Are there any differences between a 1985 QV engine and the 2 earlier QV years? | FerrariChat
Discussion in 'Technical Q&A' started by proteng, Oct 4, 2009.
  1. proteng
    proteng Rookie
    Sep 22, 2008
    17
    Sarasota, Florida
    I've heard and read that the best year of the QV engines is the 1985. Is there any difference between the '85 and the other 2 earlier years' engines?...or is it just that it 'should be' the best since it was the last year built?
  2. Steve Magnusson
    26,822
    If you mean for US versions, the "difference" is between '83 and '84-'85:
    1983 = K-Jet without Lambda, 2 cats, continuous air injection pump, cold start air valve, VLV...
    1984 & 1985 = K-Jet with Lambda (so it has an injection ECU and O2 sensor), 1 cat, pulse air injection that only operates during cold-running, no cold start air valve, throttle microswitch...
  3. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Actually, QV engines started production in 1982 per OM 248-82.
    Steve, was there ever a lambda Euro QV?
    Anyone have a link for pdf Euro QV OM?
  4. Steve Magnusson
    26,822
    #4 Steve Magnusson, Oct 4, 2009
    No, the '82-'85 euro 308QV are all K-Jet without Lambda, no cats.
    Unfortunately, it's so big that I can't email you a copy, but I downloaded my copy from the www.ferrariowners.com site (but, lately, I haven't been able to find the OM section there -- does anyone know where to find OMs on that site?).
  5. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Here are a few additional engine differences that come to mind:
    - Cam drive bearings are the larger size also used in the 328.
    - Metal pointers & shields instead of fiberglass rear belt covers.
    They also have these, but they may have been phased in earlier in the QV run:
    - Separate waterpump & alternator belts
    - Large bearing/small seal water pumps.
    - Cold air plenum between air box & body is quite different.
  6. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Once your car is registered, the pdf's are available under tab at the top "My Ferrari" then in the center of the page is 'Car Manuals'. But OM availability is limited to the car you registered.
    So how does one temporarily register another car model to get it's manual? And still not violate the sites rules.
  7. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,328
    Palos Verdes
    Vince V
    Sweet, great info. Never knew this. Thanks.
  8. Steve Magnusson
    26,822
    Thanks for the instructions Paul -- but that is the pits (F -- if your are listening, please make all OMs available to any registered Owner again).
  9. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    My 83, Oct. Mondial QV has the seperate belts.
  10. AMA328
    AMA328 F1 Rookie
    Nov 12, 2002
    2,518
    ABQ-67me68-OKC :)
    If memory serves, the early QV engines had ring(?) problems. After replacing many engines, Ferrari changed things, resulting in better engines sometime after that. Don't really remember the details, but way back when, the word was out on the early QV stuff.
  11. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,667
    South East
    Jimmie
  12. thecarreaper
    thecarreaper F1 World Champ
    18,071
    Savannah
    i think you are thinking of the 2v injected cars that had gained an oil burner reputation. never seen anything about early Qvs having these issues. i have a low vin euro Qv built in 1983. the engine has never been opened and it runs superb.
  13. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    I believe you are correct. In fact it was the 1980 model year specifically that had ring issues. IIRC. The QV motors are fairly reliable.
  14. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    +2
    It was the early 2V injected engines w/the problems, not the QVs.
  15. KatMan
    KatMan Formula Junior
    498
    Silicon Valley
    Stan K
    I had a late 82 2 valve injected 308 that had a big time oil consumption issue.
  16. GaryReed
    GaryReed F1 Rookie
    Feb 9, 2002
    3,127
    Seattle
    Gary
    My '81 drank a quart of oil about every 500 miles, but my '83 QV didn't use any at all.
    I just love the sound of the true DUAL exhaust system that was only on 1983 QVs (USA).
    http://www.youtube.com/watch?v=Z45rb9iA_CQ
