anyone run pagid rear brake pads? | FerrariChat
Discussion in '360/430' started by goto35march, Feb 11, 2019.
  1. goto35march
    goto35march Karting
    Jul 23, 2009
    233
  2. Walt Gamble
    Walt Gamble Formula Junior
    May 22, 2014
    426
    Search OEM brake pads...there's a long thread there...3 mos ago?
    Sent from my XT1058 using Tapatalk
  3. tazandjan
    39,182
    Some Pagid pads squeal like all get out. 575M FHP models came with Pagid 4-4s and they squealed badly until well seated. Worked really well, though, much better than regular OEM.
  4. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    As for mixing pads front and rear, you may throw off braking balance as they may behave differently as they heat up. While ABS should compensate, it’s not an experiment I’d want to try. It’s probably not as bad or dramatic as mixing tires, but why not change out all of them?
    whatheheck likes this.
  5. MaranelloDave
    MaranelloDave Formula 3
    Apr 27, 2010
    2,203
    LA
    Dave
    I'd replace them all with the same pad material. It's not like it's too difficult or expensive to replace pads at all four corners.
    whatheheck and Need4Spd like this.
  6. Manda racing
    Manda racing Formula 3
    Feb 25, 2015
    1,270
    Bakersfield, Ca
    Mark
    The guys at Vivid Racing in AZ talked me out of the ones that were on sale b/c fast rotor wear due to aggressive material.
    Fwiw
    Need4Spd likes this.
