anybody know a good way to get sap off car? | Page 2 | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by ross, Sep 5, 2006.
  1. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Right, there must have been "something" about the bags I got from the Hotel that caused the blotches.
    I use a lot of poly pastic sheating in consruction work, for things like vapor barriers, floor/dust protection, etc and the stuff you get from home centers doesn't have any film/oil/etc on them, but the whole experience with the blotches have scared me off from plastic as a whole.
  2. luigibosco
    luigibosco Karting
    Jan 28, 2005
    202
    Westchester County NY
    rubbing alcohol
  3. iceburns288
    iceburns288 Formula 3
    Jun 19, 2004
    2,116
    Bay Area, CA
    Charles M.
    I heard magic acid works pretty well...
  4. Rachane
    Rachane Formula 3
    Sep 5, 2005
    1,086
    San Francisco, CA
    Rachane
    "ResistAll" is one of the professionally-applied sealants. This was on my XLR-V when I got it, and the car's surface is extremely slick. Haven't tested it with sap yet, however!
    http://www.ctpc.com
  5. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,622
    Gates Mills, Ohio
    Jon
    You park your Testarossa under big pine trees?
    Sap and bird droppings are death to paint - I had a Honda where a bird dropping left on for 1 day left a permanent burn spot in the paint.
    I would absolutely get a car cover, no question about it. I know it's a pain, but sheesh...
    (I'm sitting here in pain thinking of a TR living the life of an old beater...)
  6. 38 Off
    38 Off Karting
    Nov 4, 2003
    248
    Pace, FL
    Phil Crain
    A detailer/paint shop told me about this years ago. Works great, use gently, apply wax to area, done.
  7. cavallino33
    cavallino33 Formula Junior
    Jul 10, 2005
    559
    Campbell, CA
    Jeff
  8. junkyarddog
    junkyarddog Formula Junior
    May 18, 2006
    353
    Palatka, FL
    Kelly Lake
    I have always used HOT soapy water. I will hurt you but not the car.
  9. luv2detail
    luv2detail Formula 3
    2,289
    North Carolina & SoCal
    Jason
    Isopropyl alcohol (IPA), a solvent, or turpentine, which is made from tree resins, in severe cases it can be used to break down the resin in tree sap, use as a last resort only and use sparingly and do not rub hard and give it some time to work or use detailer’s clay. Once you remove the sap deposits, the paint or clear may be cracked, which may entail some expensive refinishing. Factors as to the amount of time it takes to remove sap and what damage it has caused are dependent on temperature and time the sap has been on the paint surface. Be careful and take your time removing it, remember always let the products do the work for you.
    Tree sap that is still soft can be removed by soaking with Isopropyl Alcohol (or Stoner’s Terminator) wet the area with the product and allows it to remain on the surface for 3-5 minutes, then wipe with soft dry towel. For tree sap that has hardened, carefully scrape the top of the spot off with a plastic razor blade to expose the softer sap inside.
    Apply Zaino’s ZPC Fusion with a foam applicator and then remove residue or soak a towel with the solvent placing it over the sap and let soak for 10-minutes, repeat in order for the solvents to break down the sap, once it’s removed re-apply sealant / wax protection of your choice. If the paint has been etched the surface can be levelled with a suitable polish and then apply a paint protection
    Insect honeydew (sometimes mistaken for tree resin(Sap) is excreted by aphids or scale insects that infest the leaves and branches Sticky residue should be removed as soon as possible as it could compromise the clear coat. Remove as per tree sap
    Notes:
    a) Use caution if you use WD-40 for sap removal, as it contains hydrocarbon solvents, which may compromise the integrity of the clear coat causing it to occlude (clouding or yellowing).
    b) Avoid using a QD spray to flush residue, as they contain either carnauba wax or polymer sealants, which will seal the acid and not allow it to dissipate. Using an alkaline rinse of baking soda and water (to neutralize the acid) as soon as is practical is highly recommended, if the affected paintwork is not neutralized any remaining acid residue will be reactivated.
    c) If the paint or glass surface has been etched the surface can be levelled with a suitable polish, then apply a paint protection.
  10. Doug_S
    Doug_S Formula Junior
    Apr 8, 2007
    450
    NJ
    Doug
    I got some tree sap on my car while attending a party. I didn't even notice it. Later I see these clear bumps. I thought it was hardened sap over the paint.
    I took it to a detail shop and they said sap causes the pigment to blister into the clearcoat. The bumps are under the clearcoat in the paint.
    I'm very upset. At least I got some advice before trying to rub/solvant off the sap.
    The detailer said that wet sanding could take it out but he recommended not doing it as it is minor. To my eyes the former perfect paint has blisters and blemishes and dots of raised pigment. Man everytime I take my car out something bad goes on.
    I'm still in the "drive it it is a car camp" (in fact I ended its low milage already). Still when people say chips and dings can be fixed, I feel like tree sap must be avoided at all cost because it damages more so. Wish I knew before. Anyone know if wet sanding is a good solution.
  11. BigTex
    79,418
    Houston, Texas
    Bubba
    I have high hell prints in my hood and never even saw the chick......
  12. Hutch360
    Hutch360 Karting
    Jan 29, 2006
    121
    Shell Beach, Ca
    Steven Hutcherson
    Yup, the only permanent way to remove that sap from your car is with a chainsaw.
  13. Patek
    Patek Formula 3
    Mar 24, 2006
    1,908
    John Milton
    The Clay bar will do the trick like magic.
    Just be sure to bring it back with wax. The bar will strip the wax , but will in no way hurt the car. I use it all the time.
  14. Doug_S
    Apr 8, 2007
    450
    NJ
    Doug
    I know I posted to an old thread -did a search on tree sap- but what I wanted to say was not how to remove it, but if you park under a tree and do not inspect your car and remove sap it will ruin your paint. Mine has bubbles and it is not sap. Seems very serious.
    Yesterday I washed my car and parked it for a few minutes under a tree while cleaning up and when i got into the garage there were lots of sap splotches. I got all I could but in the garage under a single bulb it is hard to find every one.
  15. testarob
    testarob F1 Rookie
    May 13, 2006
    2,504
    Debary, Florida
    Rob
    Hell prints????
  16. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    You have covered all my ideas. Bug & Tar. Goof Off.
    Get a lockable car cover that breathes and doesn't take up much room to store in the trunk. Worth every penny. Thick, heavy covers suck.
    Put your red Ferrari cover on first, then the waterproof cover to prevent tiny scratches.
    It's a dirty world out there and we are at war. But it is a war that we can and must win.
  17. PSP
    PSP Formula Junior
    Mar 31, 2001
    603
    Lake Forest, CA USA
    Patrick S. Perry
    FWIW, gasoline takes it off immediately - just be prepared to wash and wax right away.
  18. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    i've got it off with duct tape. use the sticky side and lift it off.
  19. otaku
    otaku Formula 3
    Aug 12, 2005
    1,391
    Boise,Idaho
    Josh
    WD40 lol
  20. Ed_Long
    Ed_Long Formula Junior
    Nov 11, 2003
    686
    Salem, Oregon USA
    Ed Long
    Ross:
    My wife's advice is to use olive oil. Gentle on the paint, dissolves the sap, wipe it off. Seems appropriate for an Italian car, don't you agree?
    Ed
  21. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,524
    Dumpster Fire #31
    SMG
    having kids I stumbled into this one, baby wipes! I've yet to find something they don't clean. amazing stuff and cheap, well if your not buying them daily :)
