argh... chronic overheating... help.... | Page 3 | FerrariChat
Discussion in '308/328' started by James in Denver, Aug 26, 2007.
  1. Dr Tommy Cosgrove
    36,588
    Birmingham, AL
    Tommy
    I hope I am wrong but that milky color may mean a busted head gasket. What does the inside of your oil cap look like?
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,804
    The twilight zone
    That is a bad sign.......
  3. PAP 348
    Dec 10, 2005
    100,232
    Mount Isa, Australia
    Pap
    +1 :(
  4. James in Denver
    James in Denver Formula 3
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
    I'll check the oil cap, but let me clarify, it was milky green, it did not appear to be oil contamination. And this time when coolant came out it was clear green. However, I'll check the oil cap to look for condensation or milky foam just to be sure.
    The oil color on the dipstick is very clear (golden color of new oil) with no foam or foamy residue that I've seen on another car I had many years ago with a head gasket problem.
    What should I look for on the oil cap? Condensation? Milky foamy stuff?
    James in Denver
  5. Dr Tommy Cosgrove
    36,588
    Birmingham, AL
    Tommy
  6. James in Denver
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
    Ok, I'm of course late for work at this point (and slightly paniked), BUT...
    The oil cap has no residue on it what so ever, it was very clean with a slight bit of goldish brown oil. I pulled the dipstick, and aside from being slightly overfilled, the dipstick was also clean, goldish brown oil only.
    NO milky or foamy residue.
    I'm assuming this means 1) No head gasket problems, or 2) head gasket hasnt gone far enough to let contamination go backwards from coolant to oil.
    ---- slight bit of worry here ---
    James in Denver
    EDIT: Since I'm already worried, can someone describe the symptoms (besides overheating and milky coolant) of a head gasket problem? What else should I look for and what would be the "STOP NOW" symptoms?
  7. PAP 348
    Dec 10, 2005
    100,232
    Pap
    Yeah under the oil cap.
    In severe cases I have seen you can also detect the smell of fuel and or combustion gases in your coolant header tank also but this is usally followed with the coolant bubbling from time to time ;)
  8. Ultimate Pedals
    Ultimate Pedals Karting
    Nov 1, 2003
    101
    Palm Beach, Fl
    Rob Baylor
    Pressure check the coolant system.
    Requires a hand pump with a dial gage and an adapter to replace the cap on the expansion tank.
    Pump up the system and see if it holds the pressure.
  9. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    James you might not be in bad shape. You say your car hits 195 on the highway but if it doesn't go over the half way point in traffic then you shouldn't worry. My car hits 195 in traffic and goes down just a nudge when at highway speeds. Outside temp shouldn't really matter and factor the elevation in CO. and you might be at normal operating temps.
    Does sound like you should get it looked into at this point though just for peace of mind.
  10. BigTex
    79,406
    Houston, Texas
    Bubba
    195 is good on all mine, and the coolant does 'foam' as it comes out the bleeder..
    As noted and bubles or milkyness in the oil would indeed be cause for worry...
    As noted above also, the t-stat HAS to have the bleed hole and the proper sealing ring.....don;t cut corners at that point! Although there may be a 'value' part number out there for it......
  11. James in Denver
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
    This thread (the 2nd I started) was mainly due to the fact that the coolant tank was freaking empty and the temp skyrocketed on Sunday. I believe this is cured with the new cap.
    But, to clarify, my car will go OVER 195 at a steady 55 mph in light traffic in "cooler" outside temps, over by maybe 1 needle width. It will come down if there is NO traffic (airflow?).
    Also remember that I've not really driven out the car, I'm grand-pa cruising at this point BECAUSE it heats up very very rapidly and does NOT come down if I "put the pedal to the metal". Seriously, I'm doing 0 to 60 in like 15 seconds (and geez do people really want to race in this car).
    As the outside temperature climbs, so does the water temp. At 85 to 90 degree outside temp, low highway speeds are 195 for short distances and it creeps up to 225 (3rd mark) at longer distances on the highway (45 min drive from US36 to I-25 to home). In stop-and-go, it goes 2+ needles over 195.
    It has NEVER gone over the 3rd mark BUT the previous owner states that the laser temp reader showed 215 at the top of the radiator while the temp guage showed 195.
    After checking the oil cap and dipstick, I'm pretty sure (hopefully) that I do not have a head gasket issue (I hope). However, I believed that the previous owner had re-done the radiator, and that may not be the case, so the suggestions about the radiator being clogged / not getting flow may be accurate (its 23 years old).
    I WANT to be able to drive the car on the nice-and-twisties in the mountain roads, but if it heats up this much from cruising, I'd hate to over-do it in the mountains.
    My overflowing issue may be resolved (only 1 test drive), but based on the feedback here, the radiator will get redone or replaced as soon as possible.
    Again, thanks for all the help.
    James in Denver
  12. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,298
    Colorado
    Dave
    James,
    Drive it a while with the new cap. If your problems persist, get it to a mechanic. We can only offer suggestions on here, not diagnosis. BTW, I doubt you have any head gasket problems.
    Dave
  13. BigTex
    79,406
    Houston, Texas
    Bubba
    I agree with Dave ...actual head failures are pretty rare, statistically.....
  14. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,178
    Atlanta
    Tom Spiro
    Sorry to have started all the horror stories for you. If you dont have milky white on the dip stick or under the cap, then I think its safe to assume you are ok with out oil in the coolant.
    I really do beleive you have a radiator issue, and considering your altitude you may have some other weak items - cap, and old thermostat... that have contributed to the funky temp swings.
    When I had my 308, I used to avoid super hot day, and lots of traffic for the same reasons you are mentioning. So my advice is coming from someone who has been there done that... I was really supprised at how easy it was to remove the radiator... but I did take off my front spoiler too... if you keep it on it may be more difficult to get that bottom hose off..
    The other thing to be aware of is if your engine is overheating...seriously overheating... then your oil temps will be really hi... as long as they are between 210 - 230 range I think you are ok... even higher when you are on track etc... ,but if the oil temp pegs... you have a real issue going on.... sounds like you may or may not be aware of the oil temp.... if your oil is clean and clear, not milky... most likely your engine is ok.
    If you want to be really sure, the easy way is to do a compression test ... that will tell you if you have any leaks... all you need is the pressure tester gauge that goes into the sparkplug hole, make sure the cylinder is at power stroke - valves closed... and compressed air. you should get somewhere between 140 to 160 lbs... ( I think may be higher) the big thing is they should all be reading +/_ 10 - 15lbs of air pressure .... if you have a wide variance then that is the affected cylinder... and where you would have a gasket leak.
    taking off your head and replacing the gasket is not exactly the most fun you can have, but it is possible DIY... l'm pretty sure you dont have to go there. The good news is that these cars are very durable... they will take a ton of punishment and keep on going.
    In my case, I was at a track meet in Savannah and driving the car pretty mildly... with Wade from Ferrari of Atlanta and he said - your oil pressure gauge is not reading right... most likely its the sending unit... we'll pop one in when we get it back at the dealership ( I used to store my car there) ... two days later Ron Reineke calls me up and says "are you sitting down" "ha ha I said to Ron dont scare me like that" - then he says what I hope none of you ever have to hear.... " I'm not joking you have a major problem with your engine.... turns out that the #5 main bearing cap was sitting down on the windage tray... could have been there for years... when they bolted it back up ... the crank would not turn.... warped block!!!! - cause repeated overheating!!!!!
    I have to say when the guy who sold me the car wrecked his 360 challenge two years ago... I was not sad! (He survived with no problems) but Karma got him good!
  15. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,608
    Gates Mills, Ohio
    Jon
    I would find out. The radiator had already been redone on my 87 328 when I bought it. It's just an 'old car thing', and given the reasonable cost probably a good thing to take care of pre-emptively.
  16. ForzaMaranello
    ForzaMaranello Karting
    Jul 15, 2006
    234
    Louisville CO.
    Robert T
    James, I am sure I gave you all the service records on the car, My father remembers us doing the radiator, looking back, it was within a few years of purchasing the car, so that would mean somewhere in the early 90's. With that being remembered, I would say she probably needs it again.?????
  17. James in Denver
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
    Yeah, I know, I'm not looking for the fchat voodoo gods to mysterious fix the car :) I'm looking for advice as to where the problem is.
    After all the input, the radiator is the first stop after the cap. I'm going to drive it again tonight and see how the temp goes with the new cap, but I've already made plans (and budget) to replace the radiator.
    Now, the question is, re-core the original or replace with a NEW aftermarket aluminum.
    I'm thinking NEW, because its one of those "while I'm in there, might as well do it right, spend some money, save some weight".
    James in Denver
    PS Robert, I've put 950 miles on it in the past 1 1/2 months, told you I'd drive it more..... :) ...... and I'll check the receipts to see when the radiator was done and what was done.
    EDIT:
    The original owner (Robert and his father) did a compression test on it prior to purchase. I posted the results a while back. I had a low of 139 and high of 152 which is supposed to be good for Colorado. The cylinder with the 139 would be my only concern but it was a rear one and Roberts dad wasnt sure the tester was seated correctly. Most of the others were between 142 - 145 from memory.
  18. johnish
    johnish Karting
    Jun 21, 2004
    71
    Hertfordshire, UK
    John Isherwood
    Hi
    I had the same problem with my Mondial t when the outside temperature climbed to 68 F. Tried various things, new rad cap, make sure the water pump was running OK, made sure the fans were coming on, bled the system goodness knows how many times. Finally checked the radiator. Only two pipes in the cores were letting water through. Had the radiator re-cored, now no problem. £450 for the renovated rad against £2,500 for a new one. Well worthwhile. It probably happened as the car has lived in a hard water area all its life.
  19. docmirror
    docmirror Formula Junior
    May 6, 2004
    781
    Ft Worth TX
    +1 radiator (and lines) clogged. I fought this for a few years with my '83 QV.It would do okay in winter, get hot in summer, so I restricted my driving in summer. Went though all the rationalizations for everything else before pulling the rad last June. Took it to a cheezy shop in a crappy part of town and had them pull both tanks, clean inside, and rod every tube. Reassemble, and pressure test. Install a few new rubber lines(I shoulda done them all), and use water wetter. It's all good now, stays at 190-ish no matter what the outside temp is.
    funny thing I notice, the temp gauge lines are routed near the headlight supply wires. When I drive with the lights on, the gauge reads +10deg hotter due to inductive current flow. hahahaha!
  20. jimangle
    jimangle F1 Rookie
    Nov 5, 2003
    2,506
    Haverford
    James
    It wouldn't hurt to flush out your cooling system. Who knows what the coolant to water ratio is. The previous owner/shop could have filled it with straight coolant thinking it was pre-mix. The car will overheat with that mixture as well.
  21. Dr Tommy Cosgrove
    36,588
    Birmingham, AL
    Tommy
    Is Nick's the ONLY source for a aluminum radiator that fits our cars easily? He seems really high.
  22. hardtop
    Jan 31, 2002
    11,298
    Colorado
    Dave
    James,
    If you are going to do the radiator, just get the original recored. The weight savings from an aluminum one is not going to turn it into a pavement ripper. Having the original in there will be a plus when you resell (which, believe it or not, I'll bet you will). Sherpa23 just had his done very reasonably. Contact him for info.
    Dave
  23. CFCARRIAGE
    CFCARRIAGE Formula Junior
    Jun 9, 2006
    598
    Missouri
    Dave
    This may sound silly, but are you sure your temp guage is correct? We all know how some of the older guages can be off and/or fluctuate. Sounds like your getting thru the problem. Best of luck.
  24. James in Denver
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
    I drove the car last night (around 1am, no or very little traffic) for about 60+ miles (broke my FIRST 1000 MILES IN A FERRARI---- go me, go me....).
    Here's the update:
    Outside temp varied between 55 and 65 degrees. Water temp rose to 195 slowly for first 10 mins to 15 mins. Turned on heat and the water temp decreased, THEN increased back to previous level. Once at 195, it dropped considerably (thermostat opening? Fan turning?) then would go up and down always going to just below 195 except as noted below.
    First part of the drive was in city (no traffic, but stop and go due to numerous stoplights/signs). In one specific spot, the temp really decreased when the outside temp dipped, almost down to 1/4 mark. However, it always rose at stop signs/lights to just close to 195. Again, this is with NO TRAFFIC.
    Highway driving at 55 MPH, the water temp was 1 to 2 needles under 195, highway driving at 80 MPH, water temp was very slightly under 195 or right at 195.
    NO coolant discharging at all when I got back home.
    INTERESTING FACT: I bled the car again after it cooled for maybe 10 mins, ONLY AIR came out of the front radiator, NO FOAM AT ALL, air, then straight coolant, no spitting or foaming. AIR FOR ABOUT 20 seconds solid!!!! THEN COOLANT.
    I replaced the cap, thats the only change I've done so far. Maybe the cap was bad.
    I HAVE NOT driven in 80+ degrees yet, will try it this weekend.
    Still planning on doing the radiator, but want to see how this is going.
    ALSO NOTE: The car seemed to have a misfire/stumble when at cooler operating temps at idle/low speeds, say the first 10 to 20 mins of driving. However, after it hit 195 then backed down temp wise, it ran PERFECTLY, great acceleration and NO skipping/mis-fire.
    James in Denver
    PS I'm continuing to update this thread to keep this list informed and to document what I'm doing.
  25. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    If you want to test your radiator fan motor and alternator for proper output, let your car idle just outside your garage until hot, then use an extension cord turn on a large portable AC home fan to blow into your radiator.
    If your engine stays cool while idling with the home fan on, then it is your radiator fan that isn't pulling enough air (either going out or not recieving sufficient current, etc.).
