348 - Are 348 and 308 OEM black plastic shift knobs the same? | FerrariChat
348 Are 348 and 308 OEM black plastic shift knobs the same?
Discussion in '348/355' started by dave80gtsi, Oct 12, 2021.
  1. dave80gtsi
    dave80gtsi Formula 3
    1,918
    Ohio
    Dave Meredith
    I "think" that this is the case, based solely on casual observations made at car shows. And then the 355 series went to a 6-speed chromed knob, right?
    Should this be the case, since many of you newer 348 model folks might not poke around the 308 / 328 forums very much, you might have missed a thread up there about a very nice alternative to the cheap-looking and -feeling black plastic shift knobs:
    Bespoke Black OEM-Style Wooden Shift Knob | FerrariChat
    Note that, while I did start the aforenoted thread, I have no financial interest here. I'm simply passing on a trusted resource for a very high quality improved knob, coming from a very satisfied user.
    Thanks - DM
    P.S. - Did the 348 series used white or orange R-1-thru-5 numerals on their OEM knobs? I've seen both.
  2. bjwhite
    bjwhite F1 Rookie
    4,806
    Seattle, WA
    Brian White
    I've never seen orange numbers, only white on the 348. Unless someone painted them to match the gauges.
  3. AceMaster
    Feb 6, 2009
    34,776
    Ontario, Canada
    I've never seen the orange coloured #'s......at leats that matches the 348 gauges :D
  4. dave80gtsi
    1,918
    Ohio
    Dave Meredith
    Upon further investigation, I do now believe that the OEM orange numerals is a 328 thing.
    Best picture which I could find:
    Nevertheless, it's your car, so you can make them any color which floats your boat!
  5. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    494
    Victoria, B.C, Can.
    John Glen Wesanko
    Just a note about shift knob pattern colors. If you want to restore the fresh white look there is a paint "crayon" available that works well. We used to use it at work when restoring the white highlighted areas of helicopter cyclic grips. Use a toothpick or something that will not mar the finish and "dig out" the old dirty fill and then clean with a toothbrush and soapy water. Once dry, rub the crayon back and forth across the grooves until you have filled all numbers and lines flush. Take a clean microfiber towel and polish off all the excess product and it will look like new.
