Anyone changed their headers themselves with the engine in? | FerrariChat
Discussion in '348/355' started by Shootfighter65, Jan 7, 2015.
  1. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,372
    Charleston SC
    Randy..alluneedtokno
    Thinking of tackling this myself while it's put up for winter. Any tricks tips I should know?
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Car in the air as high as you can get it.
    Wheels off.
    Inner wheel well lining out.
    You may need to loosen a few things like the oil tank to get a little extra room.
    Remove cats.
    Unscrew retaining nuts.
    Some Cirdu du Soleil of the headers, a few choice cuss words, and out they come.
  3. Eric C
    Eric C F1 World Champ
    11,136
    St. Louis, MO
    Eric
    My back aches just thinking about it.
  4. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    Lol guys. I will do it at my friends shop with help from one of his guys. That should ease some pain. Can you get it all from underneath?
  5. Eric C
    11,136
    St. Louis, MO
    Eric
    Wait, I thought you said heads. Oops. Ha.
  6. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    Headers lol.
  7. amg55
    amg55 Karting
    Mar 12, 2013
    103
    Car being just a few feet off ground was fine for me I sat in the fender well on a chair comfortably and loosened everything. Also didn't touch cats to remove, just loosen all flanges on that side. Also take off axle heat shields 2 10mm nuts or you will smash them.
    Right side is fun because fan must be removed and big oil cooler hose moved to the side. Easy work with a big wrench for that fitting its huge.
    I recommend offset 13mm 12pt box wrench for tops and long extension with a flex joint 13 for bottom 4 bolts.
  8. F355Bob
    F355Bob Formula 3
    I did mine last summer. You need to remove all liners, remove oil lines. and I needed to loosen the engine mounts and raise the engine two or three inches. I also removed both fans. Was pretty easy, but took awhile because your body is not in a comfortable position if you do not have a hoist. I got the Snap On wrench that someone recommended on FChat and that helped get the header bolts off.
  9. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    Time? what is the wrench? I want to buy it if my friends shop doesnt have one
  10. cavallo95
    cavallo95 Formula Junior
    Jan 23, 2007
    272
    chicago
    I just cut the right side out , it was easier then removing lotsa stuff, fabspeeds fit in no problem.
  11. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Classic Coach charged me $800 labor to install my headers and change a CV boot and I have a lift. I did the cats myself but i think you need to choose your battles.
  12. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    I am not sure what you mean...curious
  13. F355Bob
    F355Bob Formula 3
    I changed mine over course of a week, working a little each day. I would say it took 7-8 hours and that is with the car on jack stands. Mine is a Snap On 13mm FHOM13B
  14. F355steve
    F355steve Formula 3
    Apr 9, 2008
    2,089
    Honolulu - Seattle - Okinawa
    Steve
    I did mine on jackstands with nothing special but the 13mm snapon wrench mentioned above. Get the wrench.
  15. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    Shoot me a pic
  16. cavallo95
    Jan 23, 2007
    272
    chicago
    #16 cavallo95, Jan 8, 2015
    I could not get my rite one out ,not enough clearance, so i decided to cut the right one in half and pulled it out that way since they where trash anyway ,but I was very careful with surrounding part, fabspeed headers are much smaller getting them in was a breez, just need some long extensions, worked pretty well for me.
  17. cavallo95
    Jan 23, 2007
    272
    chicago
    I could not get my rite one out ,not enough clearance, so decided to cut it right one in half and pulled it out that way since they where trash anyway ,but I was very careful with surrounding part, fabspeed headers are much smaaller getting them in was a breez, just need some long extensions, worked pretty well for me.
  18. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    can someone shoot me a pic of the wrench I need?
  19. F355steve
    F355steve Formula 3
    Apr 9, 2008
    2,089
    Steve
    It's in my garage, at home. Someone must have a picture handy of it.
  20. F355Bob
    F355Bob Formula 3
    Just go to the SnapOn web site enter FHOM13B and there is a picture
  21. amg55
    amg55 Karting
    Mar 12, 2013
    103
    This is an easy diy job, all header bolts cooperate as long as your car hasn't been abused. Mine appear to be never removed, so from a 1998 car (97 build date) the bolts were not rotted A little pb blaster goes a long way.
  22. F355steve
    F355steve Formula 3
    Apr 9, 2008
    2,089
    Steve
    Snap-on
    Boom, that is it. You need it because the pivot point is narrow. A rachet is to fat to fit in the tight spaces. You need it because it neck can sit at a greater than 90 degree angle, which you will be using it as such. It is also long and narrow which helps with leverage.
  23. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    Thanks...
  24. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    We did goth's at FBB's on a lift about 5 feet up. Take ur time, no biggie. Fender liners out. Pass side oil reservoir disconnected for some wiggle room. Think we removed at least one cooling fan, not sure which side - maybe drivers - could have been both.
  25. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    I used a small socket metric set plus hand wrenches to remove all the header nuts.
    This takes a little time due to the tight area you have to work in ....especially the right side beside the oil tank.
    I removed both fans (not really necessary on the left side) to open up the clearance.
    On the right side I removed the oil tank mounting bolts to provide a little wiggle play.
    The left oem header is removed with a right angle twist and out it comes.
    The right oem header feels like it does not want to come out but it will (with out any cutting)....again just turn it 45 degrees and slide it out (this is where removing the fan makes a difference....that little extra clearance lets the header slide out).
    Time to remove? with wheel, inner fender liners, loosen catalytic convertors (left loose-didnot remove from car)....going at leisurely pace probably took an 2.5 hours in total.
    The re install is much easier.
