Anyone making the Dino throttle cable bellows? | FerrariChat
Discussion in '206/246' started by 4redno, Mar 12, 2010.
  1. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,067
    Seattle, WA
    Keith Mitchell Wintraub
    #1 4redno, Mar 12, 2010
    Is anybody planning to reproduce that small rubber bellows which covers the opening of the conduit that a Dino throttle cable runs through? The bellows goes over the opening of the conduit and has a small hole on the end which the cable runs through. The bellows go in and out when the cable moves but because this piece is made of rubber and gets exposed to the elements when driving, it tends to get dry and crack.
    See the attached photo if you don't know what I'm talking about.
    Cheers,
    Keith
  2. celestialcoop
    celestialcoop Formula Junior
    715
    Coop
    Hi Keith,
    I don't know about the throttle cable application, but Dinoparts.de and Ricambi America sell clutch cable boots, which are similar in appearance. I replaced 'em on a couple of Dinos. I didn't compare them directly, but they might be a workable susbstitute. I'll dig through my used parts bin & see if I can compare one of the old clutch boots with the throttle bellows on my car. I'll let you know if we're in luck!
    www.dinoparts.de/EN/ferrari-246-gt-gts/clutch/clutch-arm-boot-rubber/
    www.ricambiamerica.com/product_info.php?products_id=188622
    My guess is that someone out there has found a better/less expensive/locally available item from a Honda, a Ford...or whatever. They will likely chime in, once they read your request. Hey, it may be raining boots & bellows before long!
    Coop
  3. racerboy9
    racerboy9 F1 Rookie
    2,645
    I have a NOS original bellows and it doesn't fit very well. Too small to fit over the tube the throttle wire exits from. My old one was split from being too small. I think finding a modern replacement that fits a little better is the way to go.
  4. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    The throttle cable boot from a Porsche 914 is what I use, might have an extra - let me dig through some boxes.
  5. dinogts
    dinogts Formula 3
    I think it's starting to rain.
  6. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,067
    Seattle, WA
    Wow, I'll have to look on line for a 914 boot. Thanks for the tip!
  7. dinogts
    dinogts Formula 3
    Keith -
    Any luck on the 914 boot?
    Mark
