Anyone with a Broken Timing Belt? | FerrariChat
Discussion in '360/430' started by MalibuGuy, Aug 24, 2010.
  1. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,848
    The threat of a broKen timing belt lurks in the mind of 360 owners.
    Was wondering if anyone experienced such a disaster?
    (Changed my original belt at 3.5 years and 35K miles. )
  2. KINGS POWER
    KINGS POWER Formula Junior
    Aug 3, 2005
    275
    SoCal
    King
    I have not seen a failure on a 360 or 430 yet
  3. PAP 348
    Dec 10, 2005
    100,205
    Mount Isa, Australia
    Pap
    Probably because the 430 has a timing chain. :D:D
    But yes, I also havent heard of a belt breaking in a 360 or the chain failing in a 430. :D:D
    But we have seen a recent example of a cam variator failing causing engine damage. :(:(
  4. blackbolt22
    blackbolt22 F1 Veteran
    5,799
    Boca Raton, FL
    Mr. Anderson
    Another reason I went with 430 was no belt changes.
  5. chrmer3
    chrmer3 Formula 3
    May 19, 2006
    1,719
    USSA
    Chris
    a 430 w/ 6-speed would seem to be the best service wise..
  6. PAP 348
    Dec 10, 2005
    100,205
    Pap
    Yep. :eek::eek:
  7. MalibuGuy
    Sep 18, 2007
    5,848
    Can you describe the Cam Variator failure.
    I know about a recall campaign to replace the bolt which holds the Variator on one Bank.
    Some have said that even with the longer bolt, failures can still occur.
  8. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,437
    what year is your 360?
  9. CyclingPeaks
    CyclingPeaks Formula Junior
    Jun 11, 2006
    361
    Big Island, Virginia
    Hunter Allen
    There used to be a youtube video of a Stradale at Palm Beach Track day blowing the cam belt during a lap. It was an in car camera shot so not much to see except the driver clicking the paddles and nothing happening. Can't find it or would post it. Very sad day for him I would say.....
  10. MalibuGuy
    Sep 18, 2007
    5,848
    My 360 is MY2003.
    My car had the Variator bolt replaced with a longer one.
  11. PAP 348
    Dec 10, 2005
    100,205
    Pap
    Here ya go mate. Have a read. :(:(
    http://www.ferrarichat.com/forum/showthread.php?t=240871&page=9
  12. MalibuGuy
    Sep 18, 2007
    5,848
    Thanks PAP for the thread.
    It appears that the Variators need to be changed with the belts and that perhaps they are more likely to fail than the belts are!
    Are Variators the same as tensioners?
  13. blkdiablo33
    Jul 12, 2004
    4,437
    i thought variotors concerns were for the 99-00 and 01 and up were okay?
  14. blkdiablo33
    Jul 12, 2004
    4,437
    is this your secon round for the timing belt replacement?
  15. MalibuGuy
    Sep 18, 2007
    5,848
    Yes I am approaching my second belt service.
  16. PAP 348
    Dec 10, 2005
    100,205
    Pap
    Yeah man, thats what I would do. :D:D
    Replace the cam variators every belt service. Aint cheap, but its probably for the best. :D:D
    Variators are not the same as tensioners. :):)
    Variators vary cam timing. Tensioners tension cam belts. :eek::eek:
    They were "updated", but I think the ones that failed in old mates car where the updated ones. :(:(
  17. m3mike
    m3mike Formula Junior
    Apr 18, 2006
    464
    Knoxville, TN
    When I had my 360 in being worked on they had another one in the shop they were rebuilding after the timing belt broke. It does happen.
  18. 900ssDuke
    900ssDuke Karting
    Sep 12, 2007
    214
    Steady on chaps. Your dealers will love you. There would be loads more of these failing for it to be a big problem. If mine fails (04 car ) I'll let you know. I'm certainly not changing it out every belt, and I dont believe many dealers will either unless you suggest it to them.
    I feel lucky.
  19. andrew911
    andrew911 F1 Rookie
    2,893
    Northern NJ
    +1- I'm going to drive my car and do normal belt changes/service...enjoy life and not worry about it. I've only heard about 3 variator failures here on f-chat, from around the world- such a small number relative to something like 18,000 360's made? Things tend to get blown out of proportion on forums (that is per my mechanic). Don't want to jinx myself though, so I'll knock on wood :)
  20. chrmer3
    chrmer3 Formula 3
    May 19, 2006
    1,719
    USSA
    Chris
    Someone thats bored do the following- amount of 360's consumed by "spontaneous combustion" vs variator failures.... ;)
  21. wilsemail
    wilsemail Karting
    Sep 30, 2007
    76
    Anaheim, California
    I just turned 80k miles on my '99 360 and no variator problems at all. I just changed the timing belts, but as I stated in a previous post, these timing belts are tough!! Toughest ones I've ever seen. As a matter of fact my timing belt had 50k miles on it this time before I changed it. Why? Am I crazy? No, I inspected it regularly after 30k and found it to be like new. Just like the first one I changed at 30k. And when I changed it this time at 50k it still looked good and so did the tensioner pulleys,....in perfect condition. Don't forget, there are two timing belts with a separate drive gears for each, further reducing it's stress. Looking at the belt after 50k showed microscopic cracking. Didn't want to chance it anymore.
  22. MalibuGuy
    Sep 18, 2007
    5,848
    Hey PAP-
    I looked at some of the timing diagrams:
    The Variators are attached at the end of the exhaust cams. From what I gather from the other thread is that they are difficult to remove and replace.
    The Tensioners are located in the "V" of the timing belts. Much easier to replace. On my first belt service one was replaced.
    Now my question is:
    Can the mechanic determine at the time of belt service, if the Variator and Tensioners are worn out and need replacement?
    Or does one just change them or not depending on your philosophy?
  23. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    1+
  24. tazandjan
    39,082
    #24 tazandjan, Aug 25, 2010
  25. MamoVaka
    MamoVaka Formula 3
    Jul 31, 2006
    1,409
    Los Angeles, CA
    Pano S.
    you pansy! I would have ran it until I literally saw tears and the belts looked like bruce banners belt after he transforms back from the incredible hulk! torn to shreds! that is how a true baller rolls!!
    50k! come on! go for 100k!! microscopic tears? come on! don't be a nancy boy!
