Are any of these parts valuable? 83 Mondial Cab | FerrariChat
Discussion in 'Mondial' started by Subito Grigio, May 16, 2022.
  1. Subito Grigio
    Subito Grigio Formula Junior
    Jun 2, 2009
    405
    The exhaust sampling brackets/tubes not shown. They are pretty bad - but who knows - they might be very rare.
  2. FamilyCar
    FamilyCar Formula Junior
    787
    Seattle, Wa
    Peter Goodall
    Those were probably taken off because they were worn, but by now they may be useful.
    In the 3rd picture, I think one of the boots on the left is for the clutch slave cylinder. Any rubber items that old are prone to tearing and I'm not sure how available those are, so it would possibly be of value to someone that needs one. When I had my slave cylinder re-built they put a new boot on, but I had the old one that I hadn't given them. It fit a lot better.
    The brake booster might be rebuildable, so someone might want that to have rebuilt then do a swap, rather than pulling theirs out and waiting.
  3. Subito Grigio
    Jun 2, 2009
    405
  4. moysiuan
    moysiuan F1 Rookie
    4,191
    Canada
    They are rare but they need to be in usable condition, the nuts can be so corroded that they would not be usable.
  5. Subito Grigio
    Jun 2, 2009
    405
  6. moysiuan
    moysiuan F1 Rookie
    4,191
    Canada
    #7 moysiuan, May 18, 2022
    I don't think I see anything of notable value.
    The brake pads look like plenty of wear left, and they have the OEM style wear sensor wires. Could be useful to a handyman or reseller who has worn pads and doesn't get fussed about needing new.
    The brake lines might have fittings that can be salvaged for a brake line rebuild, but since new lines are available, albeit without the original style fittings, probably not much immediate use. The oil hose fittings might also be useful for a line rebuild, new hoses are not readily available.
    The shock top mounts might be usable. The other suspension parts would likely be too worn to bother using given the labour involved to replace those types of things.
    Maybe in the future when there are concours restorations of these cars some of the old parts would be scarce and rebuildable and find a market. eg. perhaps the engine mounts could be rebuilt? The brake boosters are usually rebuildable.
    I would just put the stuff in a box, label it, and let it sit for 20 years. Like many of the boxes of used bits in my workshop...waiting for the moment when Mondial's become coveted and restored like eg. Dino's!
  7. Subito Grigio
    Jun 2, 2009
    405
  8. 350HPMondial
    350HPMondial F1 Veteran
    5,325
    Edwardo
    Oil hose end fittings,, and the one slightly used ring nut.
  9. Subito Grigio
    Jun 2, 2009
    405
  10. Subito Grigio
    Jun 2, 2009
    405
    All of your feedback is extremely helpful toward separating the “nuggets” from the junk! FChat is really valuable in this subtle, but important way.
  11. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,674
    Argent/Brasil
    Guido
    Rubber Oil lines (from oil cooler, brake lines or others) you cannot use them again once air is touching the rubber inside. Rubber swollow up and new oil will degenerate and take it apart.
  12. Subito Grigio
    Jun 2, 2009
    405
    Ok. Thank you!
