Anyone Have a "Carpad" on Their Garage Floor? | FerrariChat
Discussion in 'Other Off Topic Forum' started by Jerrari, Nov 2, 2005.
  1. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,469
    Michigan
    Jerry Wiersma
    #1 Jerrari, Nov 2, 2005
    Just wondering if anyone has purchased one of these things (or one like it) to put on your garage floor to collect dripping snow and slop in the winter? If so, was it worth the money? Thanks, Jerry.
  2. BWS550
    BWS550 Wants to be a mod
    Apr 1, 2002
    8,933
    NEW JERSEY
    BRUCE WELLINGTON
  3. SrfCity
    SrfCity F1 World Champ
  4. modoindustries
    modoindustries Formula Junior
    316
    Bel Air, CA
    Sami C.
    No and yes,
    I thought the question waqs has anyone "CRAPED" on thier garage floor.
  5. bludevil12
    bludevil12 Formula 3
    May 12, 2004
    1,930
    Northern VA
    David L.
    CARPAD....??
  6. modoindustries
    316
    Bel Air, CA
    Sami C.
    I am not telling.
  7. DIGMAN52
    DIGMAN52 F1 Rookie
    4,094
    Dallas Texas
    Philip C
    I bought one and sent it back. I didn't like that the edges were just a hose inside the plastic, and I thought it looked crappy. The fold lines looked bad, but they might have gone away over time. I went with a race-deck floor instead and am very happy. I also bought one of the above mentioned plastic sheets ( 1 car size) and during wet seasons put it under one of the daily drivers to catch the dirty water, and then can pull it out on the drive to clean.
  8. fanatic1
    fanatic1 Guest
    Nov 1, 2003
    561
    columbus
    philip
    I never understood these things........you're spending money on this product designed to keep your garage floor clean...........why don't you buy a pad to put over the car pad to keep the car pad clean...........just kind of wierd in my book. spray out your garage once a month, end of problem.
  9. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,469
    Michigan
    Jerry Wiersma
    It's a little hard to spray water when it's 10 degrees outside.
  10. fanatic1
    fanatic1 Guest
    Nov 1, 2003
    561
    columbus
    philip
    for the price of the pad, you could probably put a hot water spigot in the garage.
  11. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,469
    Michigan
    Jerry Wiersma
    I have no drain in my floor so i have to open up the door to spray the water outside. When the temperature is that cold, it makes no difference if you can get the water out of the hose, the water will freeze right to the garage floor instantly or make the driveway into an ice rink, it is just not an option.
  12. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,599
    Gates Mills, Ohio
    Jon
    Oil and fluids can make a new concrete garage floor look bad fast. It makes the garage look scuzzy and when you go to sell your house can be a turn-off. It's much cheaper and easier to remove the covering than to re-pour your garage floor.
    I like larger area coverings better and might do my garage with those. The yellow carpads look trashy, IMO.
    Having lived in Cleveland and Chicago before moving to San Diego, I can tell you that hosing out an unheated garage in Jan-Feb-March up north is a bad and dangerous idea, as Jerry said. Ice.
