Anyone revalved their oem F355 Bilstein coilovers? | FerrariChat
Discussion in '348/355' started by f355spider, Feb 7, 2011.
  1. f355spider
    f355spider F1 World Champ
    18,048
    I was talking with Steve in tech support at the West Coast office of Bilstein USA and he says for $100 a corner, they would be happy to completely rebuild the oem coilovers and revalve to a higher compression and/or rebound damping.
    I have always thought the oem shocks lack adequate rebound damping, anyone ever had this done?
  2. rydermike
    rydermike Formula Junior
    Mar 27, 2010
    416
    Spring Hill,FL
    Mike Donohue
    Might want to try RE Suspension in North Carolina . I just sent a set of Penske's for my Ex-Sprint cup car and was under $300 total including shipping back to me.
  3. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,734
    What piece of the chassis dynamics gave you this idea?
  4. Rifledriver
    37,126
    The Challenge cars used standard 355 shocks but did use the rears at both ends and changed the adjustment controller.
    If you really want to change the shocks Delta Vee is very knowledgeable about chassis tuning and does a far superior job on the Bilstiens than Bilstien does.
  5. enginefxr
    enginefxr Formula 3
    Aug 20, 2007
    1,753
    S&R Exotics
    Gary Sharpe
    +1
    I had Rob do a set for me. Very nice guy, and knows his stuff.
  6. sevminasyan
    sevminasyan Formula 3
    Jun 24, 2008
    1,156
    Glendale, CA
    Steve
    I have heard of ROB but can you refresh my memory as to how we can get in touch with him?
    Thanks much
  7. Rifledriver
    37,126
    Delta Vee/Internet website
  8. enginefxr
    enginefxr Formula 3
    Aug 20, 2007
    1,753
    S&R Exotics
    Gary Sharpe
  9. f355spider
    18,048
    #9 f355spider, Feb 8, 2011
    Mitch,
    I am not an expert, so perhaps I am using the incorrect terms, but at higher speeds, the suspension just felt more "floaty" to me...as if it lacked sufficient damping. My BMW with stock sport suspension seemed to be better damped....even more so now that I have a PSS kit installed.
    But again, I am not an expert driver, nor one that sees the track, so I may have these terms or even my diagnosis incorrect.
    I did mention this once to a friend of mine who races BMWs and Corvettes, who also owns a F355B and he was in agreement. This was a few years ago, and at that time I sent him the info on Rob at Deltavee, but my friend never did anything about it. (partly because he probably has too many cars and projects to keep track of as it is) ;)
  10. Rifledriver
    37,126
    #10 Rifledriver, Feb 8, 2011
    Common complaint of 355 drivers at speed. One reason they put rear shocks in front on Ch. We also used to adjust the nose down a little to keep more air on top and less underneath.
  11. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    My shocks may or may not need rebuilding ...... but as it is now ............ the difference between the front to rear compression and rebound on my 355 is huge! The front is soooo much softer than the rear, it doesn't take a suspension 'expert' to validate this.
    One can easily undertand why challenge cars would use rears on the front, as was stated above. That configuration may be too stiff for some on the street ........ but it makes perfect sense for track use.
  12. Rifledriver
    37,126
    Just wait until you take the same shocks and take 500 or more pounds of inertia off of them.
  13. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    I have quite a lot of experience with exactly what you are talking about, and more. I will send you a PM. I am not selling anything, just avoiding arguments.
  14. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    +1 ......... ;)!!
  15. Mitch Alsup
    Nov 4, 2003
    9,734
    There is a reason the rear end is set up on the soft side, this leaves much of the roll stiffness on the front. The stiff roll at the front causes understeer in turns and helps quell the inherent oversteer (mid-rear weight bias) and still allows for power on oversteer. The soft rear enhances rear traction under a variety of circumstances. The alternative was to use 285/35 or 295/35 rear tires with the 225/40 fronts. Those tires would not fit with the diffusers,.....
    However, this stiff front, soft rear does take a slightly different driving style than the equally stiff all around typical race car setup (easly to slide, easy to recover). In particular, it requires a deliberate and slow inputs to the steering wheel, coordinated with throttle application; so the car turns and squats at pretty much the same time. In this turn and squat attitude, it has maximum lateral acceleration capabilities.
    Back to shocks. A shock with too much compression and too little rebound will pump itself UP over bumps as the bump throws the car up and the rebound prevents it from recovering before the next bump. A shock with too little compression and too much rebound will pump itself DOWN. The shocks on my F355 (1995 with 62K miles) takes turn 2 at TWS (fairly bumpy; 90 MPH in 105 MPH out) just fine. However it did not when the ride height was incorrect (too low in the front).
    So, next time you are out with your car, and you fnd a nice long sweeping corner that has a few bumps and can be taken with verve, safely and without constabulatory influence; drive the corner and see if you sense the car is pumping up on the shocks, pumping down on the shocks, of pretty much staying the same on the shocks. Drive it as many times as you like.
  16. sunline
    sunline Karting
    Dec 23, 2004
    155
    Ashburn Virginia
    Ken
    I had Delt-Vee rebuild my shocks and it made a huge difference. my car had about 10K miles, but is a 1996 and was about 11 years old. Rob told me all the shocks he rebuilds on 355's are usually in various states of internal deterioration
  17. f355spider
    18,048
    Will do Mitch. But again, my lack of experience in such things may make my opinion of what is happening, not very accurate. I will tell you that one year ago, I did have a complete aligment, ride height and wheel balance done. Made a significant difference in ride quality and handling. I was suprised to learn my car was sitting 2cm too low in the front. Not sure why, or how that happened; or was never corrected by the dealer since it had a major service and front end work a couple times over the years...
    I've since noticed a lot of F355s sit similarly low in the front and wonder if it is common to lower them, or if the front springs are beginning to take a "set" after all these years?
  18. Mitch Alsup
    Nov 4, 2003
    9,734
    I suspect the springs at the front sag under time and under heavy braking. Mine was found to be similarly low a half dozen years ago.
    I forgot to mention earlier, that a good deal of the softness at the rear is from the springs, which, in my opinion, are pretty well damped. So, I think if you want the rear firmed up with the benefits and detriments that accompany this, the correct step is to change out the rear springs--go up about 15%-20% in the spring rate.
    {A gentleman from ?Sweeden? and I had a conversation on this from about a year ago, if my memory is still working... He went up 40% at all four corners if memory serves for a dedicated track car...}
  19. windsock
    windsock Formula 3
    1,153
    Thanks for the public slam Dave. Next time I change timing belts on a car I will be sure to ensure the cars ride height is set correctly.
  20. sevminasyan
    Jun 24, 2008
    1,156
    Glendale, CA
    Steve
    Thanks all
  21. f355spider
    18,048
    Sorry Mark,
    My comment was definitely not meant in anyway to malign FoS or the great service you folks provide...hell, if it wasn't, I wouldn't be going there! ;) Unfortunately, my post did not come out the way it was intended, and it certainly can be construed that I am bashing you guys. What I was trying to point out, is that even professionals are not always adjusting ride height when an alignment is performed, and if it is the customers concern, one should bring it up. I don't believe most shops would mess with ride height, particularly since many owners intentionally lower their cars, either for looks or track use. So the point is, one needs to ask, not assume.
  22. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    You know, I swapped my 348 fronts for 355's and I also have the car sitting a smidge (technical term?) lower than it did with the stock 348 SS versions. Think I'll go back to stock, but this gives me a place to send the 355 set for tuning.
