430 - Anyone bled their ABS valves while bleeding their brakes? | Page 2 | FerrariChat
430 Anyone bled their ABS valves while bleeding their brakes?
Discussion in '360/430' started by Extreme1, Feb 13, 2024.
  1. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,387
    Santa Clarita, CA
    Thinking about it more, wouldn’t the fresh fluid have to be flowing through the brake lines, then turn the key on?
  2. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,755
    England
    Mark
    You may find that you need to use the diag bleed if the abs module has been removed. The trapped air can be stubborn.
  3. mferrari43
    mferrari43 Karting
    Jan 23, 2022
    127
    California
    Matthew Ferrari
    anybody find any answers on this? i rebuilt all my brake calipers and have trapped air that's really hard to get out. I've bled everything 2 times (without a tool to activate the ABS) and the brake pedal still goes to the floor. i also have an x431 launch and it has options for abs bleed on a 355 and 430 but no 360 (wtf). anybody know of another tool or method to get this air out of the system?
  4. imahorse
    imahorse F1 Rookie
    4,282
    WI
    Dustin
    Are you doing the back bleeder too?
    I have a gravel driveway so I just locked up the wheels a few times and rebled it.
    mferrari43 likes this.
  5. mferrari43
    mferrari43 Karting
    Jan 23, 2022
    127
    California
    Matthew Ferrari
    Ya i have been bleeding both nipples on each caliper separately one at a time, could this be an issue or no? I would totally try the gravel method but i’m honestly scared to back it out of the driveway like this lol
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,706
    Central NJ
    Dominick
    Are you using a motive bleeder ?
  7. mferrari43
    mferrari43 Karting
    Jan 23, 2022
    127
    California
    Matthew Ferrari
  8. imahorse
    imahorse F1 Rookie
    4,282
    WI
    Dustin
    Having air in the abs unit will cause some sponginess, but won't be to the point that there is next to no pressure. Either you still have air in other places or something isn't working properly.
  9. Scottslaw
    Scottslaw Formula Junior
    Just as a data point, a few years ago I removed all four calipers, left fluid in the (capped lines), rebuilt them all and refinshed them, reinstalled, and bled with a motive (filled up method). I had zero issues with air or spongey pedal etc... So something else may be going on (and no, I didn't use a scanner to open any valves). Just thought I would share this in case you thought that the job was impossible without a diag tool. In my case it was not.
