Anyone tried this "upgraded" window lift motor? | FerrariChat
Discussion in '308/328' started by greg288, Oct 23, 2016.
  1. greg288
    greg288 Karting
    May 28, 2007
    203
    Has anyone tried this window regulator/motor set-up?
    Ferrari 308 Door Window Lift Motor # 60030509 | eBay
    It certainly looks more beefy and industrial than the usual part however it is twice the going rate for the normal replacement and doesn't feature the manual crank hole.
  2. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    The stock mechanism is easily cleaned and rebuilt. The motor is usually ok. My windows would not move without hand assistance. After reworking the mechanism the windows move with ease. I also replaced the window channel molding.
  3. George Vosburgh
    George Vosburgh F1 Rookie
    I have seen this motor and considered trying them. "Birdman" recommends a unit that sends the correct amperage to the motor which he says the original design layout does not do. Which is why everyone has problems with the windows. I'm going to address this problem this off season. Film at eleven.....
  4. dflett
    dflett Formula 3
    1,632
    NY
    David
    Mine were slow and the passengers even stopped half way down. Cleaned both gearboxes and realigned/retensioned passenger side and both sides are ok now with stock motors and wiring. Sometimes they just need cleaning/servicing
  5. 308inSD
    308inSD F1 Veteran
    Aug 17, 2010
    8,979
    SD, CA
    Greg
    The hard part of the job is rewinding and rerouting the wire, right? How challenging was that?
  6. dflett
    dflett Formula 3
    1,632
    NY
    David
    #6 dflett, Oct 25, 2016
    Not very difficult. You can use cable ties to hold the winding while your route the cables. But do draw a picture of how the cable is routed before you take it off and make the replacement cable the same length as the one you take off.
  7. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,259
    Black Forest Germany
    Martin N.
    #7 Martin308GTB, Oct 25, 2016
    There even exists a helping tool. I got mine together with a used motor assembly from TRutlands many years ago.
    Worth its weight in gold.
    Best Regards
    Martin
  8. robo330
    robo330 Formula Junior
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    The glass on my car was very slow, in fact sometimes would not lift at all. I lubricated the motors and drive shafts without removing them. Installed Birdman Fuse Blocks and the suggested Window Accelerators (see the Birdman website) and the windows go up and down really fast for an old car. The Window Accelerators made a huge difference, but Jonathan Birdman's Fuse Blocks increased the Voltage to the electric motors significantly. I would suggest lubricating the cables and pulleys when you have the Door Trim off. I believe this was all covered in another Thread on this site. Do take a look!
  9. robo330
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    The Window Accelerators are available from Rodney Dickman - refer: Birdman's 308 site.
  10. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    These new style motors are amazing. I got mine from TRutlands.
    Aaron
  11. robo330
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    Is that $499 for 1 or 2 motors? Seems a lot to me,,,?
  12. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    TRutlands was about $600 for two I think.
  13. robo330
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    The 2 Fuse Blocks from Jonathan Birdman cost $180 plus the Window Accelerators from Larry Dickman cost $119. All up $299 plus S&H. Not bad I think!
  14. greg288
    greg288 Karting
    May 28, 2007
    203
    #14 greg288, Oct 25, 2016
    Thank you Aaron!
    I was very aware of all the typical problems and suggested fixes for them.
    I was simply asking if anyone had actually tried out these new style motors/regulators.
    And thanks for the shopping tip.....I'll take $600 over $1K for a pair any day.
  15. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    I had a video of mine somewhere. Window down and back up takes about 10 seconds per side now.
    Aaron
  16. kafugelum308
    kafugelum308 Formula Junior
    Jun 6, 2003
    610
    Northwest
    M Bradley
    I have two of them on my 308. I had cleaned the existing ones and was never happy with the results. These were a bit of a pain to run the cable but there was ample direction on FerrariChat. I am very pleased with the result.
  17. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,328
    Dumpster Fire #31
    SMG
    Amperage draw is the problem, use the dual relay circuit posted at least a decade ago. Just need to add a power lead from the fuse box... Instant faster windows for $20 and an afternoon.
  18. dinoart
    dinoart Formula Junior
    798
    Westminster CA
    David
    Martin
    Where can I get this tool? Is it still available? I don't see it under TRutlands. Thanks
    David
  19. Martin308GTB
    Jan 22, 2003
    4,259
    Martin N.
    Hi David,
    this tool is not, and never was available separately. It just held the cable on the spool for packaging and transport purposes. But it really helps while working on the windows.
    Therefore I redesigned this tool myself and sell it as a 3d printed part. I don't know, whether it's allowed to link to the sale ads section, where I have a thread. Therefore I will send you it via PM later.
    Best from Germany
    Martin
  20. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
  21. JohnInItaly
    JohnInItaly Karting
    Feb 5, 2019
    118
    California
    John McCoy
    Birdman fuse blocks and grease on the cables made such a huge difference that I plan no further work on my windows. They work just fine.
  22. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    I'd ask the same question I usually do regarding "upgrades" to existing systems...In this case, "Did the windows go up/down adequately when the car was new?" If not, then yes, something better is needed, if they DID, then unless the motor has failed or parts are broken, cleaning (to include electrical connections) and lubrication will restore it to operating as it did...
    Whether they worked OK when new, I don't know though I rented a couple of several-year old 308's when in Hawaii back in the 80's and I don't recall the windows being unusual in their up/down performance. But admittedly that wouldn't have been something I was particularly concerned about while doing my (poor) Magnum impersonation. ;)
