Anyone Else Had Problems with 360 Dash Leather? | FerrariChat
Discussion in '360/430' started by Aldo360, Dec 30, 2018.
  1. Aldo360
    Aldo360 Rookie
    Dec 1, 2018
    15
    Aldo Benato
    My 360 has various bubbles in the dash under the leather like the glue has worn out there.People have told me that this is common.I was hoping to hear from other people about their experience and how they fix this.I was thinking to re cover the dash with leather but finding the right leather would be hard ,it is better just to fix it.I had visons of injecting glue with a syring into the buble areas and then leaving it pressed down but I am no pro on dashboards
  2. jackgt
    jackgt Formula Junior
    Jan 27, 2015
    574
    california
    Jack
    My dash was tight in some spots. If I am not going to use the 360 for a period of time I put leatherique on by pouring in the dash and spreading it with my hand. The only part that is not perfect is around the piece above the inst cluster. I have heard you can steam it?
  3. Skidkid
    Skidkid F1 Veteran
    9,547
    Campbell, CA
    John Zornes
    Common issue but not easy to fix. The foam under the leather is disintegrating, not the glue. The only fix is to remove the dash and have it redone. There are a bunch of threads on here some are very detailed with photos.
    docf and Dave rocks like this.
  4. I'm 360 Canuck
    I'm 360 Canuck Formula 3
    Nov 21, 2015
    1,911
    Ontario, The Real One in Canada
    Lars!
    It sure would be nice if someone came up with a very fluid glue that can be injected into spots with a medical style syringe small enough that the hole would be barely noticeable.
    I count myself as lucky...although my car originated in Cali, it’s spent most of its life in Canada, so if this issue is sun related, it hasn’t been exposed as much.
  5. Aldo360
    Aldo360 Rookie
    Dec 1, 2018
    15
    Aldo Benato
    Ok, but this sounds like if the foam is weak and broken then reconditioning the leather will not be the answer, it will just be more beautiful LOOSE leather.
    To save money I could inject some glue but I think it would look ugly after.Maybe re upholster the dash with suede or alcantra and make it Stradale style.
    How sad because the leather is like new, few miles on those dead cows
  6. Graz
    Graz Formula 3
    Oct 15, 2012
    2,329
    New Jersey and Florida
    Graziano
    I had to have a bubble repaired on my 360. It’s the foam that degenerates under the leather. Would recommend highly that you have it professionally repaired. Not sure where you’re located but I had mine done at Coachtrim in Danbury CT. He was able to use the existing leather. Excellent work. Check the vents too. Sometimes the fasteners for them break and the vents stick up.
    I'm 360 Canuck likes this.
  7. bball16
    bball16 F1 Rookie
    4,134
    NY LI FtL
    It's a big job. It requires the removal of the whole dash to have it redone. When I had my 360 the first sign of trouble was when the defroster vents popped up and warped. After reading what was involved and the cost I traded for a 430 lol. My recollection was about $4k to do the job properly.
  8. SCKOMS
    SCKOMS F1 Rookie
    3,903
    Lake County, IL
    Spiro
  9. EZORED
    EZORED Formula 3
    1,034
    Scottsdale, AZ
    Dennis
    Part of the problem with the shrinking dash leather is that only the glue holds it in place, and the weak point is the foam which disintegrates with age and heat. The only mechanical attachment to the dash is the cheap plastic vents at the base of the windshield. My solution was to order 2 aluminum vent replacements from a forum member down under . Next I R&R the dash. It was a 2 day project one day out and 1 day in. The Aluminum pieces bolt thru the dash holding it in place and thus do not allow the leather to shrink.! I did pay an upholster $750 to stretch the leather back and install the aluminum vents. 2 years later, my dash still looks good. At the same time my air bag was becoming wavy also, I just carefully pulled the leather back, clean off and re glued. One of the reasons I went this route was that my cars dash was a special order and the dash matched the Cuio interior instead of black. My upholster said it is going to be impossible to match and the best solution if that was a problem for me was to change it to black. A non starter for me and big bucks!!
  10. rizzo308
    rizzo308 F1 Rookie
    2,781
    Perth, Australia
    riggio
    whatheheck and EZORED like this.
  11. EZORED
    EZORED Formula 3
    1,034
    Scottsdale, AZ
    Dennis
    Thanks Rizzo! that the man!!!
  12. SCKOMS
    SCKOMS F1 Rookie
    3,903
    Lake County, IL
    Spiro
    Definitely a must! I had the front part of my 430 dash recovered and had Rizzo308's vents installed. The tech was very impressed with them and they look great!
    Sent from my Galaxy
  13. docf
    docf Formula 3
    Sep 14, 2008
    1,422
    Florida
    Gary
    100% correct as to the problem being the foam. Most will note decayed foam at times in the foot wells. If the dash leather like you said is good a professional should be able to handle it. These cars are at the youngest 14-15 yrs old. Foam will decay with age obviously.
  14. unreelviper
    unreelviper Karting
    Jan 9, 2014
    179
    DMV
    I too used Rizzo's alloy vents on my F430. I have not had one problem with his vents or the leather on the dash after it was redone. Fortunately for me, I had a friend who took the dash out for me( money saver).
  15. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    On some 360's & F430's I've seen the issue appears to be leather shrinkage around the area by the front dash vents.
    It appears the dashboard leather was neglected and never seen any leather conditioner ever............
    I highly recommend applying leather conditioner on the dashboard on a regular basis.
    Dan
  16. KWK6531
    KWK6531 Rookie
    May 15, 2004
    11
  17. KWK6531
    KWK6531 Rookie
    May 15, 2004
    11
    I tried to DM you.
    How much for the vents and shipping time to Florida USA?
  18. jackgt
    Jan 27, 2015
    574
    california
    Jack
    #19 jackgt, Jan 4, 2019
    I got some, they are perfect and will not warp--
    I read what works and what does not. I have more time than lots of money, and every year my dash lays down better. The leather is still there but dried up. Some spots like the rear quarters that get a lot of sun were like cardboard. Now the leather is thicker and pliable. In the west we do not know what rust is but the interiors suffer and you just have to take care of them EVERY YEAR.
  19. Skidkid
    Skidkid F1 Veteran
    9,547
    Campbell, CA
    John Zornes
    I had a set as well and they look nice. A couple of suggestion would be:
    1) The holes are through holes. They should either be countersunk for a flathead or a allen bolt so that the bolts sit flush with the top and not above. Heck, you could include a set of bolts that fit as well and it would make for a very finished product.
