Are any of the running 412 T2's still running a tipo 044 V12? | FerrariChat
Discussion in 'F1' started by SSNISTR, Aug 3, 2014.
  1. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    Hi all. I know there are more then a few 412 T2's still in running order. Does anyone know if any/all are running an original spec 044 engine, or is some other engine being used instead? Recent engine shots showing the engine ID tag would be great too. As a buddy of mine is "positive" they are using some other V12 and I am pretty sure original spec 044 V12's are still being ran...
  2. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    #2 SSNISTR, Aug 3, 2014
    Seems 11 412 T2's were made, seems high for an F1 car no? I mean none of these were converted into F310's correct? I assume not as they were both very different looking chassis'?
  3. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,843
    Atlanta
    John!
    Ferrari F1 client program are the only ones capable of operating most cars, I would say anything post mid 80s would have to be run by factory certified and trained F1 mechanics who were familiar with the machinery. It makes zero sense running an alternate V12 unless by some strange circumstance the alternate unit in question just so happened to bolt up and mount to the chassis and suspension points exactly like the original (no chance in hell). So in other words, it's highly unlikely Ferrari would modify an original F1 chassis to accept any other engine other than that of which it was designed to accept. It's entirely too much work and massive $$$ to design a new one-off engine to fit the thing when it won't be any more durable anyway.
  4. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    I didn't mean a one off, was thinking maybe a '94 spec 043 or something similar.
  5. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,704
    ESP
    Bas
    All cars in Corse Clienti are running their original engine as far as I know.
    There are a couple of the 412's (T1/T2) that are outside the program but they still have their original V12s as well. Ascari Resort had 2 or 3 of them. I would think the 043 and 044 would have similar mountings etc but it would be quite hard to come across these engines, and I doubt that Ferrari would retrofit a different engine in there.
    CC and AR normally run the cars at lower revs (~1000rpm lower at least) to preserve the engine as rebuild are very expensive and frequent...lowering the RPM by ~1000 can extend engine life 5-8x longer. Doesn't make a huge speed difference for these guys so it makes a lot of sense...
  6. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    Makes sense. Hopefully someone has seen one recently and can confirm a 044 in a 412 T2...
  7. Bas
    Mar 24, 2008
    42,704
    ESP
    Bas
    I did some research; The 412T2's for sale that where owned by Ascari/Klaas Zwart both had their original engines (so 044's).
  8. bigodino
    bigodino F1 World Champ
    13,119
    The Netherlands
    Peter den Biggelaar
    False. There are quite a few parties outside Ferrari that run these cars. And I know of at least one Ferrari (an F93A) that once had a JUDD V10 in it.
    There's a world outside the Ferrari factory - and every other F1 manufacturer for that matter - that keeps these old cars running.
  9. Bas
    Mar 24, 2008
    42,704
    ESP
    Bas
    +1
    Rennwerk is one of them, I believe they're operating a 412T1 and definitely a couple of Arrows.
  10. Ferraripilot
    May 10, 2006
    17,843
    Atlanta
    John!
    Great to hear that ferrari doesn't keep their ecu and running info for these old cars completely proprietary!
  11. Bas
    Mar 24, 2008
    42,704
    ESP
    Bas
    The wonderful part of ECU's is that they can be hacked ;).
    I doubt the ECU of the 412's are very sophisticated though...
  12. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    Good go know, thanks!
    Anybody else have input?
