ate brake calopers | FerrariChat
ate brake calopers
Discussion in '206/246' started by dino clay, Jun 26, 2008.
  1. dino clay
    dino clay Karting
    Oct 31, 2007
    185
    san mateo, cal
    clay cavanaugh
    rebuilding, any one to recomend
  2. John Corbani
    John Corbani Formula 3
    Honorary Owner
    May 5, 2005
    1,153
    Santa Barbara, CA
    John Corbani
    #2 John Corbani, Jun 26, 2008
    Clay,
    Welcome to FChat. Take a few minutes to use the Search function here on th Dino Forum. There are lots of posts concerning brakes. Use Advanced Search, search on Brakes, select 206/246 thread only, and stand back. Or just use "Search this Thread" at the top of the Forum and enter Brakes. As a machinist, you can probably do it yourself. If you want to farm it out, either Ferrari or Porsche shops can do it. Porsche 914 used same calipers, front and rear. Simple job.
  3. champtc
    champtc Formula Junior
    Apr 18, 2004
    732
    there is also a very interesting thread on Willwood brakes. Evidently by merely drilling the mounting holes on the Willwood calipers themselves you can mount it to the wheel with no other modifications. I am thinking of trying them on a 246 gt that I am rebuilding. I am pretty sure that the ate brakes were the ones used on the 914-6 and not the 914-4. It is all on here some place. Good luck!
  4. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #4 synchro, Jun 26, 2008
    What do you need, just a rebuild or fully plated to show condition?
    If you choose to re-plate the calipers then the rears are the difficult ones as the handbrake mechanism is built internally to the caliper, so you must destroy the freeze plug to get at the internals and remove them before plating. I'm doing this right now and here's a pic of the Porsche specialist who is doing a batch. He's in the Seattle area, does exceptional work for the Vintage racing folks and does things correctly but is a little slow due to demand.
    PM me if you'd like his contact info.
  5. John Corbani
    Honorary Owner
    May 5, 2005
    1,153
    Santa Barbara, CA
    John Corbani
    Clay,
    Sorry about the "Search this Thread". Don't work. I was thinking Forum, not thread. The advanced search does work and you get lots.
  6. ENZOSON
    ENZOSON Formula Junior
    660
    Erie, Colorado
    PIETRO
  7. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #7 2NA, Jun 28, 2008
  8. John Corbani
    Honorary Owner
    May 5, 2005
    1,153
    Santa Barbara, CA
    John Corbani
  9. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #9 synchro, Jul 4, 2008
    This photo of my caliper was taken at "European Autowerke"
    Contact the proprietor:
    Bernd Buschen
    Fall City, WA 98024
    Ph: 425.445-9146
    Email: [email protected]
  10. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Note the spacer blocks that differentiate these from the Porsche 914
  11. racerboy9
    racerboy9 F1 Rookie
    2,649
    I believe the 914 also had smaller caliper pistons though I don't think that would affect braking that much as the rears don't do near the work of the front brakes.
  12. krisdisk
    krisdisk Formula Junior
    Mar 29, 2009
    500
    Flanders Belgium
    Kris De Bruyne
  13. racerboy9
    racerboy9 F1 Rookie
    2,649
  14. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,338
    Encino, Ca
    Carl T
    PMB are the experts at restoring ATE calipers! Speak to Eric if you contact them.
  15. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #15 synchro, Dec 12, 2013
