Attempted to lower 430...No such luck. Need advice PLEASE | FerrariChat
Discussion in '360/430' started by Pazzo009, Mar 30, 2016.
  1. Pazzo009
    Pazzo009 Formula Junior
    358
    Northern Atlanta Area
    Marc C
    Hi guys, first off, yes I have read the previous threads regarding the DIY of adjusting the coilovers. They have been informative but I am running into a certain problem. So before I throw in the towel and bring the car to a shop, I was hoping someone can offer advice or insight.
    - This may be a dumb question but I am still not sure which way to turn the ring. This simple factor was not explicitly mentioned in what I have read. My instincts tell me compressing the spring will lower the height, but I think I'm wrong. Part of me also thinks less spring compression will soften compression thus weight will compress and it will sit lower....Someone please answer this, and if so, did the ride become soft with more body roll?
    - My problem. I have the right spanner wrench and I did pre-soak with WD-40. I was able to loosen locking ring. On my main larger ring, I try to turn it (in either direction) and it doesn't stay where it was turned. It is moving though. So when I apply pressure the shock body itself, it was twisting about 20 degrees. I improvised a piece of metal to stop that between the shock body and lower control arm. After that problem was rectified, I was able to move the ring 1/4 turn in either direction, but as soon as I release pressure in my arm, the ring moves right back to its current resting position. It's as if the twist of spring is forcing the ring to move back to current position.
    Has this happened to anyone and is there a remedy. If not, the only viable option I see is to remove the spring and put a spring compressor on it.
  2. fatbillybob
    Aug 10, 2002
    28,948
    socal
    That is SOP. Also have a plan. What are you trying to do? If you are lowering the car because it looks better most likely you will make at limit handling worse than stock. The oem stock setup is there for a reason. You need to have reasons for changing it. Lower is not better unless it is met with alteration of companion components. Don't get fooled by "it feels better." You can have more exciting handling and a slower less safe car.
  3. Pazzo009
    358
    Marc C
    Hi, I would like to lower it for aesthetics. I personally do not like the stock ride height whatsoever. I am not looking for drastic, I would like .8 of an inch. I have read the mixed reviews regarding ride after lowering it. (I also know alignment is imperative).
    The car is a cruiser for me. Doubt I'l ever track it because I have a track dedicated car and a GT3. I just want it to look better. I haven't heard of many guys changing springs for lowering purposes on this car.
  4. Teachdocs
    Teachdocs Formula Junior
    Sep 3, 2012
    568
    Kansas City area
    Chad
  5. Pazzo009
    358
    Marc C
  6. Teachdocs
    Sep 3, 2012
    568
    Kansas City area
    Chad
    #6 Teachdocs, Mar 31, 2016
    The privacy settings had been modified. It is available for review now.
    You must loosen the jam nut first before anything else. The spring will typically twist when the large nut is turned.
    You lower the jam nut and perch nut in order to lower the car. The nuts get turned in a counter clockwise direction if you were looking up at the nut from the floor in order to loosen.
    If you use lubricant sprays, be. Artful to not get much in the ceramic discs.
    The video should answer your questions. Let me know if you need more help and good luck!
  7. Pazzo009
    358
    Marc C
    Okay, thank you very much. That helped with direction of spring. On to my next issue...I need to take load off the spring because I'm turning it and the perch ring moves right back to previous position.
  8. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    906
    S La
    I just did it but I raised one side. The spring must be compressed with spring compressors. Easy to turn collar when that is done and almost impossible to do without compressing the springs. Then, you must have the car realigned. Camber and toe will have to be reset.
  9. Teachdocs
    Sep 3, 2012
    568
    Kansas City area
    Chad
    Car must be lifted at the jack points with the spring fully extended. It is not nearly impossible as shown in the video. It takes a fair amount of determination but done without too much fuss.
    Ride heights are changed at the track all the time with race cars and they never use spring compressors.
    Assuming (which you should never do) the car was properly aligned prior to lowering, the camber offset can be mathematically determined by the number of turns lowered. Well documented in other threads. If you lower 4 turns, about 8 mm, this will give a little more negative camber which is definitely OK for the street. The toe will need to be adjusted for sure. Changing the camber as a DIY is not easy because you need to have a source of various shim thickness available prior to doing the adjustments. You can do it the old way and use various washers, but this is a Ferrari, not a spec Miata. A set of various shims will run you about $750 but you will only use 6-8 and they are not returnable.
  10. ItalGerBrit
    Mar 15, 2016
    906
    S La
    Do the race cars have the rubber gaskets between the springs and perches? The rubber seems to bind and prevent turning the collar. If metal to metal then turning would be fairly easy when lubed.
  11. Teachdocs
    Sep 3, 2012
    568
    Kansas City area
    Chad
    On the F430C, yes, but the rubber is slightly different.
    In the video, you can hear the rubber making noise as it turns the spring.
    Spray a little lubricant down at the bottom rubber perch support and also at the top of the spring.
    It is possible that your perch nuts and rubber are a bit frozen from age or oxidation or something. Once it breaks free, it will work well.
  12. Pazzo009
    358
    Marc C
    This is the problem I'm having.
  13. Pazzo009
    358
    Marc C
    I WD-40'ed the Sh$& out of it. I even pre soaked it 2 days prior. I am getting more than 30 degrees of movement, and once I release pressure from my arm, it goes right back. This only happened on the one coilover I attempted first. The only way I can see this working is relieving spring pressure with the use of a spring compressor.
  14. Teachdocs
    Sep 3, 2012
    568
    Kansas City area
    Chad
    Sounds like you have a stubborn frozen perch. There isn't much turning movement at one time so you just can't get it to break free.
    WD40 is only good at water displacement and not the best penetrating lubricant. Get some real penetrating lubricant and try that.
    Do you have a plan for the alignment to follow?
  15. ItalGerBrit
    Mar 15, 2016
    906
    S La
    That was my experience and if the tool slips off cranking hard on it you bang your knuckles. Getting the spring compressors on the springs is sort of a hassle as well and I ended up sitting the top compressor hook over the top spring perch mount.
    About the expensive shims, if you have the camber tool and are going to do the alignment yourself, you can temporarily set the camber using washers stacked together to determine the thickness of shims needed and just order what you need.
  16. GWARREND
    GWARREND Formula Junior
    Sep 23, 2012
    547
    Ontario, Canada
    Greg
    easier to remove the coilover and adjust out of the car... my .02
  17. Pazzo009
    358
    Marc C
    Absolutely...This is a known protocol after changing suspension settings
  18. vv23
    vv23 Formula Junior
    Jan 8, 2009
    259
    Edmonton, Alberta
    V V
    As the spring perch lowers, the car lowers and vice versa.
    I just lowered mine a few days ago. Un bolted the top control arms to get space, put spring compressors in to take load off the perch.
    Dialled the perch down and then took the compressors off and re bolted the control arm.
  19. blackbolt22
    blackbolt22 F1 Veteran
    5,808
    Boca Raton, FL
    Mr. Anderson
    I noticed no difference in handling with mine with a 22mm drop. I was told that was Euro ride height. It is unlikely Ferrari would use different springs for the US and European market. So I don't think there is a safety concern.
    You will need a front and rear end alignment afterward.
  20. f430_8451
    f430_8451 Karting
    Apr 4, 2014
    102
    Cali, OC
    Also, let me know if you need any help. I can take some pics of what I did that helped the rings turn easier.
  21. Pazzo009
    358
    Marc C
    #22 Pazzo009, Apr 8, 2016
    Hi, thanks for trying to help me out. I was able to get it. Spring compressors were needed in order to take the tension off the perch. Once I did that, it was smooth sailing. I went 11 turns. Don't know if I should go one more turn?
  22. f430_8451
    f430_8451 Karting
    Apr 4, 2014
    102
    Cali, OC
    Looks good. I went 10 turns, but noticed that it was too low for me, so I went two turns back up. So now i'm at 8 turns.
  23. martiy1971
    martiy1971 Formula Junior
    Jun 2, 2015
    647
    Alberta
    Robert Martineau
    Agreed, I just did this same procedure - remove the coilover from the car, compress it with a spring compressor and it turns very easy. you'll end up damaging either the car or your hands unless you do it the correct way.
