Anyone else using dexron VI for F1 fluid | FerrariChat
Discussion in '360/430' started by MalibuGuy, Feb 11, 2011.
  1. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,860
    Decided to change my F1 fluid from Shell Donax which I believe is a dextrin class III to Dexron class VI.
    Noticed that the shifts were smoother and more responsive.
    Maybe it was my imagination but I had noticed before that there was sometimes a slight lag when pulling the paddle and getting the shift.
    Also I had observed a flicker of the F1 warning light when the system was cold and automatically downshifting from 3-2 when decelerating. This flicker of the F1 warning light has disappeared for now at least.
    I think the 6 is a significant improvement
  2. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    #2 Juri, Feb 12, 2011
    I am using FormulaShell ATF, which is Dexron III / Mercon. You can get it at any Shell gas station.
  3. MalibuGuy
    Sep 18, 2007
    5,860
    Hi Juri-
    I also checked my power steering fluid. I had it changed last year and the technician said it was pretty dark almost black. To my surprise it had turned very dark again.
    I decided to use the Dexron VI. Drove the car last night and the steering system seems smoother and quiet.
    My opinion is Dexron VI is better. According to GM it is holds up much better in terms of resistance to degradation from heat over time compared to Dexron III.
  4. tazandjan
    39,084
    MG- My car has Valvoline synthetic power steering fluid in ithe power steering and that works great. Unfortunately, I think they stopped making it. The VI may make a good substitute. Still running the Fiat Tutella CS in the F1 system. Hard to find, though.
    Taz
    Terry Phillips
  5. Skidkid
    Skidkid F1 Veteran
    9,500
    Campbell, CA
    John Zornes
    I am running VI in the steering but haven't change the F1 yet. That is on my list of things to do but brakes are first.
  6. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    #6 Juri, Feb 12, 2011
    You are correct that Dexron VI withstands high temperature better than Dexron III. However, are you sure that it is compatible with the rubber and plastic gaskets inside the hydraulic pump and actuator?
    I am asking this question, because had a bad experience with my own car... When I purchased my car in CA, somebody had added conventional power steering fluid to the reservoir, which I did not know at the time. a month later, I started hearing the sqeeling noise, which typically happens on older cars when the power steering fluid level is low or the pump is giving up... In any case, I had to change the whole fluid to find that somebody screwed up by adding all kind of wrong fluids into the system...
    As you know, there are special synthetic hydraulic fluids available on the market (i.e., Pentosyn CHF11S and CHF202) used in different German-made cars (VW, Porsche, etc.), but I am not sure if those would be safe to use instead.
    The recommended original fluid (oil) for power steering is Shell Donax TA (see attached product specifications and MSDS sheet in PDF), which can be purchased for about $20-25/canister (1 Liter each) from different petroleum/oil suppliers.
  7. JoshECS
    JoshECS Formula Junior
    433
    Ashburn,VA
    Josh Hill
    Pentosin CHF-11s is a suitable and easy to get substitute for the Tutela. I've found CarQuest keeps it on the shelf.
    I don't recall anything good coming from putting ATF in the F1 system though. I had to flush a Maserati out a couple weeks ago that had that stuff in it. The ATF was causing a lot of strange things to happen.
  8. djantlive
    djantlive Formula 3
    Jun 30, 2005
    1,015
    tutella for me. it gets pretty hot and no reason to run cheap fluids
  9. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    Any suggestions to where to purchase Tutella from?
  10. MalibuGuy
    Sep 18, 2007
    5,860
    For me it wasnt about cost but about using the best fluids for the F1 System.
    So I agree with you.
    Tutella, I believe is is Dexron III fluid. Dexron VI is superior to III according to GM. GM formulated both the Dexron III and VI.
    Well I will post again about my experience after more miles ;)
  11. MalibuGuy
    Sep 18, 2007
    5,860
    #11 MalibuGuy, Feb 12, 2011
    Well I put in the fully synthetic Valvoline Dexron VI in both my F-1 and Power steering system. I will keep ya posted if I have any problems. I doubt it though. According to GM, the VI is backwards compatible with applications using the III. However, one should not use the older dexron 3 fluid in a new car which specifies dexron 6 fluids. I think this is due to the longer change intervals which dexron 6 confers (100,000 miles for transmission)
  12. tazandjan
    39,084
    #12 tazandjan, Feb 12, 2011
    Josh, MG- Interesting and will look forward to the results.
    Here is a spec sheet on the Pentosin CHF-11S. Specced on many power steering systems (Volvo, VW) because it operates fine down to -40 C (-40 F also, coincidentally the temperature where F = C, X=1.8X+32, -0.8X=32, X=-40F/C)
    Taz
    Terry Phillips
  13. Skidkid
    Skidkid F1 Veteran
    9,500
    Campbell, CA
    John Zornes
    GM quit licensing the Dexron III name several years ago. You will see lots of stuff that is Dexron III compatible but they can't sell as Dexron III. GM marched along updating the spec (higher requirements) and collecting new licensing fees. Dexron VI has a much better viscosity profile and a much higher shear strength. Overall a higher spec fluid that III.
    Even though IV was out when the 360 was you won't find anything saying it is OK because they don't go through certification testing again for a given part. BUT GM requires that they be backward compatible so you can use any newer spec fluid.
    I too used a fully synthetic fluid for my steering. No problems so far and it has been over a year.
  14. MalibuGuy
    Sep 18, 2007
    5,860
    #14 MalibuGuy, Feb 12, 2011
    FYI Here are the specs per Valvoline.
    Product Information A PRODUCT OF ASHLAND CONSUMER MARKETS, A DIVISION OF ASHLAND INC.
    Valvoline DEXRON®-VI ATF
    Valvoline DEXRON®-VI ATF (automatic transmission fluid) is formulated with premium synthetic base stocks and
    advanced additive technology, and meets all the stringent requirements of General Motors' DEXRON®-VI
    specification*, which is designed for the modern automatic transmissions in GM vehicles. Valvoline DEXRON®-VI
    ATF is officially licensed with GM and can be used in new and old GM automatic transmissions. It is fully backserviceable
    and can be used wherever DEXRON®-II and/or DEXRON®-III are recommended.
    * DEXRON® is a registered trademark of General Motors Corporation.
    The Valvoline DEXRON®-VI ATF Advantages:
    • Provides consistent shift performance for new and old GM transmissions
    • Extends transmission fluid life and prevents fluid breakdown at higher operating temperatures
    • Provides excellent oxidative stability under severe conditions
    • Reduces sludge and varnish build-up
    • Protects transmission gears and allows them to operate smoothly
    • Maintains lubricity
    • Flows well for cold start-up
    • Thoroughly field tested
    Approvals
    DEXRON®-VI
    Exceeds the latest performance requirements of DEXRON®-III, DEXRON®-II
    Meets the performance requirements of Allison C-4
    Test Method Typical Property
    Viscosity @ 100°C ASTM D445 6.0 cSt
    Viscosity @ 40°C ASTM D445 29.5 cSt
    Viscosity Index ASTM D2270 155
    Cold Crank Simulation @ -30°C ASTM D5293 2,900 cP
    Brookfield Viscosity @ -40°C ASTM D2983 12,500 cP
    Pour Point ASTM D5949/5950/6892 -48 °C / -54 °F
    Density @ 15°C ASTM D4052 0.848 g/cm³ / 7.08 lb/gal
    Flash Point ASTM D92 208 °C / 406 °F
    Color ASTM D1500 7.0
    Appearance Visual Red
    Sulfur ASTM D4951 1620 ppm
    Phosphorus ASTM D4951 190 ppm
    Effective Date:
  15. tazandjan
    39,084
    #15 tazandjan, Feb 12, 2011
    The 599 recommended fluid for both the power steering and the F1 system is Shell Donax TX, which seems to indicate both systems work fine with synthetic ATF fluid, which is a Dexron III equivalent fluid. The Dexron VI should be an improvement and the Dexron VI backward compatibility with II and III indicates no problem with seals. Guess you will know pretty soon, but it does not seem like there will be an issue. Here are the specs on Donax TX.
    My car has Valvoline oil, PS fluid, and anti-freeeze, so I am very comfortable with their excellent and widely available products. Since their synthetic PS fluid is NLA, I will probably be stuck with Dexron VI next time.
    Taz
    Terry Phillips
  16. MalibuGuy
    Sep 18, 2007
    5,860
    The Vavolene 6 has slightly better kinematic viscosity at 100 and 40C
    compared to the Shell products. Add to this superior heat durability and I think a good case is made to run the 6 for the F1 system.
  17. alex360S
    alex360S Formula Junior
    Oct 30, 2006
    324
    Montreal, Quebec
    Alex
    Could someone please explain how to go about changing the F1 fluid without dealing with bleeding procedures.
  18. tazandjan
    39,084
    Alex- The smart thing to do is just to suck the old fluid out and add new fluid to the tank. Let us see if we get any pros on here with a different idea on how to do it better.
    Taz
    Terry Phillips
  19. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    #19 Juri, Feb 14, 2011
    First, read this post:
    http://www.ferrarichat.com/forum/showthread.php?t=268458&highlight=clutch+sensor&page=2
    It is possible to flush the whole F1 hydraulic system using an auxiliary 12V (8 A/h) battery connected to the electric contacts of the F1 pump electric motor:
    1) turn off the main battery switch
    2) disconnect the F1 pump electric motor connector
    3) open the bleeding valve #1 (shown below)
    4) connect an auxiliary 12V battery to the contacts of the F1 pump electric motor and activate it
    5) keep adding the new hydraulic fluid into the reservoir (make sure that the fluid level never drops below 1/4 in the reservoir and no air is aspirated into the system !!!)
    6) flush through the system about 0.5L of hydraulic fluid
    7) stop the pump and close the bleeding valve #1
    8) open bleeding valve #2 and repeat the procedure described above
    9) there is a third bleeding valve indicated as #22 in the diagram (below); one should perform bleeding procedures through that valve as well.
    10) fill up 3/4 of the F1 reservoir with a new hydraulic fluid
    11) reconnect the electric connector of the F1 pump motor with the harness
    12) turn on the main battery switch
    13) drive the car while frequently shifting gears for 15-20 min.
    14) repeat the procedures listed above 3-4 times to maximize the exchange of hydraulic fluid in all EV lines (hydraulic tubes going from the F1 power unit to the hydraulic gear shifter)
    As with the SD3-mediated purge procedure, there will be some residual old hydraulic fluid contaminating the new one, which is OK...
    If you have any questions, let me know.
  20. MalibuGuy
    Sep 18, 2007
    5,860
    Nice detailed post Juri.
    I changed my fluid the easier way. Using a glass syringe, I sucked out the old fluid from the reservoir and filled with the new fluid. Then I drove the car shifting gears quite a bit. Next I removed all the fluid again and re-filled with new fluid. I figure this is a pretty good fluid change.
  21. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    #21 Juri, Feb 14, 2011
    I may be wrong, but your approach will most likely result in an exchange of only about 20% of the fluid at a time, because most of the fluid is inside the lines past the power distribution unit with solenoids and pressure accumulator. The most important thing is to change the fluid inside the EV lines (marked 7, 8, 9, 10, and 11 in the schema shown below). There is not much circulation of the hydraulic fluid through the EV lines in general, which means that changing fluid in the F1 reservoir can not ensure that the fluid inside the EV lines will be effectively changed to a new one...
  22. MalibuGuy
    Sep 18, 2007
    5,860
    Thanks Juri. I will go ahead and do a few more changes over a few weeks. It is very quick only takes a few minutes anyway and I have plenty of fresh fluid.
  23. fengpi
    fengpi Rookie
    Jul 14, 2010
    15
    I'm going to flush my F1 fluid.
    Any suggestions what is the best to use.
    Someone once suggested to me Redline ATF.
    Any thoughts?
  24. Patrick 360
    Patrick 360 Rookie
    Jul 21, 2019
    16
    Summerfield NC
    Patrick
    I have also heard of some guys using Redline products but not sure which one(s) to use. For the F1 system they have D4 ATF which meets DEXRON II and DEXRON III specs. Then they have D6 ATF which meets DEXRON VI specs. As for the Power steering system, they have those 2 fluids and their own Power Steering Fluid. I am wondering if D4 ATF would be the fluid to use in both? Any suggestions?
  25. tazandjan
    39,084
    Patrick- You will eventually get an answer if you keep asking. Ricambi sells Tutella CS, now rebranded, but it is $50/liter. I still use it since it is specifically designed for Selespeed applications (F1).You only need a liter every 3 years when doing complete fluid changes and bleeding, but we swap out half of mine every year to keep it fresh, so use a bit more.
    I use Valvoline Dexron VI in my power steering.
