Are porsche calipers fully interchangeable with 308 gt4 brakes | FerrariChat
Discussion in 'Technical Q&A' started by 308dino74, Feb 12, 2006.
  1. 308dino74
    308dino74 Rookie
    Nov 15, 2005
    16
    Hello...
    Does anyone know if........porsche rear 914-6 calipers are fully interchangeable with 308 gt4 brakes ? If so...how about the 1980 porsche 911sc calipers for the front?
    I know the pads are.....
  2. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    They were both Ate. My answer to your question is "I believe so" but I'd take a caliper along to your friendly Porsche dealer.
    BTW, if you want another set, I may have an old set of fronts in my basement somewhere. Will need to be cleaned up and rebuilt with new seals and dust boots.
    Philip
  3. 308dino74
    308dino74 Rookie
    Nov 15, 2005
    16
    Also.....i recently looked at pics of both and they seem identical.....has anyone tried installing them.
    i can the rear calipers for $45.00 each with no core charge.
  4. spang308
    spang308 Formula Junior
    Jul 17, 2004
    893
    York, PA
    308 rears are the same as 914-6 rears. I "believe" 308 fronts are the same as 911 fronts from the same era. Pads definitely cross over.
    Good luck,
    P.S. Phil how's it going? Long time no hear from.
  5. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    #5 pma1010, Feb 12, 2006
    Calipers: If anyone wants them (and I can find them) they can have the fronts for a nominal fee plus shipping. PM me.
    Hey John:
    Head down at work. Planning to go vintage racing in an Elan -- see pics, but have several negotiations to go through first.
    Philip
    P.S., 308DinoGT4: not intending to hi-jack the thread.
  6. Steve Magnusson
    26,841
    See if you can find out the thicknesses of the Porsche brake rotors vs the F rotors for those models -- I have a vague recollection of someone posting that the F rotors are thicker (so although very similar, the piece inbetween the two caliper halves is thicker, and the bolts holding the sandwich together are longer on the F version of these caliper).
  7. spang308
    Jul 17, 2004
    893
    York, PA
    Steve, you have a mind like a steel trap. I do remember hearing that discussed before.
  8. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Incidentally, the 911 calipers up to 1983 are for a 20mm disc. The 1984 - 1989 calipers are for a 24mm disc - same Ate calipers just a wider spacer between the two halves. One of these may be the right width for you.
  9. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    asked the same question got the same answers. with the wider disc how do you change the spacer? is it just a washer or like a bushing? do you need longer bolts? unraveling this will be great since porsche parts are easily available and cheap.
  10. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Ditto for the 246 GTS Dino too
  11. pcelenta
    pcelenta Karting
    Nov 1, 2003
    216
    If I remember correctly the only difference is the configuration of the handbrake assembly (I had an old 2 litre 914 in addition to my 308 for a bit) so in short you can't just slap a 914 caliper on. the issue of interchange was in the rebuild kits as the piston size is the same...you can also use the pad hardware kits.
  12. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    The space is exactly that (not a washer or a bushing). Specifically, it is dimensionally the same as the caliper halves in profile, only a set width depending whether for a 20 or 24mm rotor. Yes, you'll need different length bolts if changing from 20 to 24 or 24 to 20. Once apart you'll see how these seal against fluid leakage - it's not complicated.
    Easiest thing to do is figure out what ferrari rotor width you have then go buy some 911 Ate calipers for the same (or very nearly the same) width - either new from a porsche supplier, or used on ebay for example (then rebuild with rebuild kits). Incidentally, the CV axles are the same as for a 911 of similar vintage.
  13. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    You might want to try and contact "marankie". That's his name on this forum. He owns both a 914/6 and a GT4.
