anyone have issues with the AC blowing warm air in a 612? | FerrariChat
Discussion in '612/599' started by ttforcefed, May 23, 2010.
  1. ttforcefed
    ttforcefed F1 World Champ
    19,257
    09, brand new, doesnt blow cold air is prob the better way to put it. Off to the dealer...
  2. donv
    donv Two Time F1 World Champ
    26,141
    Portland, Oregon
    Don
    Mine was the same way. I took it to the dealer, they recharged it, and it's been good ever since.
  3. johnaz
    johnaz Formula Junior
    Nov 16, 2009
    289
    Carefree, AZ/Anchorage, Alaska
    John Schwamm
    Mine ( 2008) blows warm for a bit always on initial start up ( several minutes at times), seems maybe the temp sensors take some time to 'find' the right temp, then it goes to cool on a/c. Not a good system for more instant reaction to what it should do from what I have found.
  4. ttforcefed
    19,257
    mine doesnt blow much cold air out at all...im going to have it recharged...otherwise i wontbe able to drive it during the NY summer...
  5. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Sounds like it wasnt charged up properly before you received it. :):)
    That, or it has a leak. :D:D
    Did the dealer sort it out for you Ricky? :):)
  6. champagne612
    champagne612 F1 Veteran
    5,725
    mine is the complete opposite - thing blows freezing cold air.
    Pap what exactly are you referencing :)
  7. ttforcefed
    19,257
    its at the dealer now...keep u guys posted
  8. champagne612
    5,725
    While the 612 is there
    Check the computer display - make sure the dimmer for the back lit goes all the way up and all the way down. If it flickers replace it now b4 wtty expires
    Check leather is tight around the A/C gauges - mine slightly lifted ofer the three humps -
    Check the headlight covers for moisture
    Last there was a recall on Pirelli tires. 90% of the recall did apply to the Scuds but 10% of the 612's have the Pirelli recall tire installed - especially the Sport Package 612's
  9. johnaz
    Nov 16, 2009
    289
    John Schwamm
    Also there was a software upgrade on a/c, so make sure you did not need it or it has been done.
