Apple Help | FerrariChat
Apple Help
Discussion in 'Other Off Topic Forum' started by Seth, Aug 17, 2004.
  1. Seth
    Seth Formula 3
    Feb 8, 2004
    1,551
    Texas
    does anyone know for the powerbook how to keep the computer on when i close the screen? so i can listen to music?
  2. DrStranglove
    DrStranglove FChat Assassin
    31,498
    Google Maps
    DrS
    yes.. give me a sac
  3. DrStranglove
    31,498
    Google Maps
    DrS
    Go to "System preffs"
    well, I thought it was there... just go to energy saver and make he display go to sleep only!!! And leave it open!!
  4. Seth
    Seth Formula 3
    Feb 8, 2004
    1,551
    Texas
    i dont want it open! i want the thing to close and still play like my PC...
  5. richard_wallace
    richard_wallace Formula 3
    Feb 6, 2004
    1,957
    Cincinnati, Ohio
    Richard Wallace
    One word...
    iPod :)
  6. DrStranglove
    31,498
    Google Maps
    DrS
    true. with itrip, no wires!!!!
  7. DrStranglove
    31,498
    Google Maps
    DrS
    Ok
    You can use a PowerBook G4 and PowerBook (FireWire) computer by closing the display and connecting an external monitor.
    Close the PowerBook's display. The PowerBook will go to sleep.
    Connect the AC power adapter and an external monitor.
    Turn on the external monitor.
    Connect an external Apple USB keyboard and mouse. The PowerBook will wake from sleep. If you have an Apple display that also has a USB cable, connecting this cable will also wake up the PowerBook.
    To use the internal display again, choose Sleep from the Apple menu, then wake the PowerBook by opening its display.
    Tips
    When you use your PowerBook with the display closed, you can't take advantage of Video Mirroring. If you have both a VGA and S-video source connected to the PowerBook, only the VGA device, usually an external display, will have an image.
    Connecting an external monitor increases the power requirements of the PowerBook. Therefore, you must use the AC adapter whenever the PowerBook is connected to an external monitor. The PowerBook will not wake up if the power adapter is not connected, and if you disconnect the power adapter the computer will go to sleep.
