Anyone else have thermostat housing leak issues? | FerrariChat
Discussion in 'Technical Q&A' started by JohnMH, Dec 21, 2024.
  1. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,795
    Bologna
    I have replaced the thermostat seals twice on my 91 TR in order to try to cure a persistent leak, in both cases they leaked around the seal between the two halves of the housing when I started the car.
    The original seal was larger profile and square, part no. 4184495. The part it has been superseded with is 105192, which is smaller in thickness and barely protrudes from the lower half of the thermostat housing. FWIW, the housing is straight and undamaged.
    Anyone else have this issue?
  2. fatbillybob
    Aug 10, 2002
    28,796
    socal
    I have on 550 T-stat housing but not in TR. It seems like sourced o-rings today don't stand proud enough to make a good seal. It's like there was a metric SAE conversion issue and the part is just not quite right. It's almost like re-using the old o-ring is a better choice. I can't remember my exact fix. I either coated the o-ring in silicone RTV or loctite 518 case sealant and then replaced the cover and that solved the leak by just thickening up the o-ring a bit with the goop. I tend to hate RTV and most likely used 518.
  3. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,795
    Bologna
    I think I will look for some nos original type seals. I don’t have the originals anymore and don’t like the idea of sealant.
  4. Rifledriver
    36,928
    4184495 is not a Ferrari part number that I can tell. I just looked at my 85 TR parts book and it shows 105192 being the original number and goes back to the early 70's.and is the same number for all TR, TR512 and M's. I have never had a problem with a housing leak. Are the thermostats correct? Could they be interfering?
  5. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,795
    Bologna
    Eurospares shows 4184495 as a superseded part, with 105192 as the replacement. When I search for a photo of 4184495 online I find a photo of similar seal which has a rectangular cross section and seems slightly taller (which would solve my problem). The thermostats are OEM Ferrari, bought from the dealer in Modena. They fit and operate perfectly, but the seal does not protrude sufficiently from the top of the case. I changed the timing belts in 2021 when my seals were changed and the problem arose. My engine is out again for another reason so I am just trying to solve it. It is not a huge leak, just an irritating, persistent drip every few seconds.
    My choices are either to find a pair of 4184495 seals (difficult, but not impossible) or try to get the top of the seal to emerge from the case, either by installing an o ring below, or by putting a bead of sealant on top (but what sealant?). Opening the thermostat housing when the engine is in is not much fun.
  6. EDoug
    EDoug Formula Junior
    Apr 19, 2005
    261
    Southern Florida
    John, I recently used 105192 from Ricambi without any issues on my 1986 Testarossa. EDoug
  7. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,795
    Bologna
    It is quite odd. Maybe the groove in which my seal sits is extra deep on my car? I have owned it for 16 years, swapped thermostats at every belt change and have only experienced this issue recently with the new style seals.
    To eliminate variables, I extracted the housing, removed the studs and checked both the top and bottom cases for flatness, they were perfect. The shop manual lacks a torque spec for the 10mm nuts which hold the cases together but as it is a 6mm stud, I use 10Nm in a crosswise pattern.
    I am thinking of removing the assembly again and sealing the top and bottom cases with Henkel 510 (no 518 available here). In the longer term I will look for some of the original seals.
  8. Rifledriver
    36,928
  9. EDoug
    Apr 19, 2005
    261
    Southern Florida
    John, this is what the groove in my 1986 thermostat housing looks like for comparison. EDoug
  10. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,795
    Bologna
    Exactly what mine looks like. The standard seal (105192) did not leak?
    I sealed mine with a thin bead of Loctite 510. Once it has cured I will refill the system and see if it holds coolant.
  11. fdekeu
    fdekeu Formula Junior
    630
    Belzium
    Frank
    Loctite 510 if applied well will work
    Overkill to change thermostats every time
    Changed mine after 30 yrs because the temp started to drop below 85°C
    The rectangular seal is probably an X-ring
  12. Rifledriver
    36,928
    My 90 still has its original thermostats.
  13. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,795
    Bologna
    I swap them out when I am in there, only because they are no fun to reach with the engine in place.
    The Loctite 510 worked perfectly, so I can finish the car now.
    fdekeu likes this.
  14. F450_TONY
    F450_TONY Rookie
    4
    Edinburgh
    Tony Brighton
    Guess the newer seal might not be making a proper seal due to the thinner profile. Have you tried using a sealant or gasket maker with the new part to ensure a tighter fit? It could help compensate for the size difference. Also, double-check the torque specs on the housing bolts—sometimes uneven pressure can cause leaks around the seal.
