Assistance Required: Brake Fluid Warning Light and Concern Under the Car | FerrariChat
Discussion in '360/430' started by DAF430S, Jan 18, 2025.
  1. DAF430S
    DAF430S Rookie
    7
    DAF430S
    Dear All,
    I hope this message finds you well and that the start of the year has been enjoyable for everyone.
    I recently observed a red brake fluid warning light (the one with an exclamation mark) on my F430 Spider. Concerned, I checked beneath the car and noticed something dangling, as shown in the attached picture. This seems unusual, and I suspect it may not be normal.
    The car continues to run beautifully and has never experienced any issues, but this development has left me quite concerned.
    I would greatly appreciate any advice or insights regarding this matter.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,960
    Central NJ
    Dominick
    The pipe in pic is normal .. the brake light is not
    Can you tell us when the brake light is on .. always, etc
    Attach a pic of the light in question
  3. DAF430S
    DAF430S Rookie
    7
    DAF430S
    Hi,
    Thank you for the prompt response a bit of reassurance, but why does the pipe look like it’s been chewed and brake light only comes on when the car is not in drive, when driving it goes away…
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,960
    Central NJ
    Dominick
    The pipe does seem low than normal and when going over speed bump etc it got worn ...it probably was misaligned during a prior service
    The light is telling you either the brake fluid is low or the pads are worn
  5. fatbillybob
    Aug 10, 2002
    29,071
    socal
    the tube looks like the HVAC evap core drain tube.. It's just a waste line. The brake light can be on for many reasons the brake reservoir fluid level for starters, worn brake pads with sensor trigger, bad sensor, bad wheel speed sensor, any number of brake codes, parking brake problems......Have a pro look at it. Brakes aren't something to mess around with unless you know how they work.
    flash32 likes this.
  6. Qavion
    Qavion F1 World Champ
    14,362
    Ian Riddell
    #6 Qavion, Jan 18, 2025
    Disconnect the connector on the level sensor on the reservoir and see if the light goes away. If not, it's a brake pad issue.
    flash32 and vrsurgeon like this.
  7. Qavion
    14,362
    Ian Riddell
    Unless you also have an ABS warning light, it won't be a wheel speed sensor. Not sure how a park brake issue would cause this... unless it's wearing down the pads.
  8. grtoz
    grtoz Karting
    Dec 14, 2010
    165
    Byron Bay, Australia
    Graeme Towers
    Qavion likes this.
