Anyone adjust their parking brake? | FerrariChat
Discussion in '456/550/575' started by Salami, Dec 26, 2020.
  1. Salami
    Salami Karting
    Oct 31, 2020
    219
    Oregon
    Mine seems a few clicks too slack.
  2. Qavion
    Qavion F1 World Champ
    14,269
    Ian Riddell
  3. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
    Or just like everyone else just leave it in gear
  4. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    I adjusted mine on the cable and it really helped.
  5. Salami
    Salami Karting
    Oct 31, 2020
    219
    Oregon
    Oh god the dreaded drum-in-hat parking brake. The Bain of my existence. I once sold a truck because of that design.
  6. tazandjan
    39,163
    Anybody who had an old drum brake Corvette (C1) or Chevy can use that star wheel adjustment in their sleep. Do that first like the WSM says and then adjust the cable. Lock it up with the star wheel and then back it off the minimum number of clicks that completely frees up the disc.
    Salami, F456M and Qavion like this.
  7. Salami
    Salami Karting
    Oct 31, 2020
    219
    Oregon
    Cool thx. Yeah I live on a hill and noticed it’s barely adequate at max travel.
  8. Salami
    Salami Karting
    Oct 31, 2020
    219
    Oregon
    I’m not familiar with corvette star wheels but I’ve used many star wheels in other vehicles.
  9. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    Typically the parking brake shoes wear more than the parking brake cable stretches. I always adjust the parking brake shoes first. You have to raise the car and remove the rear wheels to access the star wheel adjusters. There is a hole in the outer part of the brake rotor hat. Look where the parking brake cable enters the brake backing plate and the star wheel adjuster will be 180 degrees from the cable entry point .
    Carefully turn the adjusters so that they cause the parking brake shoes to move outward. The starwheel adjusters are not made of steel, more like brass or some kind of pot-metal, so it is very easy to break the teeth off of them if you pry on them too hard. They will bind up if you tighten or loosen them to their limit of adjustment.
    I make sure that I am rotating them the correct direction by watching them with a small flashlight until they just stop moving and contact the inside of the brake rotor, then I back them off three teeth.
    I then check the parking brake lever, it should stop at 4-5 clicks, if not then the cable needs adjustment. If the car has sat for a long time, there will be corrosion on the parking brake surfaces, so you can clean it off by pre-burnishing the shoes and discs. I drive the car very slowly 5-10MPH and apply the parking brake to clean off the shoes/discs.
    Brian Brown
    San Francisco Motorsports
  10. colorfull
    colorfull Formula 3
    2,333
    Franklin Park, New Jersey
    John Napoli
    Brian,
    Thank you @Motob for that detailed explanation, I have an F430 with rear discs, my cable turnbuckle fully engulfs the screws threads) and my pads are almost full.
    Would you (or anyone) happen to know how to perform similar on discs?
    Thank you!
  11. tazandjan
    39,163
