Anyone use Rust-Oleum epoxy on their garage floor? | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by battman, Sep 21, 2004.
  1. battman
    battman Karting
    Dec 1, 2003
    68
    Milwaukee, WI
    Jeff Batt
    Hello all,
    With a little luck, I'll be moving into a new house in the next month or two. 1st order of business: setting up the new garage. I was looking for a cheap way to protect the floor, make clean up easy, and of course look good. Sadly, this is not a show garage, I'll be working on cars in there and it will see snow/salt covered tires, etc.
    I was thinking about using the Rust-Oleum epoxy. I searched through the archives and found a little info, but curious to see if anyone recommends (or doesn't recommend) it.
    Other suggestions welcomed!
    THANKS!
    Battman
  2. Wolfgang5150
    Wolfgang5150 F1 Rookie
    Oct 31, 2003
    4,706
    Yeah - it sucks!! Seriously, I bought two kits at Home Depot last year; it peeled/flaked etc. within months. I followed the directions to the letter. Extremely frustrating...............
  3. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,984
    MD and NE
    Robbie
    Jeff, Behr paints also make a garage floor paint, available from Home Depot. DONT BUY IT. It sucks. My did the same thing started peeling. I emailed the Co. and sent them a sample from my floor. They said it was bad primer from the factory and sent me a check for reimbursment. That was cool of them but what a pain in the rear.
  4. PWehmer
    PWehmer Formula 3
    Oct 15, 2002
    1,733
    Surrounded by Water
    Get industrial epoxy.
    Grainger sells it. www.grainger.com
    Search for 9100 system epoxy.
    Need to clean the floor well. Then treat it with the acid to open up the surface of the concrete. The concrete needs to be very dry and aged for 28+ days.
    The 18' wide rollers make a better final appearance- less ridges.
    With proper prep the epoxy will stick great.
    To keep it from being too slippery broadcast some aluminum oxide on the surface. Grainger sells bags of it for a couple bucks.
  5. VROOM!!!
    VROOM!!! Formula 3
    Feb 11, 2004
    2,495
    Los Angeles
    Armen
    Is there a purpose for this? The only thing i do to my floors is walk on it...
  6. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,026
    PA
    Kevin
    I have had Rust-oleum epoxy on my garage floor for about 2 years now and it's great. I'm in PA so the temps vary from 0 to mid 90's. Oil and fluids wipe right up; I also slide my jack across it with no problems. It also looks cool since the kit includes a bag of paint chips you can throw onto the still wet floor to give it that professional look. I'd recommend it.
  7. JSL
    JSL Formula 3
    Jan 5, 2002
    2,212
    California
    J.S. Leonard
    I put it down on my new garage about 3 months ago. Seems to be fine. Don't know about the long run but I looks great and seems to be holding up well.
  8. sduke
    sduke Formula Junior
    Mar 10, 2003
    825
    The Hub City, Texas
    Steven D
    I have painted three garage floors. I have used Rustoleum, Sherwin Williams, and U-Coat-It. All three produced good results.
    I have posted pictures of my last floor (which is with U-Coat-It), so I won't bore everyone with a repost. I feel like the U-Coat-It produced a bit better gloss.
    The whole secret is painstaking preparation. The concrete must be completely free of oil and grease, antifreeze, and dirt. You cannot shortcut this and have a good result. I acid etched my last floor twice to make sure I had good adhesion. I feel like a portion of the better result with the U-Coat-It may simply be that my preparation got better each time I did a new floor. The prep time easily took five times as long as the actual painting.
    I had a bit of hot tire peel with the Sherwin Williams, and the Rustoluem stained a bit from the tires. The U-Coat-It kit was first rate and I really like the clear sealer that went down on top of the color. The kit came with mixing buckets, crack patch, two cleaners, gloves, complete instructions, free support line, and step abrasive if you have some steps to paint.
    That said, good prep will make any brand work and look good.
  9. SrfCity
    SrfCity F1 World Champ
    True, I used the Behr stuff and short cut it and the stuff is not sticking. One thing though, the Behr crap is water based. I think that it'd be better to have some kind of oil based stuff. Home D didn't have an oil based product.
  10. WAR EGL
    WAR EGL Formula Junior
    May 8, 2003
    726
    SE Connecticut
    TWS
    I used the Rustoleum product, and in general found the results to be good. I suspect, however, that I am not the typical user. First, I degreased and then power washed the floor. Then, rather than using the citric acid supplied in the kit, I opted to etch with phosphoric acid. Muriatic would have been a second acceptable acid, but I chose not to use the citric since its unlikely that it will adequately etch the surface to ensure long term adhesion. After all that, I let the epoxy cure for 9 months before parking a car on it. I didn't intend it to be 9 months, but that's how long it took to find the right F-Car. I suspect that your average individual isn't willing to wait that long before parking on paint, but I am sure that it added to the durability of my application.
    The only issue I ended up with is some peeling where an unlevel section of the floor let water in under the garage door. The constant pooling and evaporation caused the paint to peel in that spot. I know that it was the pooling and sitting that was the problem because the paint outside the garage door that is constantly exposed to the weather did not show any signs of peeling. Its been two years since I painted the floor, so it has seen significant temperature swings as I didn't add heat to the garage until after the paint was more than a year old. Other than the area that peeled due to the water, the floor was in excellent condition when I sold the house last month. Now I have a 104 year old unfinished garage. Looks like I need to start this process over as the Ferrari just doesn't look right sitting in a grungy garage.
    TWS
  11. 360CS
    360CS F1 Rookie
    Nov 1, 2003
    2,641
    Kent
    Joe J
    #11 360CS, Sep 23, 2004
  12. 360CS
    360CS F1 Rookie
    Nov 1, 2003
    2,641
    Kent
    Joe J
    I beleive that Rust-o=leum is part of The RPM Group which also own Stoncor TREMCO etc etc etc Their products are of good quality :) A bit pricey i thought!!!!
  13. Bluebya
    Bluebya Rookie
    Sep 19, 2004
    3
    Norcross, Georgia
    Marc
    #13 Bluebya, Sep 23, 2004
  14. We did our garage floor back in june it was cleaned with the acid wash provided in the kit then it was painted and the flakes where thrown its still holding up well and looks great also wash's off really easy.
    Just depends on how thick and how well you apply it and how well you clean and prep the surface.
  15. F328 BobD
    F328 BobD Formula 3
    Mar 17, 2001
    2,327
    Southlake, TX
    BobD
    Interesting how we all get different results. I tried the balck and white stick tiles in my last garage and it was terrible... really bad. If you turned the tires on the way into the garage, the tiles would slide around and move. It looked great when I first put them down... but I would never use stick tiles ever again.
  16. DN35
    DN35 Formula Junior
    611
    Illinois
    D. Norton
    Rustoleum sucks. It'll lift under hot tires. Spend the money and get one of the good kits.
  17. GaryReed
    GaryReed F1 Rookie
    Feb 9, 2002
    3,127
    Seattle
    Gary
    I haven't had any problems with the Rust-Oleum coating that I applied to my garage floor.
    I bought the "solvent based" two part system, NOT the "water based" one and I degreased the floor with Simple Green and then acid etched it before applying the paint.
  18. Wolfgang5150
    Oct 31, 2003
    4,706
    Gary:
    Where did you buy the solvent based paint? And how much was it?
    Thanks.
  19. GaryReed
    GaryReed F1 Rookie
    Feb 9, 2002
    3,127
    Seattle
    Gary
    Either Lowe's or Home Depot and I think it was about $75 for the two gallon kit.
