360 - Apologies in Advance... Tires in 2022 | FerrariChat
360 Apologies in Advance... Tires in 2022
Discussion in '360/430' started by ihavearedferrari, Apr 4, 2022.
Tags:
  1. ihavearedferrari
    ihavearedferrari F1 Rookie
    Nov 23, 2007
    3,316
    Adam
    Hi All,
    Just wanted to quickly check in and ask if anyone is using the following tire combo:
    225/45/18 and 275/40/18
    The rears are OEM size but the fronts are slightly larger.
    Any issues with this combo with regards to ABS/ASR?
    Any feedback appreciated.
    Cheers
  2. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    I went up size on the front of my 430 to 235 and left the rear stock at 285. No issues.
    ihavearedferrari likes this.
  3. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    I don’t know. I run 225/40-28 and 285/35-18 Pilot Sport 4S on OEM starfish on my 360 with no issues. The key is to keep rolling diameters close to stock ratios front/rear.
  4. Ghostdiver
    Ghostdiver Formula 3
    Mar 18, 2005
    1,348
    Southeast Texas
    Wally Hollar
    N4S, I sure hope you meant 18" on the front and not the Amish 28" wheel....couldn't resist. Sorry!
    OP, I can't find the program/website I used to "play" with combos but you should be able to use this site to do the same. Remember to plug in the stock sizes and keep the aspect ratio close. Doesn't have to be exact, but should be close. Also, depending on what year your car is it may be more sensitive to size differences.
    Tire Size Comparison
  5. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    LOL. Fat finger on iPad! Yes, 18.
