ATC/ATO Fuse Panel | FerrariChat
ATC/ATO Fuse Panel
Discussion in 'Technical Q&A' started by phsimone77, Sep 19, 2013.
  1. phsimone77
    phsimone77 Karting
    Dec 29, 2009
    57
    Florida
    Phil
    Hi from a newbie,
    Although I have owned my 308 for several years, I am just starting to have some issues with my fuse box(s). I have found these 9 position fuse panels online for about $27.00 a pop. They take blade type fuses and may accept the OEM covers. Does anyone have any experience with these? Once again they are ATC/ATO 9 position panels, actually suitable for under the bonnet. I love Birdman's and I know there are many happy drivers out there with his great product but I would like to put the covers on mine.
    Thanks much and no disrespect to Birdman, he has been a great resource for me and I know many of you.
  2. phsimone77
    phsimone77 Karting
    Dec 29, 2009
    57
    Florida
    Phil
    If anyone is interested, go to CE auto electric supply's website to view. Did not want to post a specific company for purchase but this is the only place I have seem them. They appear to be a good match. Feedback would be appreciated.
  3. Mike Florio
    Mike Florio Formula Junior
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
    I made the conversion a couple of years ago and posted a report (with pics):
    http://www.ferrarichat.com/forum/308-328/354146-yafb-yet-another-fusebox-solution.html
    I got the fuse holders from an outfit called Wiring Products, Ltd (Electrical & Wiring Supplies - Automotive, Marine and Commercial - WiringProducts)
    phone: 775 425 5526. Here's the specific unit I used: 8 Circuit ATO/ATC Fuse Block Side Entry - WiringProducts
    I am very pleased with the quality of the fuse holders, and the clear plastic covers look a lot like the originals. The size is pretty close to the originals, and I even could have pried the aluminum labels off the original covers and glued them on the new ones, but I'll probably just make replicas. I had to make a bracket to mount the fuse holders and I made a cover out of thin plastic covered with (reversed) naugahide bra material.
  4. phsimone77
    phsimone77 Karting
    Dec 29, 2009
    57
    Florida
    Phil
    Thank you Mike, I will have to look at those. The ATC/ATO really look like they would do the job, and I may by a pair to see if they work out. I could always change them out if they don't.
    Phil
  5. phsimone77
    phsimone77 Karting
    Dec 29, 2009
    57
    Florida
    Phil
    Mike, I do like the looks of what you showed me. Of course there are only 8 circuits available. Might I ask how you consolidated the circuits to go from 9 to 8. Thanks so much.
    Phil M.
  6. Mike Florio
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
    I'm sorry, the part number I gave you is wrong. The ones I used were AF-CFB10A, which have 10 positions, but no longer appear on their website. Maybe you can give them a call and see if they have any of the 10 position boxes left. I went to the Arlington (manufacturer) website and found this ATC/ATO 10-way Heavy Duty, Side Terminal Fuse Block which is pretty close, but has two covers for each block, and may be too long at 7.25". Their 8-way standard box is only 4-13/16 long but will take 30A per circuit, so you could double up a couple of those 15A circuits with (say) a 20A or 25A fuse.
    I have one spare fused output on each box. Here's a better picture of the installation. You'll notice that on the top (input) side where one wire feeds several fuse tabs I used those brass expanders. I bent the top tab on the expander over to the next tab and soldered them together. Then I shrink-wrapped them to discourage any shorts. For the multiple output bottom tabs I just plugged in an expander where needed:
  7. Ferraridoc
    Ferraridoc F1 World Champ Owner Silver Subscribed
    Jun 20, 2012
    17,251
    Gold Coast, Aust.
    Patrick
    I couldn't buy the 10 slot ones anywhere, so mounted 2 x 8's and a 4 slot, giving 2 spare. Quite a complex install, and in the meantime found a source for the 10 slot (had to convince the retailer that he could get them in), so while the car was off the road for its major, made them up - will install later. Having too much fun driving my new 308 for now!
    If you flip the boxes upside down, you can bridge the terminals with thick copper wire - a much more professional looking install. I was going to solder on the double adaptors too - glad I didn't, now I can just swap them to the new fuse box.
  8. Mike Florio
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
    I was going to do that, but the structure of the boxes would have required cutting slots in the plastic and I was afraid it would compromise the structural integrity. I didn't solder the adaptors on to the male connectors on the box, I soldered them together separately, then inserted them.
