Anyone else pulled their dashboard dimmer apart? | FerrariChat
Discussion in 'LamborghiniChat.com' started by dinonz308, May 9, 2025.
  1. dinonz308
    dinonz308 Formula Junior
    Nov 26, 2017
    869
    Dean
    Because, that's a natural thing to do I guess :)
    I wanted to see if I could use the potentiometer in some sort of pulse width modulated circuit so I could use the original item to dim LEDs - but to my surprise, when I pulled the one I have apart, it looks like it is already a PWM circuit.
    Or do I have a modern replacement for the old original? In which case I want more!
  2. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,064
    Switzerland
    Raymond S.
    I simply bridged this Reostat since the dashboard lights were anyway too dark, that increased the brightness easily by 10% or more.
  3. dinonz308
    Nov 26, 2017
    869
    Dean
    I was looking to install LEDs, and was hoping to use the same rheostat but mine appears to have a circuitboard with a 555 timer IC and a Mosfet to handle the power drawn - or at least the replacement dimmer I have does.
  4. dinonz308
    Nov 26, 2017
    869
    Dean
    @raymondQV Do you happen to know which of the pins at the back are 12V, ground and then is the output tied to ground or 12V?
  5. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,064
    Switzerland
    Raymond S.
    Sorry cant remember but that should be easy to find out.
