Formula Junior
    522
    Wilmette, Illinois
    Bill Muno
    After applying the penetrating oil, heat the pulley with a heat gun. Several cycles might be necessary to free the pin.
    nicce12 likes this.
  4. nicce12
    nicce12 Karting
    May 22, 2013
    76
    Stockholm, Sweden
    Niclas Olovsson
    I was eyeing the torch in the corner of my eye, will attemt not to burn down something important... Thanks!
    wmuno likes this.
  5. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,952
    The Cold North
    Tom
    Remove the cam..knock the pin out from behind.
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    Remove the cam pulley, knock it out from behind, get a set of Testarossa dowel pins. They have threaded holes in the middle and you can insert a bolt, a tool, to pull it out when you are doing cam timing.
    The look of the pulley means it has not been service in a while. Clean it up, run a 6mm drill bit (it's metric) into the holes to clean those up so they don't stick. Buy a small flat cutter (that cuts 90 degrees to the plan of the handles), grind the tips down to fit behind the edge of the dowel pins and use that as your pin puller tool.
    @fatbillybob claims he has a method that knocks these pins loose everytime.
  7. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
