Anyone have a radar detector mirror mount? | FerrariChat
Discussion in '360/430' started by CoreyNJ, Apr 22, 2024.
  1. CoreyNJ
    CoreyNJ Formula 3 Silver Subscribed
    Apr 17, 2006
    2,476
    New Jersey Shore
    And which one do you use?
    Thanks,
    Cheers,
    Corey
  2. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,624
    San Jose
    dc
    They also make rear view mirrors that integrate the radar displays. I thought those are pretty slick.
  3. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,624
    San Jose
    dc
  4. CoreyNJ
    Apr 17, 2006
    2,476
    New Jersey Shore
  5. GogglesPisano
    GogglesPisano F1 Rookie Silver Subscribed
    Sep 13, 2022
    3,218
    East Bay, California
    Joe
    blendmount makes a few different styles. Some that clips towards the swivel part without teeth.
  6. jerbear27
    jerbear27 Formula Junior Silver Subscribed
    Jun 12, 2022
    300
    CT
    Jeremy
    I’m happy to remove the mount and see how much damage is done to the arm (aftermarket mirror tho). Let me know.
  7. CoreyNJ
    Apr 17, 2006
    2,476
    New Jersey Shore
    I think I'm considering blendmount. The next question is... Has anyone successfully powered the detector from the overhead console since it seems blendmount offers a power cable? I was going to use that for my reverse camera mirror setup, but never got around to it. Now that everyone is switching out their Becker radios, I may do the rear camera with a radio change as soon as someone figures out how to replace the startup logo on the Walmart special radio to be a Ferrari logo. That was the only thing preventing me from using a Porsche PCCM with the bezel logo "Greeked" out by a wrap.
  8. ridege55
    ridege55 Formula 3 Silver Subscribed
    May 9, 2017
    1,386
    Manhattan Beach, CA
    In both my Ferraris, I powered up the detector. One from using the mirror tap and the other from fuse box using a pig tail. Mirror tap was definitely easier and I think it comes with the Blendmount as an option.
  9. CoreyNJ
    Apr 17, 2006
    2,476
    New Jersey Shore
    So there is enough power there, great. How did you figure out which wires to use? I don't know if I trust the available wiring diagrams that are floating around the internet as it seems the wire colors may or may not match. I was thinking 1st to locate using a Multi-Meter the ground line and the figure out which lines are hot all the time and which are ignition switched.
  10. ridege55
    May 9, 2017
    1,386
    Manhattan Beach, CA
    You are exactly correct. Use a multi-meter to determine the switched hot and the ground. With the mirror tap, just push into the proper connector. I recall a thread on here where there were some detailed instructions on the wiring. Let me see if I can find it.
  11. ridege55
    May 9, 2017
    1,386
    Manhattan Beach, CA
  12. jerbear27
    Jun 12, 2022
    300
    CT
    Jeremy
  13. CoreyNJ
    Apr 17, 2006
    2,476
    New Jersey Shore
    Did you try metering out the wiring to find a key switched wire in the overhead console or did you just use the posted schematic? Mine is a 2009 so I have the same setup as you.
  14. jerbear27
    Jun 12, 2022
    300
    CT
    Jeremy
    I did not. After tripping the SRS light in the dash I wired it down to the radio.
