At home nitrogen filling solution | FerrariChat
Discussion in '348/355' started by mrpcar, Jan 19, 2008.
  1. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    #1 mrpcar, Jan 19, 2008
    I am pretty sure you guys know the advantages of filling your tires with Nitrogen. Less pressure change due to temperature, maintain pressure better, no moisture, etc.....
    Since I have several compressed tanks hanging around, I traded one of my smaller tanks from argon to nitrogen. The exchange was only $20.
    Bought a regulator so that I can regulate the PSI output from ebay ($70), as the compressed tank is filled to 2000 PSI. Added the adaptor to connect to a quick connect coupling for compressed air line. A fairly inexpensive at home nitrogen filling solution.
    Everything can be found from your local welding supply store.
    So free nitrogen filling when you are in Chino hills!!!!!
  2. fatbillybob
    Aug 10, 2002
    29,062
    socal
    N will do you no good at all if the tire monkey mounted yout tires with soapy water. The water vapor will break down w/ increased heat and alter your pressures. Next time dry mount soap the tires or use hair spray to mount and it will make a difference but you won't feel one if you are on the street anyway.
