Buy
355 Anyone have this part laying around & could measure for me?
Discussion in '348/355' started by Targatime, May 19, 2021.
  1. Targatime
    Targatime Formula Junior
    334
    Los Angeles
    I haven't been able to find this in stock, and to me it looks like an incredibly easy piece to fabricate. Like 15 mins with a band saw and drill. It's the "gasket" (it looks from pics like a plastic spacer) that goes under the shifter gate. I think the only measurement I need is its exact thickness and what it's made of (plastic, rubber, something else?). Many thanks in advance if you can assist.
    https://www.ferrariparts.co.uk/part/ferrari/159389
  3. bjwhite
    bjwhite F1 Rookie
    Mar 17, 2006
    4,125
    Seattle, WA
    Brian White
    So even places who say it's in stock, it's not really in stock? Looks beveled to me and something you'd want made out of some sort of composite or plastic/nylon--not metal.
  4. Ferrarium
    Ferrarium F1 Rookie
    3,421
    Central NJ
    Eric
    Isn't it the same size as the shift gate with the same holes? Measure that? The bevel is for the shift throw angle to prevent hitting the corners.
  5. zstyle
    zstyle Formula Junior
    419
    Fountain Hills
    Jon
    Do you not have the original from your car? Very easy to take out and measure.
    Also try GT Car Parts in Phoenix, AZ. If he doesn't have a new one, he will certainly have good used ones.
  6. emac
    emac Formula Junior
    809
    upstate SC
    ernest
    That looks like it would be a good part to 3D print.
  8. Targatime
    334
    Los Angeles
    My car (right now) is an F1
    I just need the thickness, not the outside dimensions. It's literally a square piece of plastic with rounded corners and four holes drilled in it. I probably won't spend $100+ on it even if I could find one in stock somewhere. I just need to know how thick it is.
  9. zstyle
    419
    Fountain Hills
    Jon
    Ah that makes sense. If someone hasn't responded by Sunday, i'll try to remember to check mine.
  10. kenneyd
    kenneyd Formula 3
    1,450
    NE FL
    Ken
    I was able to measure it without even removing anything, fairly accurate, I'm sure it's exactly 10 mm
    Targatime likes this.
  11. Targatime
    334
    Los Angeles
  13. malex
    malex Formula 3
    1,190
    FL
    This is timely as I just replaced mine this past weekend. To those who asked . . . no, the part isn't available. I checked in the US and the UK to no avail. Was told by Ricambi, Superformance, Rutlands, and Eurospares that it's NLA.
    But as others have said, it's a super easy part to fabricate. I made mine from some black HDPE (ordered from Amazon) using the same tools that I'd use to cut/drill wood (mainly a chop saw, drill press, jigsaw, and Forstner bits). The HDPE still has a bit of give, yet is far stronger than the OEM part. My OEM piece seemed determined to return to its molecular state as the damn thing disintegrated into plastic crumbs.
    I did have to source 1/2" thick HDPE. But I also have a wood planer. So shaving off some thickness (~2-3mm) wasn't an issue.
  14. Ricambi America
    Sponsor Owner
    We have those actively in design/testing for re-manufacture. No ETA presently, but they will be available again as a reproduction (stronger!) part.
    Qavion and Targatime like this.
  15. Targatime
    334
    Los Angeles
    #12 Targatime, May 20, 2021
    What do you guys think would be an acceptable material? I don't have a wood planer unfortunately and would like to keep this simple. Does that part do anything other than act as a 10mm spacer between the shift gate and shifter housing? Could I go wrong using a 10mm thick piece of plexiglass and spray painting it black? Plexi is durable and really easy to work with.
    https://www.amazon.com/SimbaLux-Plexiglass-Transparent-Protective-Projects/dp/B084T6SXJ6/
    Edit: found a piece of black HPDE:
    https://www.amazon.com/Density-Polyethylene-Plastic-Sheet-Black/dp/B07JM6BKFX/
    Any reason to go with one over the other? I'm not a plastics specialist.
  16. kenneyd
    kenneyd Formula 3
    1,450
    NE FL
    Ken
    90% of it is not visible, so it doesn't really matter only a little bit of the inside edge.. Make it smooth and paint it black.
    However If I remember correctly, it does appear that it cushions The shifter from hitting the side when you go into reverse. I will have to double check that
  17. kenneyd
    kenneyd Formula 3
    1,450
    NE FL
    Ken
    Well I had an unexpectedly take my shifter apart while driving today lol.
    Turns out my 9-month-old brand new from ricombi shifter gasket has deteriorated as well.
    So anyway I was able to take it out and take an accurate measurement. It is 12 mm
    Targatime and Qavion like this.
  18. Targatime
    334
    Los Angeles
  19. 0.0.1.99
    0.0.1.99 Formula Junior
    Jan 14, 2012
    404
    Carolinas
    Ken
    If someone could post the complete specs, we can design it as a STL file in Blender or SketchUp. It can then be edited or printed by anyone with a printer or even uploaded to a printing service.
  20. kenneyd
    kenneyd Formula 3
    1,450
    NE FL
    Ken
    What exactly do you need?
    I just epoxied mine back together, but I'm sure it's going to break again in different spots
  21. Targatime
    334
    Los Angeles
    Ken can you add precise dimensions in mm to your sketch? All the relevant internal and external dimensions as measured with a caliper. Ken2, is that enough to create a file and print a run of parts? I am eager for this.
  22. 0.0.1.99
    Jan 14, 2012
    404
    Carolinas
    Ken
    Yeah that should be it. Just need the complete dimensions via caliper.
  23. kenneyd
    kenneyd Formula 3
    1,450
    NE FL
    Ken
    I can clarify any of the dimensions, I just did this real quick before work.
    Just note, the front and back edges are thinner on the top at only 12 mm, and thicker on the bottom at 14.5 mm. Otherwise it's relatively symmetrical
    big picture link Dimensions https://imgur.com/gallery/6NAo2xW
  24. Targatime
    334
    Los Angeles
    Hero. Thank you!
  25. emac
    emac Formula Junior
    809
    upstate SC
    ernest
    I have a formlabs 3D printer if someone can put together an STL file. I would be happy to print a run of them. I will donate the material if people would cover shipping and make a donation to Fchat :)
  26. 0.0.1.99
    Jan 14, 2012
    404
    Carolinas
    Ken
    Working on STL file now.
  27. kenneyd
    kenneyd Formula 3
    1,450
    NE FL
    Ken
    Cool! Let me know if you need any clarifications on the specifications, I know that was a really rough rough sketch lol.
  28. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    10,861
    San Carlos, CA
    Mitchell Le
    That's great. It's NLA ...
