Anyone run nitrogen in there tires | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by ttforcefed, Oct 20, 2019.
  1. ttforcefed
    ttforcefed F1 World Champ
    18,874
  2. 4_Eff_Sake
    4_Eff_Sake Formula Junior
    Jul 30, 2016
    761
    Australia
    Scott
    I worked for a tyre retailing company for 15 years. We offered nitrogen fills. For street cars, they are relatively pointless.
  3. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,618
    Pittsburgh, PA
    Matt F
    I run 78% nitrogen in every tire of my cars.
    Matt
  4. energy88
    energy88 Two Time F1 World Champ
    27,128
    West of Fredericksburg, VA
    Boomhauer, AshAP, PhilNotHill and 2 others like this.
  5. ttforcefed
    18,874
  6. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    25,892
    DFW, Texas
    Tom C
    #6 tomc, Oct 20, 2019
    Not exactly the National Academy of Sciences, but there are some advantages per Popular Science, particularly if the N2 is dry.
    https://www.popularmechanics.com/cars/a3894/nitrogen-in-tires/
    T
    Edit...more technical, but implication is that it has some benefits. Again, assuming dry gases.
    https://www.rubberchemtechnol.org/doi/abs/10.5254/1.3548247
    https://www.tiresciencetechnology.org/doi/abs/10.2346/1.2802612
  7. energy88
    27,128
    Plus, there are advantages in aircraft tires due to the large swings in the environment encountered during a take off and landing cycle.
    tomc likes this.
  8. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Nitrogen provides a bit of consistency and improvement for fuel economy (less rolling resistance), which is probably why car manufacturers are using it (e.g. CAFE).
  9. Statler
    Statler F1 World Champ
    Jun 7, 2011
    17,389
    surely two tires filled to the same psi (one pure nitrogen and one air) have no change in rolling resistance? less fluctuation due to temps so less likely to run lower psi if you don't check regularly? ok.
  10. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Yes, all variables (people) being equal, tire pressures should remain relatively the same. ;)
    Kidding aside, nitrogen permeates the rubber less than regular air. So longer periods between refills.
  11. zygomatic
    zygomatic F1 Rookie
    4,855
    Washington, DC
    Chris
    Dryness is the only benefit for street cars. And, truthfully, it is minor - especially for cars that aren’t tracked regularly.
    The best thing you can do for your tires is keep them properly inflated.
    teak360 and EastMemphis like this.
  12. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,376
    Weston, MA
    Paul
    This.
    Unless nitrogen only costs you 10 cents per tire. Otherwise take the savings and buy your family hot fudge sundaes, you'll see greater benefit. :)
  13. I'm 360 Canuck
    I'm 360 Canuck Formula 3
    Nov 21, 2015
    1,911
    Ontario, The Real One in Canada
    Lars!
    You may need to explain that to some ;)
  14. BOKE
    BOKE Beaks' Gun Rabbi
    33,965
    600 East Fremont Street
    Lucky
    #14 BOKE, Oct 20, 2019
  15. max930
    max930 Two Time F1 World Champ
    20,425
    vancouver
    I do in my truck. Bought the tires at Costco and they use nitrogen.
  16. tuttebenne
    tuttebenne F1 Rookie
    Mar 26, 2003
    3,189
    Bay Shore, NY
    Andy
    Nitrogen doesn't seal tires from leaks it just leaks less. If you don't mind maintaining a tank of nitrogen for the top ups you will need over time, then go for it. The reduction in pressure variation due to temperature changes is a nice benefit but having to maintain a tank of nitro in the garage just for tire filling and maybe power tools isn't something I can justify.
  17. tomc
    Apr 13, 2014
    25,892
    DFW, Texas
    Tom C
    I think one of the papers above found that assertion to be untrue, at least insofar as I could tell from the abstract, but rubber chemistry isn't my technical wheel house...T
    Edit - from one of the above articles... "Use of nitrogen as the inflation gas does not benefit the measured cavity gas temperature or tire rolling resistance, both of which are shown to be tire pressure dependent, but not dependent upon the filling gas when measured at equal tire inflation pressures."
    I don't know these guys by reputation, but ExxonMobil Baytown is a top notch R&D facility...T
  18. BOKE
    33,965
    Lucky
    #18 BOKE, Oct 20, 2019
    The entire nitrogen in tires thing is BS as far as I am concerned. 99% of the nitrogen going into tires is coming out of low-end generators or concentrators that aren't even close purity-wise to what you can get from Air Gas in a welding tank.
    These generators or concentrators may have put out 95% plus pure nitrogen when new, but I doubt they are serviced as much as required to keep the purity up. How would you know what they really were putting in your tires at Costco or the tire shop anyways??? They are just selling you expensive green tire valve caps.
  19. tomc
    Apr 13, 2014
    25,892
    DFW, Texas
    Tom C
    This source says yes, less effusion. The source is getnitrogen.com, so consider the source!
    https://www.getnitrogen.org/pdf/graham.pdf
    T
    Banzairacer likes this.
  20. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Once the new car (now used) is driven off the lot CAFE no longer applies. ;)
    But here's a good paper that supports what you're saying i.e. in the real world.
    https://www.moderntiredealer.com/uploads/stats/nitrogeninflationforpassengercarandlighttrucktires-daws.pdf
    tomc likes this.
  21. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  22. JCR
    JCR F1 World Champ
    10,014
    H-Town, Tejas
    "value added" indeed...
  23. Nospinzone
    Jul 1, 2013
    7,376
    Weston, MA
    Paul
    And that's per tire! :D
    tomc likes this.
  24. tomc
    Apr 13, 2014
    25,892
    DFW, Texas
    Tom C
    Banzairacer, BOKE and EastMemphis like this.
  25. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,740
    Memphis, TN
    For all you nitrogen loving folks, please bid on the bridge I'm putting up for sale in Brooklyn. It's pretty old but still used by millions of people each year. Huge potential for revenue from tolls. Put your bid in today!
    https://foolsfornitrogen.com/brooklynbridgeforsale.htm
    Wade and killer58 like this.
