Anyone fix the OBDII ground issue at home? | FerrariChat
Discussion in '360/430' started by big_luke, Sep 13, 2010.
  1. big_luke
    big_luke Karting
    Aug 28, 2010
    151
    My 99 360 is still not state inspected because it can't talk to the SMOG computer due to the OBDII port issue. The dealer said they will fix it for free, but will have the car for a day or two. There is also a local Ferrari specialist that will update it for around 100 bucks.
    The dealer seems like so much of a hassle for such a simple fix that can be done at home.
    What exactly needs to be grounded? From what I've heard, it's just a simple ground wire from the ECU.
  2. Skidkid
    Skidkid F1 Veteran
    9,547
    Campbell, CA
    John Zornes
    I don't have the doc at work but the dealer did it in about 10 minutes. It is a simple wire splice connector that adds another wire. Stick that pin into the the OBD socket (hole is empty) and you are done. Basically you need a little wire, a pin for the plug, and a splice connector from radio shack.
    I am sure that the document is on this forum. Do a search and you will find it.
  3. big_luke
    big_luke Karting
    Aug 28, 2010
    151
    I found a couple posts searching OBD and ground. but no specific details.
  4. chrmer3
    chrmer3 Formula 3
    May 19, 2006
    1,719
    USSA
    Chris
    I did, its a easy fix. Should be a bulletin somewhere around here explaining it..
  5. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
  6. big_luke
    big_luke Karting
    Aug 28, 2010
    151
  7. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    #7 Ingpr, Sep 13, 2010
    Always happens! I don't know what is wrong. Maybe is the iPhone.
    Try;
    www.ferraridatabase.com
    Downloads
    Manuals
    Others
    Technical service department
    Let me know if you don't find it.
  8. njcycleguy
    njcycleguy Formula Junior
    831
    Northeast
    You're kidding right? The dealer will do it for free, you'll get dealer documentation that it was completed properly, but you'd rather hack with it yourself?
  9. big_luke
    big_luke Karting
    Aug 28, 2010
    151
    some people would just rather DIY. I enjoy doing things like this.
  10. Skidkid
    Skidkid F1 Veteran
    9,547
    Campbell, CA
    John Zornes
    Get serious. This project isn't much more complicated than putting paper in a 3 ring binder.
  11. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    Lol!
  12. big_luke
    big_luke Karting
    Aug 28, 2010
    151
    I've looked all through the PDF, and still have not found the wiring diagram or instructions.
