Assistance Needed: 2007 F430 F1 Transmission Problem | Page 3 | FerrariChat
Discussion in '360/430' started by Tarek K., Apr 18, 2010.
  1. Oengus
    Oengus F1 World Champ
    Glad your back in the saddle Tarek :)
  2. Tarek K.
    Tarek K. F1 World Champ
    10,798
    Cairo - Egypt
    Tarek K.
    Thanks Chas, yeah, it feels good........really missed her during these 4 months.
  3. wang
    wang Formula 3
    Feb 23, 2004
    1,998
    Brunei
    H. Wang
    Thanks for the thread (shukran jazilan). It's a heads up for my '07 430 as well.... I'm glad yours turned out ok although the wait must have been frustrating...
  4. Matthew 71
    Matthew 71 Rookie
    Jan 28, 2012
    1
    Just having a problem with my F430, it was ok for a while but now when I drive it the gear box will jump into neutral. It happens at any speed and in any gear and is really frustrating as I was on the motorway doing 60mph when it last happened. I Have taken it back to the main dealer twice for the same problem and its in there at the moment as they are trying to see what the problem is. I have had the clutch checked for wear and its still got 50% of its life left. Can anyone help with this!
    Cheers!!..
  5. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    First, one should address these questions:
    1) Does this "jump into N" at 60 mph occur while changing gears, during deceleration, or it suddently drops in N while in gear?
    2) Are you driving in manual mode or in automatic while this happens?
    3) Are you sure that there is no leak of hydraulic fluid from the F1 system that causes pressure drop?
    4) Has the dealer checked the clutch position sensor?
    5) Has the dealer checked the gear position sensors?
    6) Has the dealer tested or replaced the F1 pump and/or the corresponding relay?
    7) Has the dealer checked the F1 hydraulic manifold solenoids?
    Then, one can move further...
    Cheers.
  6. Living4life
    Living4life Formula Junior
    Jun 29, 2008
    263
    What does it mean when it blinks once or twice but doesn't goto neutral?
    If their is no leak and the fluid is full, what is your opinion...Would relay or motor would be first guess?
  7. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    Typically, ether the relay or the motor. However, there may be several other problems causing this symptom, which is better to be diagnosed with an SD3 or a similar system.
    What this blinking means - is that the required pressure in F1 system is not generated fast enough.
  8. kreuland
    kreuland Rookie
    Mar 10, 2011
    41
    I have 11,500 miles or 18+k kilometers on my '07 F430! No problems! Guess I'm lucky, but I drive it often! Sounds like the cars needs to be driven more than 500 miles per year to keep the hydrolics lubricated and functional.
  9. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    I agree !
    I drive my 360F1 spider almost every day! All on days I don't drive my 360F1, I drive my Testarossa 1990.
    These cars MUST be driven!
  10. Tarek K.
    10,798
    Cairo - Egypt
    Tarek K.
    Sorry to hear about your troubles Matthew.
    I had the same problem on my F430 and Scuderia and in both cases the dealer replaced the complete F1 kit which included the F1 pump, actuator,...etc.
    I would assume that the dealer will first have the system checked on the SD3 and adjust the actuator. If the problem still persists after adjusting the system, they will probably need to check the other components.
    Good luck.
  11. Musty
    Musty Rookie
    Jan 26, 2012
    1
    Tarek, enta masry? :D
    Ana Mustafa men Australia!
    Nice Ferrari man, are you able to enjoy it in the horrible streets of Egypt?
  12. seif roushdy
    seif roushdy Rookie
    Mar 28, 2012
    8
    egypt
    seif roushdy
    how would you rate the ferrari dealer in egypt? and would you consider getting a different type of supercar in egypt anytime soon?
  13. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner
    Jan 19, 2004
    7,849
    San Jose, California
    I already asked - a long time ago... :D
  14. radix
    radix Karting
    Dec 2, 2010
    234
  15. chenglo1
    chenglo1 Formula Junior
    Jun 23, 2012
    343
    Midwest
    Cheng
    I have been trying to research issues with the F1 system so as NOT to rule out the F1 in my future F430. I concluded that i want the old school manual gated shifter but being that they are so hard to come by, i thought i would settle for F1. These types of issues make me really want to shy away. I realize this thread is old but do you guys think that most these issues have been resolved? there are lots of '07 F430's F1's out there with decent prices and low miles. Pretty tempting but NOT when one reads a thread like this.
  16. bruno.ffc
    bruno.ffc Rookie
    Feb 21, 2013
    1
    Rio de Janeiro
    Bruno Alter
    Tared, glad that they solved your problem!!!
    Could you tell us what parts was changed on this F1 kit? It was only mechanical parts or electrical parts too?? F1 actuator, hydraulic pump, solenoids, sensors, relay, etc?
    Thanks!
  17. o31982
    o31982 Formula Junior
    Mar 18, 2012
    281
    Southern California
    nes
    Is this happening on low mileage 430's?
    I am in the market for a 2005 f430 F1 at just about 20,000 miles.
  18. zrk
    zrk Rookie
    Aug 10, 2015
    3
    Mumbai, india
    Zulfikar Khan
    AN ANSWER TO THIS WOULD REALLY HELP MATE
  19. 2bf360
    2bf360 Karting
    Dec 18, 2014
    60
    WA
    Heng
    What was the fix on your f430? My 08 f430 spider has the same identical as yours.
    Thanks,
    Don.
  20. sleepinglh
    sleepinglh Karting
    Jul 30, 2015
    82
    Sydney Australia
    Q
    The answer is if you fear these problems then you don't deserve one ;)
