Anyone ever use an aftermarket clutch for F430 F1? | FerrariChat
Discussion in 'Technical Q&A' started by Snapshift, Sep 8, 2022.
  1. Snapshift
    Snapshift Formula Junior
    930
    Centralia IL
    Lyle D. Pahnke
    I'm coming up on a F1 clutch change and was wondering if there was any collective experience on using a compatible aftermarket clutch rather than OEM.$$$ I know there is nothing wrong with OEM and it probably is the best option, but there are so many aftermarket options that seem very well engineered and are 2-3 thousand dollars cheaper. If one were able to use an aftermarket clutch, would the position sensor, calibration etc even be usable for F1. If not, that decides that. Or possibly are these aftermarket clutches only for manual gated 3 pedal cars?
    As an example, the one that I like is a stage one SPEC organic single plate
    https://specclutch.com/applications/ferrari-f430/?car_year=2005&type=14845
    There may be others. Thanks for any input that you might share. This is the big undertaking for sure and I am looking for the best options if there are any.
  2. Circle K
    Circle K Karting
    Dec 21, 2017
    154
    KC
    F1 and gated uses the same clutch. I’d go the aftermarket, as long as it’s from a reputable company like Sachs(not sure if they make Ferrari clutches) who makes for Porsche
  3. Island Guy
    Island Guy Karting
    Feb 20, 2020
    137
    Island Guy
    OEM only....saves everyone a lot of aggravation down the road.
    George Vosburgh likes this.
  4. Flyingbrick242
    Flyingbrick242 Formula Junior
    683
    Northern AZ.
    Snapshift likes this.
  5. craze
    craze Formula 3
    Mar 5, 2021
    1,161
    Melbourne
    Michael
    I would not
    Asking for trouble now or later
    tbakowsky likes this.
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,624
    San Carlos, CA
    Mitchell Le
    When I have to split the engine / gearbox connection to get to the clutch parts, I just flat out buy the factory ones. F1 system has too many variables / sensors that rely on the exact measurement to work right. Doing it the second time is just too costly.
    tomberlin, 2NA and Snapshift like this.
  7. George Vosburgh
    George Vosburgh F1 Rookie
    I switched out the F1 relay with the Scuding Swiss unit but that's all.
  8. Circle K
    Circle K Karting
    Dec 21, 2017
    154
    KC
    not all OEM is the best, the 430 exhaust manifold is a good example
  9. craze
    craze Formula 3
    Mar 5, 2021
    1,161
    Melbourne
    Michael
    And the factory calibration isn’t designed for removal of cats unfortunately
  10. hessank
    hessank Formula 3
    1,938
    Canada, Florida
    Fred
    Not necessarily true.
    If Trev anoints it, you can. Just saying!
  11. tbakowsky
    Sep 18, 2002
    20,013
    The Cold North
    Tom
    PLEASE PLEASE...listen to me..
    DO NOT INSTALL ONE OF THOSE CLUTCHES..the car will not like it at all.
    I begged a customer not to install one..but he insisted. I should have stuck to my guns and flat out just not have done the job.
    It is the worst driving f430 I have ever experianced. Please..spend the extra and so it right. If you can't..then just sell the car.
    imahorse, Fcar tech and Snapshift like this.
  12. hessank
    hessank Formula 3
    1,938
    Canada, Florida
    Fred
    Are you specifically warning him about Organic clutches or all aftermarket ones?
    There are posts here for Kevlar ones working in the gated but not so much the F1
  13. Island Guy
    Island Guy Karting
    Feb 20, 2020
    137
    Island Guy
    The OEM clutch integrates perfectly with the F1 system. If you don't mind reduced life, poor engagement issues and constantly screwing around with parameters, then there are plenty of aftermarket alternatives for you.
    YMMV
  14. Chindit
    Chindit Formula Junior
    Oct 18, 2008
    404
    Navarre, Florida
    Nick P.
