Any way to provide more space between gas and brake pedal/308? | FerrariChat
Discussion in '308/328' started by greg328, Nov 23, 2004.
  1. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    My size 13's are finding it a very tight fit.......
  2. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Spacing is controlled by spacers on the pivot bar above the pedals. You can cut the spacers to move the pedal but you'll need to modify the brake light switch with a smaller tab on the brake pedal. It is a fair amount of disassembly to take the pedal box out, remove the roll pin, pull the pivot bar, cut the spacers, weld a tab and reassemble, but it can be done (I did mine for another purpose). You may also be able to heat and bend the brake pedal arm but you'd want to pull it either way.
    HTH
    Philip
  3. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Thanks..... I might just have to carry some driving mocs in the car, but what a hassle....
  4. Dom
    Dom F1 Veteran
    Nov 5, 2002
    8,489
    I believe ultimate pedals.com provides aluminum pedals that are smaller than the factory setup. This should give you more space.
    Dom
  5. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    thanks Dom. I'll check that out!
