355 - Ash Tray Screw 15785101 | FerrariChat
355 Ash Tray Screw 15785101
Discussion in '348/355' started by Kruegmeister, Apr 14, 2019.
  1. Kruegmeister
    Kruegmeister Formula Junior
    519
    Michigan
    Kruegmeister
    Looking for the Screw that holds the Ash Tray in place
    15785101 should be the Screw & 12638177 the washer.
    Ricambi shows as Unavailable & Superseded
    Searched threads & found nothing
    Section Marked #2 is loose, is there a fastener for that as well?
    see pic
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Those screws are absolutely nothing special, run of the mill machine screws.
    You can get sheet metal screw at home depot that will work fine. Lowe's sometimes has a specialty section and the black oxide sheet metal screws are in there also in metric. I forget if it's #6 or #8. I bought smallest to largest for various places like the inner fender panel in front of the front tire. You can spray them black where you need a black head if you get the zinc ones.
    On the 348 it just kind of fits together with pressure when all the stuff is screwed down, probably the same with 355.
    Kruegmeister likes this.
  3. Kruegmeister
    519
    Michigan
    Kruegmeister
    The Plastic Piece on mine must have been worn because the #6 & #8 Didn't work, I did find a Screw just Slightly Larger than those and that did the Trick. All Together Now. Thanks for the Help!
    alexjack likes this.
  4. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    That plastic nut snaps out you can get replacements btw, but its plastic so just use oversize as you did.
